Motorola Razr V3 Volume Hack!!!
  • Motorola Razr V3 Volume Hack!!!
    I dont know about any of you guys who own a Motorola Razr V3 but the volume totally sucks on it! I can barely ever here anyone when im talking to them!. But not anymore! I have found a way to make the volume lots louder! Here is what you do:
    Download P2kTools: here
    Connect your V3 via USB to the computer. You can use the same usb cable that comes with most digital cameras instead of buying the motorola one.
    Next:
    Click on the green button "Switch To" And click P2K.
    Then click connect.
    After connecting to your phone go to "Tools" Click on gain.
    Click "Get" and the settings should be at 0. You can change them to whatever you want. Max is 8. But i wouldnt go higher than 4. When you are all finished click set. Then Click on restart in p2ktools.
    The phone should restart and you should be good to go!.
    *This mod should work with most motorola phones. Just remember you can only do this via a usb cable and not bluetooth!
    2002 Mitsubishi Galant
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    Souund Blaster Audigy2 NX
    OPUS ITX PC Case
    This is great
    one problem I went to the link you had posted for the P2k download and it isn't there any more.... What do I do?... I really need the volume louder too... please please help me..
    Misty
      Here is a working link for You guys...
      Here's the link for P2K tools for RAZR V3 and other MOTOROLA phones:
      http://www.motoaide.com:8081/download.htm
      VIA EPIA-SP13000--- 1GB RAM--- 2x 100GB Samsung 2.5" HD--- Wireless NIC + GPRS--- M2-ATX--- Mobile Impact--- Built progress... about 75%
        Thank you so much... I am truly phone stupid at this point so... what do I need to do next? I downloaded pretty much everything from that site )
          Come on bro, read the first post, install the software, make sure you download the drivers from that site, plug your phone into the USB and follow the rest of the directions on the first post....
          Carputer Specs:
          Via M10K
          512mb Ram
          60GB HDD
          OPUS ITX PC Case
            Originally posted by Cheekz185
            Come on bro, .
            Misty sounds like a girl name to me
            Installed.
            -GPSSecure- - GPS Tracking
              Yes I am a girl..I did download the stuff, however those instruction are NOT correct... but I did however figure it out.. thanks for the link to the downloads... You can't go to tools and click on Gain its not there... but you can go to the tabs below the the menu bar and click on OTHER FEATURES and on the left hand side there is the Gain Table adjustment it is simple slide bars and it works perfectly...
              Misty
                p2k tools
                I'm glad it worked out for You...
                  anyone else get an error while trying to connect?
                  Car Pc progress meter:
                  [-5%-------------------] Carpc build #2. So far, 20$ deep! I love recycling!
                  "The car is the closest we will ever come to creating something that is truly alive" -Sir William Lyons
                  My worklog
                    yes I did, and finally managed to connect by unplugging the phone from the usb cable closing the program and reopening it and then plugging my phone back into the usb cable..... you can try it worked for me...
                    Misty
                      Well, I have been trying this for a while now. I can't seem to get P2K to connect to my phone. When I click on connect, it tells me that the program is not responding. Any ideas? I have a Verizon Razr V3c. Thanks.
                        Did you download the P2K tool from the link above? I would try removing the program from your computer and then reinstalling it... make sure all other programs are closed when you try and use it...
                        Misty
                          P2K Tools not found
                          It seems the latest link above is now no longer functioning. I am having the hardest time finding this program.
                            TRY THIS ONE
                            http://motoaide.com:8081/download.html
                              That one worked! Thanks. This is a pretty cool site and I hope I might find more answers here. I bought a new GSM, unlocked V3 from TigerDirect. It came in a French version. I managed to change the language and everything works perfectly on the Suncom network except the browser. No matter what I cannot connect. I called Motorola and they said the browser was configured from overseas and there was nothing that could be done about it. I think the Motorola guy is full of crap as far as not being able to do anything. But, I need to do more research before actually attempting any changes. I don't want to make it worse.
