1993 Mitsubishi Verada KR
  • 1993 Mitsubishi Verada KR
    Hi Everyone,
    These are my first and second attempts at a carputer i hope you like my thread and thank you for taking your time to see my work, there are going to be pleanty of enhancements in the future like Frets on fire(guitar hero simulator), rear dvd screens, etc.
    Here is a list of the parts i used in the first version of my carputer
    Parts Used for CarPC V1:
    DELL Optimax(Optiplex or something like that)
    P3 1.3ghz
    512mb SDRam
    10GB internal HDD
    Internal Wifi
    USB 5.1 Sound Card
    7" touch screen(purchased on ebay)
    TinyXP
    RR
    latest version of winamp
    M2-ATX
    Parts Used for CarPC V2:
    VOOM 2 PC Case
    Intel Atom D945GCLF
    P4 1.6ghz
    1G DDR Ram
    20GB 2.5" HDD
    160GB 2.5' ecternal HDD
    3G 4 port router with WiFi
    USB 3G internet stick with 2g download limit
    USB 5.1 Sound Card
    USB GPS module With FreeDrive Software
    7" touch screen
    TinyXP
    RR
    M2-ATX with P4 cable
    Existing Car Audio :
    BOSS splits
    Sony 6x9's fitted on rear dash
    12" Sony Sub
    2 channel cadence Amp for Sub
    4 channel sony amp for speakers
    In order to fit the carputer screen i had to remove the existing stereo from the car, there was only enough space in the dash for a 7" screen without to much modification here are some photos of the removal of the old HU and me fitting the screen in place
    Click image for larger version
    here are all my cables hanging from the hole
    i used the headrest fitting so i would have easy access to take the screen out when i needed to, so far it works great.
    For my first attempt i used an old dell i had lying around, it was slow and it was big so i tried to cut down as much of the exterior as possible
    this is what the case looks like when it had its dell cover taken off it
    and this is what it looks like in the boot, it took up way to much room for my liking and and combined with the sub it was just to much
    I ran this setup for a few months and it finally failed when the bios battery ran out, i couldnt be bothered trying to replace it so i decided an upgrade was in hand, i ordered all the new parts of either ebay or through the mp3car store luckily all this happened when the us dollar was so low so i snagged quite a few bargains ordering parts from the states
    here are some new pics of the second car pc
    The Fantastic looking VOOM 2 PC case
    it works much faster and has great hibernation times it takes about 10 seconds for it to resume and about 5 seconds to go into hibernation
    here are a few more pics just to fill out the collection
    this is where i chose to put my WiFi anteanna and GPS module
    This is my volt meter and my misile cover style switches for resetting the computer if necessary
    The Final Product looks a bit better in this picture
    My Ride
    OMFG, I love how fuking simple your screen was. You basically used a headrest version and stuck the shroud in the gap of you original bezel. Genius!!!!! I wish mine was that simple!
    1X Ainol Novo Flame Tab
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1X 7 inch motorized Screen
    1x Win 7 PC
      I originaly wanted to have 2 metres of cables behind the screen so I could take it out and use obd for engine diagnostics whilst working on the engine, but I don't mind how it looks with the surround kinda suits the car
      My Ride
        It took me a few days but i got karaoke working i used UltraStar a singstar style program and i used the mics that came with my copies of guitar hero: wt and Rockband, there both logitec microphones i have them running off a powered usb hub in the back of the car,
        This is UltraStar the only down fall of this program is that it requires the keyboard to navigate the menu
        This is my car
        next up guitar hero emulator
        My Ride
          whats that monitor that you used? where'd you purchase it?
            I think this is what he has, if not, its very close.... http://www.cartft.com/catalog/il/442
            4X MK808b
            3x Perixx Touchpads
            3x 7 inch Screens
            1x Win 7 PC
              I got it from ebay seller bbillion works great haven't had an issue yet
              My Ride
                This one here is the exact one that i got fairly cheap
                sorry for the late reply i havent been home in a week
                http://cgi.ebay.com.au/Headrest-7-VG...3286.m20.l1116
                My Ride
                  thanks koolmoedee
                    Hi,
                    I have the same screen, what screen resolution are you using? I want use native 800x480, but theb best I could was 800x600.
                    Mauricio
                      i thinl im running 800 x 640 but ill have to chech im on holidays at the moment so i dont have access to my car but i will post when i return with what resolution i can achieve.
                      i know you can get a higher res out of the screen but i dont know how good it is
                      My Ride
                        Hey Koolmoedee,
                        Do you know if the 93' Verada Ei KR, has an OBD-II Connector or a OBD connector?
                          Man your screen looks absolutely fantastic! It's a perfect fit, looks stock and has that minimalistic appearance about it. I'm surprised at how simple it was. Then again, these older cars didn't have fancy dashboards and centre consoles. Great job mate!
                          How are you resuming from hibernation in 10 seconds? My system takes at least 20.
                          2007 Camry Altise In-dash Car PC
                            thanks for the props i'm still running the same system to date with no troubles at all
                            i have no idea what causes the fast resume but its always ready when i need it
                            Originally posted by afroboy2000
                            Hey Koolmoedee,
                            i never looked much into this after i got the system in but as far as i have explored it doesn't and i've pulled the entire interior out
                            My Ride
                              Nice work dude, I'm going to my putting my carpc in soon (in my 00 TH Magna) very soon
                              Oh, and yes it has an ODB plug, its somewhere under the dash. Theres a guy in in WA thats been playing around with the OBD plug on his TR doing some cool stuff
                              2000 Mitsubishi Magna TH Executive 3.0L V6 Auto
                              Lilliput EBY701, Celeron 1.4ghz, 1GB DDR2, Windows 7 Pro, Centrafuse Auto 3
