Ad-Hoc
  • Ad-Hoc
    IS there anyway to change your wireless card to ad-hoc through windows? I dont have the linksys software installed on my PC cuz i dont like it... I want to set up a wireless file sharing via ad-hoc. Do i alo have to set my wireless router to ad-hoc? Do i need the linksys software for that also? I have a Linksy WRT54G rought WMP54G x 2 for my home pc's and an EnGenius EUB-362 for my car PC. DO i need the software or can windows do it?
    2002 Mitsubishi Galant
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    Souund Blaster Audigy2 NX
    OPUS ITX PC Case
    Hey, you're getting a few things mixed up. read what i put very carefully to see the differences in your idea of wireless jargon and the methods out there (not to making fun of you, but asking if yu can set your router to ad-hoc tells me you have no idea...)
    yes, there is. I don't have my laptop in fornt of me, but IM me for my number (you live like 20 miles away) and i'll gladly walk you through it. ad-hoc menas you network without a router, ie, not infrasturcutre. its basically device to device, with no central hub.
    Do you want to set up wireless file sharing period, or are you leaving the network and need to filehsare between devices connected to that network, or are you trying to connect to a single device and share files through that? To share files through your network, both in adhoc and infrasturcture, you have to enable shared folders in your "security and sharing" alt click or in properties on the harddrive/folder. You cannot share individual files, only folders, so you'll have to keep acopy of the files in the Shared Folder, whichever folder you decided it be. Then you have to make sure that both computers are in the same workgroup. Then you find the the files by mapping it as a drive. Another wayis Remote desktop, but we'll get to that later.
    You cannot have an ad hoc connection with a computer in infrastructure mode. Why? becuase you get one setting per network device. IF you have two networking cards, then you can bridge the connections with the wifi being adhoc, and the infrastructure/ehternet connection being hooked up to the general network, and bridge the two connections. that's all in network properites.
    Carputer Progress: Here we go again...
    THE GF THEME
    Genesis has speed
    Genesis has class
    Genesis sent money
    before your a__;)
    Join the fight against carputters. EMAIL ME!
      Hey thanks for your reply...Basically I want to be able to transfer files from my car pc to my home computer...I have 3 home pcs so i might be transfering from all 3... Which would be the easiest way to do that....I know somebody created a program to do this should i just use that?
      Carputer Specs:
      Via M10K
      512mb Ram
      60GB HDD
      OPUS ITX PC Case
        This might help as well: http://compnetworking.about.com/od/w...padhocwifi.htm
        to just transfer files you might consider joining your carPC to your home wireless network, and just share out the drives. Then access the drives you want and transfer the files.
        Jan Bennett
          exactly as she said. thats' the way i'm set up. that or have one PC as a decidacted file server for all
          THE GF THEME
          Genesis has speed
          Genesis has class
          Genesis sent money
          before your a__;)
