Scion TC Black Box?
  • Scion TC Black Box?
    Ok my friend just totaled his TC by rolling it after losing control on too hard of a turn on a highway... we need to know if his car has a black box and what kind of data it records
    thanks
    Debating on installing a carpc in my Jeep.....
    5 seconds of (speed, seatbelts, all sensor information, airbag deployment,etc...) I know this because my friend totaled a 2004 GTO and the insurance company is pulling this stuff out.
    4G64 5 SPEED
    MY CAR - MY 5SPD - MY CARPUTER - MY GARAGE SALE
      you kno the scion tc has one? and when does it record these things?
        http://www.vetronix.com/diagnostics/...icle_list.html
        i think the Scion's / Toyota's use a different brand, but i'm pretty sure they use one. I had this page book marked because it tells me where mine is. Basically they know how fast you were going, how far the Brake was pressed down, and how much throttle you were giving it 5 seconds before the crash. (it loops over itself every 5 seconds, and stops recording upon airbag deployal)
        Q: What data can be downloaded from the vehicle's air bag module?
        A*: Recorded data depends on vehicle make, model and year. The following data is typical of what is found on a newer GM vehicle.
        * Vehicle speed (5 seconds before impact)
        * Engine speed (5 seconds before impact)
        * Brake status (5 seconds before impact)
        * Throttle position (5 seconds before impact)
        * State of driver's seat belt switch (On/Off)
        * Passenger's air bag enabled or disabled state (On/Off)
        * SIR Warning Lamp status (On/Off)
        * Time from vehicle impact to air bag deployment
        * Ignition cycle count at event time
        * Ignition cycle count at investigation
        * Maximum ΔV for non-deployment event
        * ΔV vs. time for frontal air bag deployment event
        * Time from vehicle impact to time of maximum ΔV
        * Time between non-deploy and deploy event (if within 5 seconds)
        http://www.vetronix.com/diagnostics/cdr/index.html
        go to the FAQs
        I'mmmmmm a n00b.... feel free to make fun
          what happens if the airbags didnt deploy?
            Most likely it will have a blackbox. Doesn't the insurance company have it already? Would be kindo suspicious if they discovered that the tC didn't have a blackbox when it was supposed to have one.
            PowerVoice v1 | NaviVoice Source
            GammaControl v2.4
            SKINbedder v3
            1995 Lexus SC300
              reeeeeead the FAQs i said
              Q: Will data only be recorded if the air bags deploy?
              A: No, data is recorded in both Deployment and Non-Deployment Events.
                How about this, you drill a hole straight through the middle of it, and tell they it was your bad during an install
                  5 Seconds isn;t very much info really is it, you would have thought they could at least have a decent timeframe.
                    Well, if you were going 120 into the turn then that's VERY incriminating evidence. Wreckless driving, endangerment, etc...
                    GammaControl v2.4
                    SKINbedder v3
                    1995 Lexus SC300
                      this is also the older model, the one that had on select GM cars in '94?
                      who remembers their 94 computer? So yeah, the one in your brand new scion could have alot more. Also remember i'm not sure this is the exact black box used on the tC
                        How in the hell fast was he going to roll it on a turn thats on a highway? Highway turns are soooo gradual and slow already. I mean, i could see if it was a country road that had like a 70 degree turn.
                        But most highway turns are like 20 degrees over 200 yards or more.
                        Is he ok?
                        My Carputer Project
                          Ground the chassis of the box to soemthing solid, then hit the + volt lead with a 10,000 volt arc welder.
                          Is this where the witty comment goes?
                          97 Black pearl Mazda Miata MX-5 Carpc V2? maybee..
                            he turned sharp passing someone not a turn in the road... and yea everyone is fine
                              hook up 3 or 4 car batteries in series, which should give you around ~50 Volts, apply to battery hookups under the hood, and voila! You get hot steamy, roasted EVERYTHING.
