Cpu upgrade enable l2 cache on startup
  • Cpu upgrade enable l2 cache on startup
    I've slipped a p3 500 mhz processor into my old p2 compaq laptop. It runs fine and recognizes the p3 as exactly what it is. The problem I have is that the bios is not accessable (compaq has it locked out) and the on chip l2 cache is not recognized.
    I can activate the l2 cache with a program called CPUMSR_0_90 and everything runs fine but must do so at every startup as the setting is not saved.
    Is there a way to have this progam enable the l2 cache automatically on windows startup? Maybe a command line (I'm not knowledgable enough to write one though)?
    Looking for a workaround, any ideas?
    Cheers
    BJ
    If you are running windose you can put the application in the startup folder.
    Other more techie solutions are possible... that is just simpe and easy.
    TruckinMP3
    Read the FAQ!
      Yeah, I thought about that. But I think what I ned is to set parameters in a config file and then have cpumsr run during boot up. Probably have to be a regedit thing.
      Thanks anyways.
      BJ
