Windows 2000 Server Routing and Remote Access help
  • Windows 2000 Server Routing and Remote Access help
    im trying to share my netzero connection between by two pcs using ethernet.
    NetZero doesnt support ICS so im using Routing And Remote Access.
    I set everything up just like the help file says to and the PING your supposted to do works but i still cant get on the internet.
    P.S. This is my first post
    Edit:
    i have one computer with windows 2000 Server and one w/ Windows 2000 Pro. im using an ethernet connection between them. on the server i have a modem which i use to dial in to netzero. I want both computers to be able to be online at the same time but i cannot use ICS because Netzero isn't compatible w/ it. In the windows help files it tells how to share the connection using RRAS, so i did everything the way the file says but it doesnt work.(The PING TEST works but i still cannot connect)
    William Surritte, Technician
    No Limit Technologies
    1931 U.S. HWY. 160, Caulfield, MO 65626
    http://home.centurytel.net/nolimititech/
    Planning: |++++ |
    Software Development: |++++ |
    Hardware Development: |++ |
    If you can be a bit more specific with the setup it may be easier to figure it out or offer another possible solution.
    God made me the geek I am, the freak part came from watching RHPS too many times and drinking Re-Animator fuid at Con's too much.
      Hey Enforcer, I checked out the link. Very nice, but talk about spending quality time with your PC. Too bad Netzero doesn't support ICS.
        i got it partially working. when i type in an ip address it works but it doesnt work w/www's for some reason
        Planning: |++++ |
          because your dns server isnt setup correctly
          also, not to be a prick, but what are you even doing here if this is yer first post, and its offtopic? do you have a carpc?
          Roy
          2005 Range Rover 4.4
            Yeah, this post should have been posted here or here
              You could use a program like RASSpy to help you use ICS.
              ODYSSEY
              Originally posted by Tidder
              Digital-Car UK|
              (\__/)
              (")_(")
                no, i dont have a carpc. i joined when i designed a carpc for a friend, but he decied not to get it. the thought occured to me that some one here might be able help me.
                Quote by RoyN:
                Planning: |++++ |
                  What do you mean it doesn't support ICS ? Do you have a network connection ?
                  If so, you can make it work.
                  [H]4 Life
                  I'm a lesbian too.
                  I am for hire!
                    I tried just setting up ICS and it didnt work. When I contacted Netzero they told me it wasnt compatible.
                    Planning: |++++ |
                      Translation: They don't know how to set it up, and would rather you
                      didn't.
                      [H]4 Life
                      I'm a lesbian too.
                      I am for hire!
                        http://www.practicallynetworked.com/...nstall_dup.htm
                        http://www.practicallynetworked.com/...n2k_client.htm
                        http://www.practicallynetworked.com/...pip_manual.htm
                        http://www.practicallynetworked.com/...tcpip_auto.htm
                        [H]4 Life
                        I'm a lesbian too.
                        I am for hire!
                          i changed isp's today to one that supports ICS. Thanks to everyone who posted
                          Planning: |++++ |
