Car PC related injuries.
  • Car PC related injuries.
    Just a thought, who has done themself the most harm doing a car pc related task................
    I think I'm a record holder, but no doubt as more people in this hobby lose fingers etc we should set up a top 10 etc, so I want to start it off, rules are....
    1) it must be almost non fatal, or posted by a remaining loved one, if they so wish....
    2) it must be related 100% to doing something for your car pc, not say losing a finger in the escalator at walmart while shopping for a tube of glue for the car pc.........
    3) It must not be an injury caused by your car pc / modding activity to a friend, unless they were helping you, and then they must post their own injury!
    4) no paper cuts or 'look the pins on the motherboard stuck my thumb' wimps need post....
    So, without further hanginf around, heres my injury!, how not to open a little plastic box with an inverter in doing a button backlight mod for the TS
    Dont click links if you dont like cuts held together with 18 external stiches and 4 inside....
    I have not posted images direct so as to scare the wimpish.
    http://homepage.ntlworld.com/tinabri...eg/Pic(2a).jpg
    http://homepage.ntlworld.com/tinabriddon/leg/Pic(8).jpg
    http://homepage.ntlworld.com/tinabri...eg/Pic(11).jpg
    Lez, more widely known as flez1966
    WTF!! You got that f-ing hatchet wound from opening a plastic container?
    Progress:99% not 100% because theres always something to do...
    Centrafuse on XP (lited)
    EN15000
    120GB 2.5" SATA HD
    1GB DDR2 Ram
    M2-ATX PS
    Slot-Load DVD
    BU-353 GPS w/Mappoint 2k6
    DWW-700M
      no the knife created the wound when the plastic I was cutting open cracked........
        Almost DARWIN AWARD Candidate #1.. way to go... j/k.
        EN15000
        120GB 2.5" SATA HD
        1GB DDR2 Ram
        M2-ATX PS
        Slot-Load DVD
        DWW-700M
          WTF were you using to cut it open with? A samurai sword? Yaouch!
          System always under construction
            Ouch, you win, by a long way. I think I burnt myself a few times whilst soldering, but that's all.
              Musta been a Hattori Hanzo sword...
              EN15000
              120GB 2.5" SATA HD
              1GB DDR2 Ram
              M2-ATX PS
              Slot-Load DVD
              DWW-700M
                I was thinking it was a radial arm saw.
                Carputer Project Status:
                0% - Mobo died on 2/17/08
                Check out the worklog for my '01 Pathfinder.
                  Ouch!
                  The only real pc related injury so far was on my first build. I had a 2.5" to 3.5" HDD converter and it fell off the work table. I was walking bare foot, and stepped on it. Almost every pin went in to the hilt. Hurt like hell. Was really hard to pull out too, with all the pins it was in there very snug.
                  GE Cache Builder | me@cardomain |Coolstuff :autospeed.com | bit-tech.net | Nitemax Ultra Pinouts
                    i sat on a Sidewinder Joystick once... not so much physical injury, but i was metally and emotionally scarred for life...
                    EN15000
                    120GB 2.5" SATA HD
                    1GB DDR2 Ram
                    M2-ATX PS
                    Slot-Load DVD
                    DWW-700M
                      I had a toolbox fall directly onto my head from the very top shelf in my garage, maybe 10 feet up. I was incredibly lucky, the toolbox managed to hit my head facing absolutely perfectly straight forward and contacting directly in the center. So basically I dented the toolbox with my head and was stunned. Had the corner of the toolbox been forward, I might have had some severe injuries, sharp corner plus no weight distribution is not fun.
                        One time my work area in my room was messy and I triped over my ampie case and I was already having a bad day so I kicked my bed in rage and hurt my foot.
                          Whenever I do some work on my cars, no blood, job isn't finish.
                          Y2K Accord Dell GX150
                          EmoRebellion is a SCAMMER
                            Cut my thumb down to the bone with a box cutter.....remember to
                            always cut away from yourself
                            "A rose by any other name is still a flower"
                              was shocked by the car's electrical system when my brother cranked the engine when i was twisting two cables together so i could solder them...
                              DAMN I FLEW!
                              but the worst was having a capacitor (car audio) Blow up in my face when my Opus Shorted out
                              For Bootscreens click Here
