Mazda6 2006 carpc installed
  • Mazda6 2006 carpc installed
    Well finally I decide to post my car pc project.
    The project was finished in March ,but now i am ready to present.
    So the configuration is the following
    -Motherboard: JetWay J7F5M2G-VHE Mini-ITX Board
    -Power Supply: DC-DC 12 volt PCU M2-ATX 160watt
    -Case: Mini-ITX for CarPC VoomPC
    -RAM: DDR2-533 ,1GB Kingston
    -HDD : Western Digital 2,5" sata ,120GB
    -DvD : DVD-,+ RW NEC slim slot in.
    -Card reader: Equip Multi cardreader+USB+Firewire 3,5"
    -Mouse: Touchpad micro external PS2
    -OS: Windows Xp Media Center
    -Carputer Software: Centrafuse 1.47
    -GPS ANTENNA : Navilock
    -GPS software : Destinator 7
    Selfmade projects
    -Install A DVDRW in original CD place
    -Install multi card reader in face of main sound unit
    -Install touchpad mouse in cup holder.
    Bellow there some pics from all operation. Enjoy!!!!!
    ok good now i am make same thing in my car add car pc and have same ur mazda monitor
    my Question ?
    i have same noise or vibrartion in monitor screen ,,do u have same or u have clear screen at drive ????
      Yes I had the same problem ,but I fix it with a better quality of vga cable.
      Also make sure that the GROUND cable from monitor ,is grounding corectly to metal case of the car.
        thnx Mr,mazdakias_gr
          Nice install!
          How do you like the Jetway? I have read so may negatives that I didn't even consider ordering one. Does it have heat problems? What bootup times are you getting?
          "Imagination is more important than knowledge." -AE
            No problem with Jetway mobo.I think that is very reliable ,if you consider the enviroment that is works.
            I never see the temp.above 47 celsius in summer.I think it is very good mobo.No problem with heating.
            I already install a second fan in the front of the case ,so in this way I have better air-flow.
            About bootup ,the timing is between 13-18 sec.
              wow gj on the install! Very clean! Where did you get that mediacard reader?
                The multi card reader is made from Equip.
                See this
                http://www.equip-info.net/english/in...um=2&prod=1586
                  hey dude nice setup, i never found the right touchpad mouse to use in my car. where did you get yours from? or what brand/model is yours. link?
                    The touchpad I buy it from here http://itw-gmbh.com/
                      my friend
                      Question 1)
                      at start pc my monitor not show the boot at start only at it display at start windows screen loading (not display dois and boot screen ) why and i test pc in my home with pc monitor all thing is display start boot 2 windows just with mazda 6 monitor nit show start screen why ?? do u thing any problem ?
                      Question 2)
                      what is reslution for mazda 6 monitor and what is better screen system used 2 pc (PAL - NTC)
                        well....I have the same "problem" .(In true it is not problem).
                        But I think something going on with resolution.
                        If I remember correct ,I use the monitor with 640x480 res.
                        Let me check in the afternoon the resolution and the screen system that I work with monitor and I will tell you later.
                          ok waiting
                          hope good job 4 u
                            so....i checked and the res. that I have is 800x600
                            About the problem for bootup menu ,that don't appears ,I must contact tomorrow with some technician.
                            I will keep you informed.
                              thnx my friend
