acura vibrating when accel.
  • acura vibrating when accel.
    The acura rumbles on accel. any idea why?
    You realize you posted this in the worklog forum, right?
    If you want to recieve any help, you will have to provide additional information (model, year, etc..).
    2002 Acura RSX CarPC Worklog
    Current CarPC Expenses
      thread moved
      Jan Bennett
        it is an omen from the car gods. BUY AMERICAN!!!!
        seriously, given the absolute bare minimum information you provided, there are at least 5 things off the top of my head that could be wrong. I am an ASE certified technician, and I can't figure out what the hell you mean. I highly doubt others here less qualified in auto repair will be able to help either.
        this is mp3car, not fixmycar.
        want answers, post details noob.
          I just think it's funny that he managed to have zero posts haha...
          I'm hungry
            The hamster cages are off balance. You must shift the hamster feed supply lines 42.pi micrometers to the left. That will cause your flux capacitor to correct for the imbalance and produce the neccessary power to send you into the future!
            1.9in x 2.9in -- 47mm x 73mm
              thats cause posts don't count in OT
              Installed
              Asus A7N8X-VM - AMD Mobile Athlon 2400
              512 Ram - 60GB HD - Opus 150w
              Lilliput 7" - Rikaline 6010
              [00000000000001100010-] 98% Completed
              Check Out My Install!!!
                I concur, you might also check your matter-antimatter reaction assembly to assure that the dilithium crystal is aligned correctly. You should probably hurry though, as you will get a warp core breach if it isn't realigned soon. Hope this helps!
                -Elliot
                  1.21 Jigga Watts!
                  Go Jay - Z
                  Go
                  (All done)
                  iPad Mini 128GB, RF 600.5 amp, JL12W0V2, 8 Infinity Components
                    Step 1 Check if the blinker fluid is low this is the #1 cause for this sort of thing
                    Step 2 Check for a leaking Pen15 filter
                    Step 3 Kick it (if all else fails)
                    .______
                    | '_ |__\___
                    [(o)|___(o)] XB
                    ._________
                    | I__I I_I|_\__I
                    [(o)______(o)]b VanPimpin'
                    LostReceptions Apps D/L Here
                    GPSGasoline- Rewriting
                    CarPCNetwork
                      I haven't changed my blinker fluid in years! I hope it doesn't happen to me!
                        I found this link its a general accelerationg problem should clear things up a bit
                        http://www.physicsforums.com/showthread.php?t=135350
                        .______
                        | '_ |__\___
                        [(o)|___(o)] XB
                        ._________
                        | I__I I_I|_\__I
                        CarPCNetwork
                          I'd just leave it like that....could come in handy when you're giving girls a ride
                          Asus MicroATX with GeFore 6100, Mobile Sempron 3300+, 1Gig Ram, 320GB 3.5" 7200UPM HDD, M2-ATX, Gain/Xenarc 7"
                          Fast IS my copilot
