Changing MT fluid....my self?
  • Changing MT fluid....my self?
    Anyone have experience changing their own transmission oil?
    Id like to say Im "mechanically inclined" but when it comes to cars, I know enough, but not enough to do everything myself.
    i dont change my own engine oil because of the cleanup and not having a garage, jacks etc etc.
    but when it comes to finally changing out my MT fluid/oil ive been quoted $60-75 just for the labor because I bought my own Redline MT90 oil.
    I think $60 is kinda crazy when I read up on how easy it is to change the MT fluid in my Matrix. Problem is the main forums i puruse have mostly the XRS (high end celica engine version) when people talk about doing their own MT changes. My engine is the smaller corolla engine.
    The Manual says it takes 1.9qts.
    I bought 2 qts....and I bought them online cuz no one in town sells it.
    I am scared to do my own change with only 2 qts, and find out its gonna take more than what I have, leaving me with air in my tranny....i guess I could recycle a tiny bit of the old used oil....
    anyone got any advice?
    (All done)
    iPad Mini 128GB, RF 600.5 amp, JL12W0V2, 8 Infinity Components
    the tranny should take 1.9 qts if those are the specs.... usually the procedure is to remove a lower drain plug... drain... then fill from an upper fill plug.....
    there are some that have no lower drain plug & you need to suck it out, then theres the problem of needing a pump with a hose to refill it, as it's underneith & can't be filled from the top like an engine....
    I'd say try to identify the drain & fill plugs, & if you have a way to pump the oil back in then you should be o.k.....
    the flip side of this is I have seen many guys screw there car up to try & save a few bucks doing it themselves, in general if your not confident that you can do it without a problem it may actually be the cheapest option of just having a pro do it on a lift..... with the right equiptment for the job..... the biggest variable is going to be the fill procedure & what's necissary for it, weather an injection pump or ???
      From the DIY on here
      i know where that is on my car, there is alot of room under the car near the tranny so I dont think id even need to jack it up.
      everyone seems to promote getting a pump to avoid spilling and making sure all of it goes into where it should.
      i think ill pick up the pump on the way home...
      (All done)
        Not that hard. Make sure park your car on a level surface. I did it on the Supra all the time, but not yet on the Matrix. Well, will do it soon. I think the bolts are 22mm or 24mm.
        - Unscrew the drain plug (just below the left driveshaft)
        - Let the oil drain while unscrew the fill plug.
        - When no oil left in to drain, screw the drain plug. Use new gasket and torque to 29ftlb.
        - Slowly fill new oil via the fill hole until oil spill out. That is the MAX level. If your are short on oil, check with your finger to see if the level is about to spill out. The manual state that the MINIMUM is 5mm from oil level to spill out and MAX is spill out. So if you are anywhere in between, you are fine. And if you still need more oil, either buy more or just reuse some old one. I am sure that you can't completely drain all oil off the tranny. So there is always "old" oil in there. Besure the nothing drop in that drain oil otherwise you can't "re-use" it.
        Y2K Accord Dell GX150
        EmoRebellion is a SCAMMER
          most of the times a pump is manditory..... there are things that look like a huge hypodermic needle, you suck it in by pulling the plunger back to fill it & then inject it to the fill hole.... when it's full it will actually spill out... that's the fill point, but the car has to be level..... be carfull with it jacked up... to much of an angle & it won't be filled properly...
            beat me to it
              So I need new gaskets? Are the gaskets rubber or metal? and I need two?
              (All done)
                It is generally easier if the new fluid is warm to hot. as most of it is very thick at room temps.
                Heat in a bucket of hot water (do not get any water in the oil)
                TruckinMP3
                Read the FAQ!
                  the gaskets are the washers on the drain plug.... they compressed when used & are a good idea to replace, although you could do them a few times without issues, to be safe pick up new ones if there easy to get...
                    so i need a 24mm gasket. right.
                    I assume an auto parts guy would know what im talking about...?
                    (All done)
                      yeah right.... you'll probably get that "deer in the headlights" look from the counter guy
                        no 24mm gaskets at the store. but got the ol $4 funnel with tube for ease of adding new fluid.
                        I dont have the celica GT-S 6spd tranny, but from the image I got on another forum the gaskets looks metal and not rubber...maybe its grey rubber?
                        Click image for larger version
                        you can see that thread here
                        now that I think about it, was the "funnel with 1/2" tubing attachment" what I wanted, or do I need one with an actual "hand pump"?
                        (All done)
                          Those are aluminum compression seals. Shouldn't re-use. May be a deasler only part. But they are cheap.
                            Those are just like the copper seals on the banjo bolts for a disc brake caliper. Good for 1 tightening, then that's it. Re-use may cause leaks.
                              why does the celica and seperate matrix forum not mention anything about buying a new washer...
                              for instance:
                              Once you know what bolt's to remove to accomplish the task, lets get dirty ! First remove the top fill plug - which is the 17 mm bolt. This is to allow air to fill the space of the old oil while it is draining. After it is removed place it and the washer aside in a safe clean place, you'll need it again.
                              (All done)
