Audi A6 C5
  • Audi A6 C5
    I finally got around to doing it, it's still a W.I.P., but who's isn't? lol
    Parts list
    Intel D945GCLF2 Atom 330 Mini ITX Motherboard/CPU
    2GB of RAM
    16GB Solid State Disk for Windows (Running TinyXP 09 w/ MinLogin)
    320GB WD Scorpio Laptop Disk for media and maps (Built in ShockGuard tech)
    TrendNET USB Bluetooth dongle
    Pinnacle HDTV USB TV Tuner (with FM Radio and DVR functionality)
    BU-353 GPS Reciever
    LinkSys a/b/g USB WiFi dongle
    Dynamix 710 Touchscreen LCD (UltraBright)
    M2-ATX-HV PSU
    Metra Dbl Din Mount Kit
    Metra Wire Harness for Symphony Systems
    SoundMax Stereo MIC
    Morex 5677 Mini-ITX Case
    I took the Metra Double DIN Mounting kit and decided to mount the Headrest kit that came with the Dynamix monitor.
    I added a USB port as well, but after a test fit, I sadly had to remove it (Just didn't fit in the Audi dash)
    I also drilled 2 pilot holes for the SoundMax MIC
    Here the MICs are added and flushed up, some bondo, and alil glaze, and some sanding.
    Out in the sun to dry after a couple coats of flat black.
    Kinda a crappy pic, but she's inside and dry =)
    I ended up getting both the 320GB spinning disk and 16gb SSD mounted inside the case, the WiFi adapter and BlueTooth dongle wired inside.
    The TV/FM Tuner sits external as it doesn't work with CentraFuse so I use the Tuners remote to launch, control and close it's own TV / DVR application
    Ready to install
    The screen doesn't sit as far into the dash as I would like it, stock was about an inch back.
    I'm still working on the CentraFuse skin I made for my A6, but most of it is done
    And the baby she sits in
    I still have to mount the PC under the dash and put the dash back in, I'm debating the FusionBrain so I can use the Steering wheel controls. But so far I love it!
    Can any one recommend a good noise filter? I have the BOSE sound system in my car, and the amps are picking up horrible engine noise and alil from the PC
    Looking good. A radio shack ground loop isolator helped my noise.
    2007 Mini Cooper eee PC worklog
      I was looking at these from Crutchfield
      http://www.crutchfield.com/p_003S15A...t.html?tp=2653
      In-Line Power Ground Loop Isolator
      and
      http://www.crutchfield.com/p_127SNI1...1.html?tp=2653
      In-Line RCA Ground Loop Isolator.
      I was debating, should I get the Power Conditioner, or the RCA one? or get both?
      If I get the RCA one, I'll have to buy 2 as I have 4 sets of RCAs (fronts and rears) hooked up to my factor sound system.
      Opinions? Would both the power and RCA isolators be over kill? will I get back performance from one over the other?
      Thank you
        Nice!
        "Live Free!!!...It's all about Open Source"
        Recent Proj
        Old Proj II
        Old Proj I
        YouTube:Project Videos
        Homepage: HexxWorld.net
        Twitter:http://twitter.com/hexxamillion
