Resetting Honda Accord SRS light
  • Resetting Honda Accord SRS light
    Okay I did my homework by googling a while and found no specific answer to how to do it or having a ball to do it as I don't want the airbag exploded. The instruction said to short the Yellow MES connector for couple time. But I have learn for a long time that do not mess with any YELLOW wire under the steering column. To my supprise, there are a lot of SRS light problem with Honda than other made. Duh ....
    Anyway, my wife 2000 Accord SRS light came on the other day for no freaking reason. She may have placed her cell phone on the passensger seat while driving.
    So any one know or have a solid/reliable way to reset the darn light?
    My friend brought his Del Sol to the dealer and they charge 800 bucks to reset/replace the SRS system. I don't want to folk out that much cash to fix it when other said the light can be turn off by resetting procedure, but again the safety is my main concert here.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    I can send you instructions on how to reset it. Give me an email address. There are too many pictures to post it here.
      I did it in my X with a combination of taking the key in and out the inition.
      Hope kyjoe has the right answer for you.
      Thanatos.
      RexBruMet Skin for FrodoPlayer
      Nissan Aux-in MOD
      Originally posted by bgoodman
      We're an international forum, post in whatever langauge you like.
        If you get under the dash.....near the reverse side of the fuse box...behind the steering wheel there are a bunch of connectors going into a box. I've done this a few times, no problems. You can tell which the MES is...because its plugged into a dummy socket....there are no male pins in the socket. Heres the instructions http://www.superhonda.com/forum/show...59&postcount=5
        Also a side note......one of the symptoms of the light going on is low voltage......causing the SRS system to be alerted because it may not perform properly.
        PC Components:
        My work log
          another cause is moisture, and pulling the airbag fuse
          PC Components:
          My work log
            after being in a accident and havin my eyes open while the airbag explodes 1 half an inch from my nose ill tell you its not a pritty site and it smells like **** :-P
              i'd say quit being a pussy and do it. Just position your head so it doesnt take it off
              PC Components:
              My work log
                yeah then buy a whole new airbag setup for 500+ and have stupid airbag resedue all in ur car that itchs like a motha ****a and the smell never goes away
                  I had to have mine reset twice, once while installing a cd changer, and once after installing the carputer. In my case it was because I left the passenger seat out and had to reconnect the battery to drive it a couple of days before finishing. I just took it to the closest dealer - not even the one I bought it from. They reset it for free, didn't even take 5 minutes.
                    take a chance, pussy
                    PC Components:
                    My work log
                      The link that Peoples gave are the same instructions that I have. Go there and do as it says....
                        Alright, thanks a ton guys.
                        Will try that.
                          SRS instructions needed
                          Hey Can you send me the instructions for putting off the SRS light in Honda 2000 Accord. My email address is [email protected]
                          Thanks in advance,
                          Hari.
                            Thanks in advance,
                            Hari.
                              yeah. that happens a lot with 6th gen accords. for no reason many times. it just seems to happen around 100k miles or so, a lot of people on forums that deal with 6th gen accords have taken their cars to various honda dealerships (not just "joes garage") and there was no cause for the light to come on. it just does, we are just damned like that.
                              I have a 98 v6 coupe...and mine is on. i just havent gotten around to resetting it yet.
                              http://i25.photobucket.com/albums/c8.../positions.gif
