Help with ******** not downloading....
  • Help with ******** not downloading....
    I'm trying to get a certain file from a well known site that happens to make you download another file to download the big file (I'll let you guys use your imagination on what kind of program I'm using..... )
    The problem is that this program requires an open port where I don't have access to the router...
    I downloaded PortScan 2000, and so far I've found supposedly 5 open ports. When I use the Nat/Firewall test on this downloader, with the port numbers it fails the test, almost as if these ports are actually not open...
    Anyone have any clues? BTW, there is a reason why I'm being so vague... If someone thinks I can give more details without getting in trouble here... I'll go into further details...
    Thanks,
    Rafster
    Post # 3000
    Can you forward the port? http://portforward.com/english/route...outerindex.htm
    PM me with the file/program you need and I may be able to help.
    Spent so far: $1,755
    Check Out My Work Log for Specs/Pics
    CarPC Progress[!!!!!!!!!!!!!!].....Installation[---------+].....Pastrami Progress[!!!!!!!!!!!!!!]
    Don't mess with Texas.
    It's not nice to pick on retards!
      Originally posted by Rafster
      ...where I don't have access to the router...
      Installed.
      -GPSSecure- - GPS Tracking
        Originally posted by xBrady
        Well said.
          hmmm... looks like this thread is being watched
            Ok, lets see. Bit Torrents are not illegal. So, should discussing them be taboo? Yes, they can be used for illegal file sharing. But guess what? The main purpose of this site is discussing carPC's which are illegal in some areas. Besides that, we are talking about our cars which can most likely go above the speed limit so should that be censored since our car can be used to break the law?
            If we can't have a discussion about legal programs then shut the thread down.
              Thanks,
              Rafster
              I just noticed this! Why the change?
                well that was meant for what he said above that post. but the one below that and above this one too!
                  OK, cool, I'll get right on that about forwarding the ports...
                  I'm trying to get a copy of Mappoints 06NA....
                  The Torrent App is called Azerus and the site I'm using is Seedler.org
                  But, now that I'm home, the torrent says... I can only leech from one location at a time.
                  I turned the other torent download off... WTF???
                  Peace,
                  Rafster
                  Post # 3000
                    azures kills my pc! really hogs the resources.
                      Yeah, but it's the best, IMO!
                      What do you use?
                      Peace,
                      Rafster
                      Post # 3000
                        I use utorrent
                        What do you use?
                        Peace,
                        Rafster
                        utorrent is the best IMO, its supper small and fast!
                          What do you use?
                          Peace,
                          Rafster
                          i still use it. runs on the server so i dnt need to worry about it slowing it down.
                            I use azereus too. Doesn't seem to slow my PC down much at all.
                            Check The Pirate Bay too. That is where I do all my DL'ing from.
                              utorrent is far far far far better than azureus. It looks the exact same, provides some extra features, and hardly uses 1% of my processor, usually 0. I was amazed that it doesn't even need to be installed, you simply run the tiny .exe and everything is self-contained.
                              I also found I was able to tweak it to get my download speeds quite a bit higher than with Azureus.
                              Anyways... I don't think you'll be able to do what you're trying to do without access to the router. if you have the router's IP adress, all you need is the admin password and you can get into the router's control panel. The password shouldn't be too hard to figure out, and if it's really tough, get it from the IT guy somehow, run a keylogger on his computer or something.
                              But all this just so that you can download stuff on your work connection instead of tying up your home connection?
