2000 Mitsubishi Verada Car PC Install
  • 2000 Mitsubishi Verada Car PC Install
    When I bought my Mitsubishi Verada (luxury Magna, or Diamante as it's called in the USA) in September 2007 I knew I would be keeping it for a few years, so I decided that I was going to take the plunge, and build a Car PC like those that I had read about on the these forums. The computer would replace the standard audio system, and add MP3 playback, video, GPS, GPS tracking and internet access to my car.
    After months of dreaming about such a setup my Car PC is finally installed. I've had the computer on my desk for over 3 mths now but time and money (for the amp) kinda pushed it WAY forward to this day. Since my dad was off work for the Australia Day holiday, we decided it was time to tackle it.
    First off the computer. It's has the following specs, including prices paid for the components and where I got them:
    * Intel D201GLY Motherboard US$69.95 (~AU$78) (
    * Intel Celeron 1.33Ghz (Integrated onto motherboard)
    * 1GB RAM - AU$35 (local PC shop)
    * 250GB 3.5" HDD - AU$85 (local PC shop)
    * Sound Blaster Live! PCI (4ch output) - had lying around
    * USB WiFi - AU$40 (eBay)
    * USB BT AU$15 (eBay)
    * USB GPS - AU$70 (eBay)
    * USBFever Mini USB Keyboard - US$24.99 (~AU$28) (online store)
    * Griffin PowerMate USB Controller - US$49.99 (AU$56) (
    * Griffin Radioshark v1 - AU$23 (eBay)
    * 7" Lilliput LCD (running at 800x480 via PowerStrip) - AU$100 (member of AussieMagna Forum)
    * M2-ATX 160W DC-DC PSU - US$89.94 (~AU$100) (
    (NOTE: Mobo and PSU were US$207 with shipping to Australia)
    The motherboard was chosen both for it's size and cost reasons. The Mini ITX boards based on the VIA chips were a bit out of my price range, and having used the Intel on my desk for a while it's definitely up to the job. It has no problems with high-res DivX files, whilst simultaneously running GPS. For $69.95 it was an absolute bargain!
    RAM is cheap, so 1GB was a no brainer. 2GB is overkill (my MacBook Pro has that much!), and 512MB too weedy. The system needed to be able to run both GPS and Video/Audio simultaneously.
    I decided to go with a full size HDD because I wanted the storage space. There is the concern that the vibrations and high-temperatures in a car would damage the HDD, but it doesn't have any critical data on it, so if it does die one day, I won't lose any sleep over it.
    The SoundBlaster soundcard was a last minute decision. I was going to use the onboard sound, but then remembered the SB that I had lying around. Popped it in, loaded up the drivers, and now it outputs 4ch to the 4ch amp!
    The WiFi, Bluetooth and GPS adaptors were bought on eBay. The WiFi adapter is mounted in the parcel shelf (between the rear speakers) and the Bluetooth and GPS adapters behind the back seats. The GPS antenna is right at the back of the parcel shelf.
    The USB Keyboard is a miniture one from USBFever that fits perfectly in the glovebox, and it easy to use whilst sitting on my leg in the drivers seat (not while driving, obviously :-P).
    The Radioshark software worked perfectly, but I quickly found the reception to be rather poor. Until I work out how to wire it up to the car antenna, it's in a drawer.
    The PowerMate was added shortly before installation, and it's brilliant. I have it setup to control the volume when turned, scroll through songs when playing music (aka. next/previous), and skip forward/backward when playing video. Every car PC install should have this.
    The display I bought off a member of both MP3Car and AussieMagna, as he was changing his Car PC setup and didn't need it anymore. It's a 7" Lilliput with a USB touchscreen, perfect for controlling RoadRunner, the frontend I'm using. Using PowerStrip, I have the display running at 800x480. For some odd reason the 800x480 display will not display that resolution properly without some tweaking from PowerStrip.
    I've found RoadRunner to be pretty much perfect for me, as it works with MapMonkey, and works well with the PowerMate and RadioShark (when I get it working).
    The system spent about three months on my desk before being installed, for several reasons.
    1. Wanted to get it all configured before bolting it down in the car.
    2. Was progressively buying the pieces when I had the money to do so.
    3. Time.
    Reason 1 was prevalent right up to installation.
    Reason 2: I finished buying all the bits in early December.
    Reason 3: Uni, work, travelling and Christmas in NZ all conspired to push installation till January 26th (Australia Day!). Ok, the travelling and NZ trip we're great, definitely worth the delay :-P
    My original idea was to install the PC into the glove box, but some testing a few days before was started the installation showed it just wasn't possible. The glovebox wasn't going to be big enough to accommodate the motherboard, PSU and a 3.5" desktop HDD. Time to move to Plan B, install the PC in the boot. This actually was a better idea anyway, since the glovebox is a very confined.
    My dad and I installed the system over a 2 day period.
    Along the left side of the car are all the power cables for the PC, Amplifier, turn-on wiring, display and power button (necessary for when Windows crashes).
    Along the right side is the VGA cable and USB extension cable. The USB extension cable runs to the glovebox, where it meets up with a 4-port hub to connect the USB touchscreen, Powermate knob, the USB Keyboard, and a spare USB for either a mouse or USB memory stick.
    All the wireless radios went in, behind the back seats and under the parcel shelf. These locations were selected to get the best signal out of the car without adding antennas outside.
    We built the computer case ourselves using a cheap metal-look briefcase ($20 of cheap wood and metal-look plastic sheeting) and a bathroom vent. Total cost was $25, and it came out quite well. The case has more than enough room for the mobo, PSU and HDD. Whilst I haven't had any trouble with heat, I will likely add two PC case fans to increase airflow.
    Powering the speakers is a 4 channel 500W Sony amplifier. Certainly not the best in car audio, but will serve me nicely until I have the money to improve on it. Sounds just fine for AU$168!
    The PC case and amp are mounted on a plank of wood that is bolted to the original carpet. It's not attached to the chassis, but it's wedged in tight, it's not going anywhere! (somehow I have misplaced these photos, will take some more tomorrow)
    During the screen install the dash looked like a wreck! Glovebox was out, kick-panels out, dash out, almost everything out! All went back together just fine, but oddly (and somewhat worryingly) I had several screws left over :-P
    The Powermate USB knob is attached to the centre piece with velcro, and the USB cable runs up to the glovebox.
    Thanks to Hamish and Andy for some background entertainment
    With all the cables run, everything connected, the seats bolted back down, and the panels back on this was the result:
    I've been using this system for several weeks now and it is working beautifully. Apart from the odd crash (unavoidable since it's running Windows :-P) it's fantastic, can do anything you can do on a regular computer.
    Two days ago I altered the icon on the GPS app that represents the car driving along the road. Now shows the back of my car driving along hehe :-)
    Well that's pretty much it. I've also got a reversing camera installed in the boot keyhole, and a Digital Speedo running off the GPS.
    Steal of a price you got on the Lilliput!
    Looking very good mate. Well thought out system.
    Sound familiar when you live in Australia and you have to buy the majority of your gear from overseas!
    Where did you get the maps from? PM me?
      Yeah I know! Bought the screen off a member of this forum who was upgrading.
      It is a pain having to get some stuff overseas, only because the post jacks up the final price a bit!
        Hi dude, very nice post, I sometimes thought you were telling my story. Started with the same car manufacturer, then a busy end of the year schedule and to match even more, the same difficulty in getting the parts.... the expensive overseas mail. Everything is here now at last, except for that 'D' day to get it up running.
        If I could give you some advice if donīt know that yet, if you plan to have obdII monitoring in your rig, thereīs one place where you at least I guess wonīt spend much with the mail, which is at Evoscan
        Nice install also btw
          Mate, I hate you so much right now, because I can see myself opening my wallet very, very soon to buy one of those :P
          That software and cable looks fabulous! Definitely going to look into that!
          Good luck with your system mate, make sure to post lots of photos when you're done
            hey hey, that screen looks familiar! Good to see your install on here mitchello, me and my magna were starting to get lonely.
            Continued Worklog... Upgrades in progress:
            *15.4" WXGA LED backlight touchscreen upgrade
            *Custom fiberglass dash bezel
              Thanks mate, I'm absolutely loving it! You won't recognise it soon though, I'm going to get the screen out, fix up the scratches and repaint it the same gloss black I am painting the vents, ashtray and centre console strip. Not a great photo, but here's the idea:
                hey man the install looks good! nice work!
                  Hi mate, very nice install there! How did you go about hooking up the radio shark to your antenna? Does it have AM?
                    I haven't gotten around to doing it yet, I need to get the dash out and hook up a switch to raise and lower the electric antenna before I can get it working.
                      i always thought the antenna just sensors a current and raises by itself. All you need to do is get the right adapters to connect to it. But i might be wrong.
                        There is a wire on the stereo harness that triggers the antenna. It's currently hanging inside the dash doing nothing. Will figure something out when I remove the display for repair/repainting.
                          The Evoscan arrived today, and I have just given it a shot, and, well, I don't think I have it configured right.
                          Installed the software on my PC, plugged it in and the interior lights start flickering. I started the car, and the flickering stopped (WTF?) and hit the connect button. The software connected, and bringing up one of the default dashboards showed the rev counter showing the correct RPM (updating several times a second by the looks of it).
                          Main problem no is with the cable connected, the park and neutral lights flash on the dash, as does the TCL off light.
                          Any thoughts? Might stick a post in the OBD forum...
                            Very nice install. Also interested in the radio aspect. Keen to find out how the reception is when it is connected to the Car antenna.
                              So am I
                              Hasn't been much of a priority to be honest, but will get to it eventually. The next thing that will get my attention is the OBD-II stuff.
