bad ideas?
This topic is closed.
  • bad ideas?
    we're all pretty swift around here when it comes to chemicals and ...what not to do.
    how about we give some kids some bad ideas and list every trick we know?
    i'll start with the obvious:
    aquafina water bottle... 4 hot tub chlorine tablets... 1" of sugar... crush the bottle...pour 1"-2" of rubbing alcohol into the bottle. screw the cap on... take your time. the sugar gives you a viewable warning and then the bottle will expand (remember, you screwed the cap on while it was still crushed)
    the bottle will expand and the sugar gives a cool illusion: white...then yellow...then orange...red...purple...then black... when its black..run away.
    louder than a shotgun shot and the sugar blows into the air.
    right after it explodes, run through where it was. you'll laugh so hard you'll cry!
    but everyones seen the dumbass's on ebaums manage to f*** that one up.
    anyone know the smoke bomb recipeit?
      botle of acitone and a match ;-)
        put some gasoline in a tub with a lot of green garbage bags. Let them soak for a while. Then just light, and run away...
        1.9in x 2.9in -- 47mm x 73mm
          styrafoam soaked in gas....turns into a jelly substance...put it on a 2x4, light it, launch it?
            potassium nitrate, sulfer, and fine grinded charcoal...
            gunpowder?
              thermite and anything that gets to 2200C... FUN!
              Click image for larger version
                um how about no
                I GIVE FREE HUGS!
                Buy Sell or Trade
                If my pm box is full, please feel free to call me any time. 440-328-3382
                Thank you
                Forex
                Rate Mp3car @ FXroot.com
                  alkasteltzer + dietcoke. For best effect mix in stomach to achieve accelerated results.
                  Rep! Rep! My kingdom for some rep!
                  My WIP
                  Ghetto Carlaputer: (putting things together) 0% * * * * * * * */2 - - 100%
                  Wife's patience: 0% * * * */2 - - - - - 100%
                    Christ... It's our own Anarchist's Cookbook thread....
                    Cut a slit in a tennisball or racquetball.
                    Cut the heads off of a ****load of wooden strike-anywhere matches and fill the ball witht he heads. When it starts getting full, you have to do this very, very carefully. When the ball is filled, seal the hole with superglue or a hotglue gun.
                    Now heave that sucker at a solid surface and watch the results!
                    Using a double boiler and all the caution available to you, heat up gasoline in the double-boiler and melt shavings of Ivory soap into the gasoline until it becomes jelly-like.
                    Use this in a malotov cocktail (Glass bottle filled with flammable liquid and a rag to ignite sticking out the top) and the liquid will be more jelly-like, similar to napalm (a registered trademark of the Dupont corporation).
                    How about the Wiki?
                      At the very least this thread will help weed out the population in regard to idiots.
                      "It's a blessing . . . and a curse."
                        Darwin Awards here we come!!!
                          Cant typ prply fngrs bandgd up!!
                          ....Yes, I know it has a stupid name, those crazy Japanese!
                            lmao....
                            If i told you guys how to make some of the stuff i know, people would be seriuously hurt. so ill refrain from posting it.
                            I will say that a stick of dynamite in an above ground pool, is pretty fun to watch from afar.
                            MII12000 | 512MB PC3200 | 60GB 2.5" Samsung
                            M2-ATX 160W PS | SlotLoad DVD/CDRW | BU353 GPS
                            7" Lilliput 619 | WinTV | WIFI | Bluetooth
                            Audigy2 ZS | HQCT | Kyocera KR1 Mobile Router(3G)
                            Roadrunner | LSXvoid | IGuidance 3
                            My Worklog
                              i believe friedrice meant to say mentos & dietsoda
                              PC Components:
                              My work log
