Need Help with Linksys Routing, Please...
  • Need Help with Linksys Routing, Please...
    Hello People,
    I have been using a Linksys WRT54G (v.2) router for about 2 years now. Pretty much problem-free, I shall add.
    Today I bought a WRT54GS (v.2) at a garage sale for dirt cheap.
    I got it to work within about 10 minutes, upgraded to the latest firmware from Linksys (4.70.6), and made sure it's working fine.
    Well, so far so good, but here comes my question/problem/request:
    I'd like to use the 'GS' as a hub only, meaning, it'd get the internet from the 'G' and pass it along on a wired network to 3 client computers.
    (I've already disabled the wireless connection on that one, so wireless isn't an issue here.)
    The 'G', however, would still provide Wireless, Routing, and Maintain the DSL Connection it's getting from the modem (as it have done in the past).
    I've tried messing with the "Advanced Routing" settings in both Routers. I've also changed the DHCP and Static IP settings to what I thought was correct, but none of that helped.
    To be honest with you, I don't even know whether I should connect the cable coming from the 'G' router to the 'GS's' Internet or LAN port.
    If anyone has a clue, I'm down to try anything except for moving to someone else's firmware (other than Linksys's)
    Thanks in Advance.
    For Sale: Carputer (CarPC) & RCA Y-Adapter
    Newsflash: Take a look at my unsold stuff above, thanks!
    Up Next: Make an OBD to Serial cable & Redo the "MMI buttons"
    Use:
    The uplink port to LAN port. (Regular cable)
    Or
    LAN port to LAN port with a crossover cable.
    No settings need to be set on the 'GS' as it is just being used as a hub.
    ODYSSEY
    Originally posted by Tidder
    Digital-Car UK|
    (\__/)
    (")_(")
      Originally posted by ODYSSEY
      Use:
      The uplink port to LAN port, or it might be uplink port to uplink port. (Regular cable)
      You mean use a regular RJ-45 from LAN-Out on 'G' into Internet Port on the 'GS'?
        Just checked linksys site. Neither of those routers have a uplink port, so just connect a crossover cable to a LAN port on each router.
        You also do the following: (Not the best option, but works)
        1) Connect LAN port of 'G' to WAN port of 'GS' (regular cable)
        2) Configure the 'GS' with a dynamic IP. (Also turn off DHCP)
        3) Place the dynamic IP of the 'GS' in the 'G' DMZ.
        ODYSSEY
        Digital-Car UK|
        (\__/)
        (")_(")
          If you want to keep it all in the same subnet just connect a regular cable from a normal LAN port on the G to a normal LAN port on the GS. Before you do that assign a LAN IP on the GS that's on the same subnet as the G and turn off DHCP on the GS.
          Nick
          '99 Ford Escort ZX2 CarPC <-- RIP Feb '07
          2006 Chevy Equinox LS (Current Project)
          **VIA EPIA PD 1ghz Mobo, OPUS 150, 7" LinITX LCD touchscreen, 512 Ram, 60Gig HD, DLink Bluetooth, Belkin 802.11g wireless,
            OK Guys, thanks for the tips.
            Here's what I'm gonna do right now:
            1) Follow nkotch's advice because I don't have a crossover cable around (and don't really feel like crimping one at 1am).
            2) If (1) doesn't work, follow Odyssey's unrecommended advice.
            3) If (2) doesn't work, I'll get off my lazy *** and make a crossover tomorrow or something...
            I'll get back to you on this one in a few minutes (no internet while testing).
              Hub/Switch to Hub/Switch requires a crossover cable.
              http://www.zytrax.com/tech/layer_1/cables/tech_lan.htm
              The following diagram shows the Normal use of Crossed and Straight cables (see also the notes below).
              Notes:
              We show Straight cables as BLUE and Crossed as RED. That is our convention the cable color can be anything you choose or more likely the vendor decides.
              To avoid the need for Crossed cables many vendors provide UPLINK ports on Hubs or Switches - these are specially designed to allow the use of a STRAIGHT cable when connecting back-to-back Hubs or Switches. Read the manufacturers documentation carefully.
              Some devices have auto-uplink ports, but not these routers.
              ODYSSEY
              Digital-Car UK|
              (\__/)
              (")_(")
                I followed what you guys have said in the first two tips, and unfortunately neither of them helped.
                I was able to ping www.google.com from the 'GS' router but not from "cmd" on the computer (using the nkotch's method).
                DMZ didn't work at all...
                It does make sense to use a crossover cable.
                So far, thats all I've got...
                  Does the 'GS' have an option to use as an access point?
                  I know that option on my Belkin turns the router into a switch.
                  Try over here: http://www.dslreports.com/forum/linksys
                  ODYSSEY
                  Digital-Car UK|
                  (\__/)
                  (")_(")
                    On the linksys spec sheet it says all the ports do "auto-crossover" so you don't need a crossover cable....most are like this now.
                    Nick
                      When you connected to the GS did you renew your IP and made sure you were getting an IP from the first G's DHCP?
                      Nick
                        This is as close as I can get while looking for an "Access Point" menu:
                          I just did.
                          It works now!
                          Thanks a lot, nkotch!
                            RTFM
                            ODYSSEY
                            Digital-Car UK|
                            (\__/)
                            (")_(")
                              RTFM
                              LoL, you edited it from a '.'
                              Thanks for trying, my friend.
