325i BMW / Newbie's first project
  • 325i BMW / Newbie's first project
    Sup my name is Joseph and i'm starting my first carputer project. I just started this so i would learn more about the installation process...
    Right now the system i've chosen is as follows:
    Touch Screen either in dash or motorized
    mobo:either a mini itx or possibly a nano itx
    Case: not sure suggestions would be great
    Memory: maximum for Mobo
    PSU: HELP this is my biggest question how did you hook up you carputer to your car's power
    Max harddrive supported...and a dvd burner or a just a dvd reader/cdwriter....i got to go but i will finish this post in i don't know 5 hours
    Peace...JOE
    Case: YOu have many options. Look in the store under "enclosures" and you will see the Ampie/VoomPC, VoomPC2, and Morex cases. The first 2 only take the M1/M2 and the last one only takes the Opus.
    Also look in the FAQ section for the thread on how to power you computer from a dc-dc power supply. It explains it really well. If you have questions after reading that, then go ahead and ask.
    For the dvd burner go slim (laptop drive) because the standard 5.25" drives draw a ton of power, and it is just a waste.
    Maximum HD space... There is no maximum! The via boards have 1-2 IDE channels so 3HD's and an optical drive. Then there is USB, so up to 128 hard drives there per usb root which would be 2 root hubs per mobo. Then PCI, and you can get controllers for that to get like 8 channels, for 16 drives. So that is a couple hundred hard drives.
    But seriously, you can use a 3.5" drive which go up to 750Gb as of now for a single drive, and 2.5" which are just around 200Gb limit.
    Keep in mind if you use the Ampie/VoomPC case, you are required to use 2.5" drives and you can have up to 2. And a limited number of 44pin to 40pin IDE adapters will fit in the case.
    Each case has limitations, and benefits.
    Oh, and
    1.9in x 2.9in -- 47mm x 73mm
      thanks for the reply
      Well....now that i have the power issue taken care of...thanks to those who wrote the FAQ does anyone know how the wiring works in the bmw...i'm trying to get an internship/job at a custom car place but any sug. before i do that?
        just research as much as possible, you dont want to spend cash on equipment you really dont need.
        ...Also can this be moved to the Newbie forum?
        Motherboard: Epox MATX
        Power: M2-ATX
        Storage: 120gb 3.5"
        Optical: Slim Slot cdrw/dvd
        Audio: SB Audigy 2
        GPS: BU-353 & iGuidance 4
        OS: Win FLP (Fundamentals)
        Frontend: Roadrunner (DFX 3 & 4)
          yeah sure.....sry....i intended to show my finished project here....sry again..
          PEace...JOE
            PLEASE PLEASE please..... dont put a motorized monitor in your BMW. Take a look at my project if you need some ideas and shoot me a PM if you have any questions.
            2003 E46 BMW
            Lilliput Transflective, GM965 mobo w/ Processor
            ELMSCAN 5 USB, Slot load DVD, BU-353 GPS
            Everything is for sale.
