2002 Civic Si Install
  • 2002 Civic Si Install
    My Install
    Hardware:
    • Dell Optiplex GX260
    • P4 2800
    • M2-ATX
    • 512mb ram
    • 80gb WD HDD
    • BU-353
    • Belkin F8T003 (10m bluetooth adapter)
    • 3DConnexion SpaceNavigator
    • Lilliput EBY-701
    Nick - 08 GG Element
    Custom 3D-CAD Design, Reverse Engineering and Fabrication
    SpaceNavigator
    SpaceNavigator with hand brake down for driving:
    SpaceNavigator with hand brake up for parking:
      Screen Pictures
      EBY-701 installed in dash without modification
      There is a little glare but not too bad.
      Closer view
        I always love how the 7th gen civics have the perfect opening for a 7" widescreen.
        I drove around like that for a year before I finally had help filling the gaps. Any plans on finishing it up sometime? I got my spare dash piece off of eBay for $20-$30 (I cant remember anymore), so I can go back to stock easily.
        1.9in x 2.9in -- 47mm x 73mm
          The only gap is the one on the right side. The gap around the top, bottom, and left is actually less than the aftermarket kit I had in there before. I did put a bead of clear silicon along the bottom and left side to keep things from rattling.
          I still want it to look like there's a screen installed. I played around a little with the idea of molding it in, but I bought a warranty for the screen (since they are prone to have issues) and I'd rather keep it unmodified so I can pull it out in the event of a failure.
          I could probably caulk it with some satin black or grey silicon to clean up the edges a bit, how do you think that would look?
            Tried it, it looked aweful.
            I dont have the si though, I have an ex, so the dash was black not silver. So it looked more uniform. I think it just looks a bit out of place.
            Something you may have better luck with is a Metra double-din kit. Then shave away the top, bottom, and left side until it is a tight squeeze fit, and the right side will cover that hole weird shape up. I tried but I accidentally broke mine so then I tried it and some Plast-dip to try and make it look better, and long story short, it was the worst looking thing ever because the filler I used was shiny rubber...
            But I think if you have more patience than I did, and took your time, it would look really good for little work.
              I just went out and measured and there's less than a 16th of an inch on the top right hand corner and top left corner so the fit would be really tight. Are you talking about the 3/16" gap on the left side and bottom? I know that the weird shaped triangular section needs something I just haven't decided yet what. I actually have one of the metra kits sitting on a shelf at home so I can start hacking it up and see what I come up with.
              Thanks for the honest feedback on the fit.
                looking good, how do you like the space nav? clean up the screen install and you got yourself a great looking project
                New System in progress:
                M10k
                Phaze TD1500 ~> Seas g18rnx/p
                Zapco Ref 500.1 ~ 12" tc-9
                Transflective Xenarc
                My Car Pc Install
                My Boat Pc worklog
                  Also as a side, do you have leather seats? I didnt know that was an option on our cars... That makes me sad. Stupid cloth...
                    I like the SpaceNavigator a lot. I use it mostly for volume and skipping tracks. On a regular day drive to work I don't even have to touch the screen. If I want to load new playlists then I have to touch the screen. I just need to get the hotkey for switching playlists to one of the buttons on the SN.
                    As far as the screen install goes, I got the trianglar piece worked out and I'll get some pictures pretty soon. The rest of the gap is too narrow to fit a plastic trim piece in there but I'll post my new solution in a day or two when it's done. I can't do anything permanent (or modify the screen) because it would void the extended warranty that I bought for it.
                      The Si only came in one trim level with the seats covered in alcantara suede. It's pretty nice because you can actually clean the suede and the inserts in the center are a type of nylon which stays pretty clean and ventilates well when driving
                      The new Si is supposed to have the synthetic suede seats too, but I checked one out and they are more like soft cotton than suede. A bit of a disappointment.
