2005 G35 Coupe Install
  • 2005 G35 Coupe Install
    Welp,
    Finally made the plunge and got it all installed this weekend. More updates to follow... here are a few pics for now.
    What size screen is that? doesn't really look 'natural' in that spot as it seems too big. You going to remove it from the case and mount it back behind the door there?
    Nice infinity wish I could afford one. Instead, I have to settle for a lower end Maxima...which is still an awsome car compared to what I used to have.
      700tsv
      The screen is a Xenarc 700TSV fitted into a digitalwheelz/mp3car infiniti custom housing. The screen can manually be retracted back into the cubby and the cubby lid shut to give a completely stock look. Other than the sides to the left and right back of the screen exposing the innards of the custom housing, the screen looks pretty stock IMO. I am finishing the trunk rack for the pc tonight. I will post some more pics when I am done.
      Regards,
      ikon
        nice like the housing matches the oem dash, where did you pot the computer in inside the dash or the trunk
        D
        2001 Nissan Maxima SE
        http://www.cardomain.com/ride/2642862
          trunk
          I put it in the trunk... building out the rack for it tonight. I figured 99% of the time I won't need access to the dvd drive while driving. If I do, the rear seat comes down and a passenger could get at it.
          -ikon
            The housing matches, but what I was referring to is that it just looks odd to me that it is taller than the lid when out. Cool that it retracts back though. Do you get much glare on it mounted that way?
              true
              It does stick above the lid a little bit... wouldn't really want a screen smaller than 7", guess that is how the cookie crumbles.
              I was a bit frustrated with mp3car with this custom housing. They forgot to include the necessary magnet mount that keeps the screen stuck to the lid (you can see we used magnet tape on both the lid lip and the back of the screen). Also was missing some screws needed to bolt the housing to the head unit rack, as the OEM bolts didn't fit the holes in the new housing/cubby replacement. So after driving back and forth to Lowes about 50 times during the install, we finally got it all in. On the plus side, I have always been able to get ahold of mp3car support and Naqueal has been great to work with in that respect. Also, i realize that this housing is hard to come by, so I am happy to have a prefab'ed solution versus having to create something myself.
              The glare isn't bad, but i have noticed some cases when in direct sunlight that it is less than perfect. The custom housing only works with the older xenarc screens, so i was kinda pigeon holed into that option.
              <rant>
              Conversely, I refuse to pay $700 for a 7" touchscreen (mp3 cars daylight readable screen), so the Xenarc was my best option sub $500. I work in flash all day creating touchscreen kiosks. We buy 42" LCD touchscreens with the computer built in for ~ $3000, so I refuse to pay almost a grand for a 7" touchscreen with no computer. When the price point comes down to $500 or less I would consider it. Not that i will even have that option with this housing... </rant>
                not sure how technical you are, but check out the 3M upgrades thread in the LCD/Displays forum. I have a lilliput 701 screen and the difference of sunlight readability before and after I upgraded the screen with the 3M films is literally night and day. If it weren't for the glare of the touchscreen, I can see the screen in direct sunlight perfectly fine.
                And I agree... upwards of $700 is a bit steep for a sunlight readable screen.
                  3m
                  I will look into the 3M upgrades... probably wait till after winter however.
                  I had two IT-related internships with 3M so I can get some good deals still. :-)
                    here's my results from the 3M upgrades to the lilliput 701 screen. Before the 3M films, the screen was crap in daylight and direct sunlight. I still have a glare problem which I'm hoping to be able to order some 3M anti-glare films for, but as far as seeing it in direct sunlight I couldn't ask for much more of an improvement. Fully readable (except for the glare off the touchscreen) even with brightness at only 30-40%.
                    http://www.mp3car.com/vbulletin/1119202-post223.html
                    I got the films as samples so the upgrade just cost some of my time and patience. Unfortunately, I couldn't get a full sheet of the anti-glare (ARMR-200) as a sample, just a piece big enough for my blackberry
                      looks great!!
                      I wanna do the same thing to my 05 g35x. just got a couple of questions for you.
                      - How hard was it to install the LCD into the mp3car housing?
                      - How is Xenarc 700TSV? this is the touch screen?
                      - you say that the lid isn't flush to the dash. how big is the gap?
                      - how did you wire the sound to the stock HU?
                      thanks.
                        - mp3car installed my Xenarc screen into one of their housing units. If you have all the parts, they will do the work if you pay them for their time. If you talk to them, I am sure you could work something similar out.
                        - its ok. it has a lot of glare once in awhile. Its bad enough that with my polarized sunglasses on i can't read the screen when in the worst light conditions. Otherwise its a great screen for resolution, color, and general brightness.
                        - i didn't say that, someone else did. what he meant was that in the above pictures the top of the screen is higher than the top of the lid that is flipp d open. however when the screen is tucked in the cubby, the lid shuts flush just like it does OEM. Also, the passive volume knob fits inside the ashtray unit and it flips back to flush as well. So all in all, when everything is hidden away, it all looks stock.
                        - i went from the pc out -> navone line amp -> passive volume control knob -> PAC AAI-NIS2 -> stock HU.
                          sorry to bother you but just got couple more questions...
                          - What is navone line amp, and pac aai-nis2?
                          - If im going to just add a garmin blackbox navi., and a dvd player, how would i wire the sound to the stock HU?
                          thanks alot..
                            ummm
                            a navone line amp amplifies the voltage on the line. the pac piece lets you plug two RCA inputs into your stock head unit.
                            ikon
