2008 Mitsubishi Lancer DE
  • 2008 Mitsubishi Lancer DE
    So i'm almost done with my carPC and i'm really happy with the way it turned out.Here's some pics and specs are:
    Abit NF7-S (Nforce2)
    1 GB DDR 400 MHz
    AMD Athlon 2400+
    VGA GeForce 4 Ti4200 (AGP 8X)
    400 W Power Supply
    300 W inverter with USB power
    Pyle 4 channel amp
    Sony Xplod sub (this needs to be replaced)
    Factory speakers
    7" Screen
    GPS Navilock
    FE:Centrafuse
    Slimline Samsung DVD-RW
    4 port USB hub
    Here's some pictures :
    DVD drive and USB hub in the glove compartment
    My master switches (left one controll the neons outside the car and the right one turns on the inverter).The neon controll has 3 positions.One is always ON,second is OFF and third is fade in and out when door opens,closes.
    Here's Dejan's plugin up and working...Congrats on the plugin it works like a charm.
    Centrafuse navigation up and running with all Croatia maps loaded.
    Visulation running
    Custom controlls in the center console (need to color match it to the console color). These controll volume,song,visulation and mouse movement
    Sub box w/ PC installed.Left half is the subwoofer enclosure and the right is where the PC is mounted.I still need to wrap it. The upper half of the box can be unscrewed for service.
    Here's the controlls at night (the blue one changes function between mouse movement and volume,song commands)
    And here's the dash view.Had to install a V-meter so i know my bat status.It's temorarily installed here,but it will go in the a-pillar once i get all the other gauges.
    Hope you like it...Cheers
    P.S. Sorry for crappy phone camera photos..
    Looks pretty good.
    What did you use for the custom controls in the center console?
    I'm looking for some nice buttons to use in my setup.
    Thanks, Dean
      buttons are called "anti theft buttons" with LED lights in it.
      They're 8$ a piece, i'm gonna post some better pics tomorow.
        I am going to get a new Lancer. Did you buy the center console section with the navi cutout in it?
          Ditto!
          My lancer (09 SE) looks like this:
          Does that resemble your factory dash at all?
          Just curious, where did you put your CPU?
          Also, did the place that you put your switches look like this originally?:
          It looks great, way to go!
            I wonder if he still come around cause I have the same question. I have the same dash as you and I would like to see where he got his.
              i'm back
              Sorry for not replying to your posts...i've been waaaaaay to busy...
              anyways...dash kit is not factory it's made by schorsche (i think it's spelled like that xD)
              LCD in the bezel was attached to the dash kit with custom brackets.
              PC was mounted in the trunk.
              if you have any questions feel free to email me at [email protected]
                i am also curious in this.
                next project? subaru brz
                carpc undecided
                  I am curious in this too.
                  Audio
                  Front / Rear RE Audio RE6.5C + RE Audio DTS-500.4
                  Sub RE Audio SEX10D4 + RE Audio DTS-1500.1
                  Carputer
                  MOCOSO Case + MiniTouch DD + Asrock E350M1
