clutch job on a 2001 Eclipse Spyder GT ~$859.44?
  • clutch job on a 2001 Eclipse Spyder GT ~$859.44?
    ah! as expected, the clutch is starting to go out on my used 2001 Mitsubishi Eclipse GT. Interestingly enough, its only notable after it has been driven for a few minutes.
    Its quite an expected repair for a used car and its good its happening now that i have the money rather than later.
    Anyway, When you accelerate while in gear, the RPM's go up but transmission of power is not beeing sent untill a few moments later. Slippage. This is more obvious on all gears except 1rst.
    SO i looked around for some pricing, there is a Transmission shop right next to my house. They look well equiped and have TONS of business going in and out every day.
    I asked them for their opinion... they drove my car, and said it needs a clutch.
    Price quoted: $854.44 total of which 360.00 is labor.
    Then, I called two dealers and one wants about $1,000 and the other wants $1,160.
    All of them can get it done and out on the road in 0.5 to 1.0 day.
    Last time i took it to the dealer for A timing belt, i ended up paying about $700.00 out of the 499.00 quoted. They said the crank pully had cracked and the tensioner was leaking... what ever that was (extended warranty covered some of the parts) however im kind of reluctant to take it back to a dealer.
    hmmm...
    ~0okami.Digital
    Most clutch jobs are ~500-900 I'd say.
    Id recommend doing any other trans work at the same time since youll already have it off. (Limited slip, fly wheel, etc...)
    '02 GTI
    [Routis '04] [Opus 90W] [160GB Maxtor HD]
    [Lilliput 7" TS] [VIA M10000] [XMPCR]
    [512MB RAM] [Custom housing]
    [Deluo GPS Mouse] [E-MU 0404 Soundcard]
    Progress Meter: [==============|] 99.9%
      Timing belt jobs can be quite easy or difficult depending on the make/model/type of car. (Transverse vs. Longitudinal) A lot of the time you can do it yourself.
      The clutch job OTOH, usually requires a lift, plus a transmission jack/lift and specialty tools. At least the cars I and my friends have owned that have needed clutch repair/upgrades had to go to a repair shop to be done and they cost between $600-$1500 CAD. On the up side, as judoGTI stated, at least if you've already got it off, you might as well do some upgrades or preventative maintenance. (ie anything that looks like it may go, change it)
      I am not familiar with the Eclipse and am not a professional mechanic, but that price doesn't look unreasonable.
        that price is good. don't take it to the dealers. I cracked my oil pan, and they quoted me $550, and it ended up costing $630. For 4 hours of work and parts... Anyways my clutch is almost gone as well, to a point,where it holds nicelyin the gears, but i can't peel off from a red light, than it slips. I got quoted by the dealer ~$1200 to do the job, and a local tach wanted about $950-$1000. with stock parts. Id recommend you looking into all the parts that can be changed in the tranny, and get some aftermarket, maybe better quality parts than stock. I researched them for my Passat, and found that there are good quality aftermarket price to close as stock price, maybe a littlebit higher, and found a mechanic, who did a ton of work on my cars so far (including a full brake upgrade, and lowering my car) that will do it for $300 in labor plus parts. so all in all, if i'm lucky to get some deal on the aftermarket parts, i'll be done with like $700-$800 out the door, and have a better-than-stock tranny. altoghether, meaning flywheel, full clutch kit, racing tranny fluid.
        My 2 cents: Research a heck of a lot, and make an informed decision.
        Cheers
        BND
          I did a swap at my shop for $250, and a new clutch is no more then $200 so look at some other shops
          4G64 5 SPEED
          MY CAR - MY 5SPD - MY CARPUTER - MY GARAGE SALE
            360 for labor is fair for the job. 500 for the parts seems a tad high. Find out what all they are replacing for that price. Minimum you would want is a new clutch disc, pressure plate, and throwout bearing. Ask if they are replacing or just resurfacing the flywheel.
            Have the slave cylinder inspected and replaced if necessary.
            Whaile the transaxle is out of the car, have them inspect the cv joints on the axles, and while thay are at it, change the gear oil in the transaxle. Just a pm (preventative maintanance) thing on this.
              I don't know if this is something you'd be interested in, but the local high school has an automotive shop and when my clutch went on my beater car, I had them install it for no labor charge. All I had to purchase was the parts and the teacher is also a manager of a local auto parts store, so I got an employee discount as well. Good luck with whatever you decide
              2005 Black Chevy Impala
                Whatever you do, don't take it to the guy that does it in his back yard.
                Tidder
                Try RevFE
                I Wish I could ban people
                  Well, im going in today at 8:00am for the repair. Thanks for the information! I will ask for fluids and inspections to adjacent components while they are accessible and change of fluids.
                  thanks a million!
                  About the flywheel resurface, is that a standard procedure when changing a clutch? Or is that something that must be requested? what is the purpose? (i'd like to understand this better)
                  So far im aware the shop had to order a clutch kit for the car. (what ever that involves, i'll be finding out today)
                  ^_^
                  ~0okami.Digital
                    Originally posted by shotgunefx
                    Did you ask on club3g.com? You'll get a lot more specific experience.
                    actually, im having issues logging in to club3g, else, I would have continued a thread i started there. It seems cant log in via firefox, or IE on two different machines. Odd.
                    Well, the car is currently in the shop. *high hopes that all goes well*
                    I asked about checking all surrounding components, they said they do that by standard.
                    I also asked about resurfacing the flywheel, also something they do in the process of changing a clutch they said.
                    FLuids will be changed (he said most leaks during the repair anyway so thats also done in the process)
                    TOB also changed...
                    sounds like they handle all that should be... So it does not seem i have anyhting to worry about....
                    I can even see the shop from here......
                    *sits back by the window with a 300mm lens stalking the shop* ^_^
                    (not meineke, its the one on the middle/left... image reduced down to 10% of actual size)
                    ~0okami.Digital
                      hmm... that ip is not loading for me.
                      "There is no website configured at this address."
                      I'll try again later.
                      Well, im back from the shop! And with good news. The car does not seem to have that slip condition anymore. No noise when out in neutral either.
                      And whats more, the take off is *GREATLY* improved! so much that i accidently spinned the tires when going into reverse. The clutch feels totally different. Feels and performs like a whole new car! im impressed with their service. Looks like i found a new mechanic
                      *happy*
                      Now to take it out for a longer test drive...
                      Anyway, a side effect: It seems that the horn is not working when locked with the remote. Also when panic mode is set off, the horn does not activate either... lights flash... and thats about it. I checked the horn from the steering wheel and fuses, and everything seems normal... but no panic mode, or lock confirm horn. wierd.
                      ~0okami.Digital
                        *happy*
                        That is weird (the IP).
                        Horn "Answerback" is a programmable item. Check your owner's manual on how to program it. Defaults to off IIRC and they disconnected the battery so it's forgotten.
                        GE Cache Builder | [email protected] |Coolstuff :autospeed.com | bit-tech.net | Nitemax Ultra Pinouts
                          ah! problem solved with the horn!
                          Loose/corroded connector.
                          sand paper and a new terminal clip fixed it.
                          ~0okami.Digital
