Dryer wont start! (it starts, but, as soon as the button is released, it stops!!)
  • Dryer wont start! (it starts, but, as soon as the button is released, it stops!!)
    I have a Moffat clothes dryer and it wasnt drying very well (it took two whole cycles to dry a batch of clothes) so I took it apart and found out that the back end of the drum was clogged, and the vent going outside was also pretty clogged.
    This is the second time I take it apart, first time was because a bushing of some sort was gone and it was squeaking. When i put it back together the first time it gave me the same problem, i wasnt able to keep the dryer running, when i started it, as soon as I let go of the start button, it would shut off. I fixed it by taking it apart, finding no problems, putting it back together! I didnt do anything and it fixed itself! This time, everything I try wont let it start by itself...
    What could be the problem?
    if i close the door it starts but doesnt stay on...
    if i open the door it doesnt even start
    so im guessing that switch is still good..... what do you think?
    here are some pictures that could aid in finding the problem:
    To view all the pics in a gallery:
    http://img213.imageshack.us/gal.php?g=dryer014lc8.jpg
    or seperately....
    http://img213.imageshack.us/my.php?i...ryer014lc8.jpg
    http://img213.imageshack.us/my.php?i...ryer013ld0.jpg
    http://img213.imageshack.us/my.php?i...ryer012ke5.jpg
    http://img213.imageshack.us/my.php?i...ryer010tb9.jpg
    http://img213.imageshack.us/my.php?i...ryer008ip0.jpg
    http://img213.imageshack.us/my.php?i...ryer003am3.jpg
    http://img213.imageshack.us/my.php?i...ryer001em6.jpg
    Thanks everyone!
    hang up the clothes and use a blowtorch!!!
    1.9in x 2.9in -- 47mm x 73mm
      nooooooo
      seriously,,,, ideas?
        that is usually a safety feature take it apart and put it back together again! Do it right this time!!
        Carputer Progress: Here we go again...
        THE GF THEME
        Genesis has speed
        Genesis has class
        Genesis sent money
        before your a__;)
        Join the fight against carputters. EMAIL ME!
          but there are no sensors for the dryer to actually know that.... i dont think thats the answer
            Check the connections on your Opus
            "A rose by any other name is still a flower"
              just forget about.
                i'd love to see the install pics!
                  What's this?
                  It looks like some kind of a door sensor.
                  Barring that, it sounds like some kind of relay is not closing. When you hit the start button, it probably closes some kind of a relay that handles the big power requirement of the motor and heater element. It sounds like that relay doesn't latch closed when you let go of the button.
                  Want to:
                    Well depending on the dryer it either has a temperature sensor or a moisture sensor. This tells the dryer when its time to turn off (or when it thinks the clothes are dry). Im guessing yours is faulty or you have a short and its causing it to turn off immediately.
                    See if you can dig up a manual for it and see where it is and test it out... Or pay a repairman.
                    '02 GTI
                    [Routis '04] [Opus 90W] [160GB Maxtor HD]
                    [Lilliput 7" TS] [VIA M10000] [XMPCR]
                    [512MB RAM] [Custom housing]
                    [Deluo GPS Mouse] [E-MU 0404 Soundcard]
                    Progress Meter: [==============|] 99.9%
                      just twist some wires together and put a switch on it.
                      I GIVE FREE HUGS!
                      Buy Sell or Trade
                      If my pm box is full, please feel free to call me any time. 440-328-3382
                      Thank you
                      Forex
                      Rate Mp3car @ FXroot.com
