2006 Mazda 3 In-Dash CarPC Install.
  • 2006 Mazda 3 In-Dash CarPC Install.
    Well, my setup is finally coming together and looking more and more like it's complete.
    Here's my current setup (also in my sig, heh):
    - VoomPC I Mini-ITX case
    - Commell LV-677 DC-DC Motherboard
    - M2-ATX 160w PSU
    - Intel Core 2 Duo T5500 1.66GHz 667MHz FSB 2MB L2
    - 1GB (2x 512MB) DDR2 667 RAM (i believe it's Kingston)
    - Dynamix 8" Touch screen
    - AuxMod
    - Audio line loopback filter (filter out noise on audio line)
    - Holux GR-213 GPS receiver
    - Targus 4 port USB hub
    - My cell phone as internet (Sanyo PM-8200 w/ Sprint PCS Service)
    Future Plans:
    - OBD II interface\setup
    - Permanent Wifi connection.
    here are some pictures i took, it's a mixture of different times when i took it, the water look is the most recent ones.
    Click here to go to my Villagephotos.com photo gallery. (There's 3 pages of photos on there.)
    I do have a 1 question though, does anyone know how, if at all, to get an actual 10, 20, 30, 40 etc MPH picture behind the speed on my GPS stats page? it's just a blank white box.
    let me know what you think, comments\suggestion\questions of your own (even if you don't know the answer to my question.)
    thanks
    2006 Mazda 3 S Series
    2.3L 4cyl Engine
    Current Build
    - Commell LV-677 Motherboard
    - Intel Core 2 Duo T5500 CPU
    - Dual 512MB PC5300\667MHz RAM
    - Seagate 80GB SATA HDD
    - M2-ATX 160W PSU
    - Dynamix 8" LCD Touchscreen
    - VoomPC I Mini-ITX Case (Black)
    What skin are you using
      i'm using the roadrunner FE and DigitalFX skin
      2.3L 4cyl Engine
      Current Build
      - M2-ATX 160W PSU
        The link to your photos doesn't work for me
        Carputer Progress:
        Re-do fabrication of screen [DONE]
        Add mini-USB and micro-USB power from M2-ATX [DONE]
        Teardown PC [100%]
        Add HDMI > VGA converter [0%]
          really?
          what happens when you click it? it's just a simple link to the public folder of all the pictures i put up...
          2.3L 4cyl Engine
          Current Build
          - M2-ATX 160W PSU
            Can't access error - might be the network here, maybe I'll try it elsewhere
            Carputer Progress:
            Teardown PC [100%]
              does your network have some type of filtering or accessability restrictions or is it full unrestricted\filtered access to the internet?
              2.3L 4cyl Engine
              Current Build
              - M2-ATX 160W PSU
                nice install. whats the model number of that dynamix screen that you are using? how is it?? i want to get the Dynamix 816 monitor, but i havent heard much about it
                [::::::::::] 100% - Planning
                [::::::::::] 80% - Computer
                [::::::::::] 0% - Fabbing
                CarPC:
                SP13000 / 120GB SATA 2.5" / 512MB DDR
                8" Innovatek TS / Globalsat BU-353 / Engenius EUB-362 EXT
                Slot load DVDRW / PS3 Wireless Keyboard
                  that's exactly the one i have.
                  it's kind of a pain though, it's only mounted with industrial strength 3M double sided tabe used in car installation stuff. i nor anyone in the bestbuy mobile install bay at the store i used to work at could help me mount it permanently because the backplate of the screen is like a very thin aluminum and has holes literally the size of o that.
                  2.3L 4cyl Engine
                  Current Build
                  - M2-ATX 160W PSU
                    Question on ignition sense connection
                    Hi,
                    I like your install. I'm doing something similar myself using the Japanparts box and the VoomPC-2. The M2-ATX supports an ignition sense connection. Where did you get this? Did you splice cables from the HU?
                    Thanks,
                    AQ
                      the PSU should have a lead on the board that goes to the ignition power line on your vehicle.
                      2.3L 4cyl Engine
                      Current Build
                      - M2-ATX 160W PSU
                        soo nice
                        r u used Road Runner ?
                        i need ur skin plz
                          yeah i'm using RR with DFX 4.0 right now.
                          2.3L 4cyl Engine
                          Current Build
                          - M2-ATX 160W PSU
                            nice install, check out my mazda3 install. http://www.mp3car.com/vbulletin/show...h-install.html
                            "The text that you have entered is too long (12638 characters). Please shorten it to 10000 characters long."
                            Dam it!
                            "The text that you have entered is too long (10418 characters). Please shorten it to 10000 characters long."
