Car-PC install, Toyota Carina E, OEM look
  • Car-PC install, Toyota Carina E, OEM look
    Hi guys.
    Just updated my previous install containing a 7" touchscreen, to a new centerconsole based on a 8" 16:9 touchscreen.
    The buttons in the screen has been kept, as they will be hooked up to the car-pc, to control this...
    Hope you like the work....
    Nice Install
    You did a very nice job, especially with the plastic soldering. What filler did you end up using by the way?
    -SwiftDeath
      Thank you very much for the comment.
      Is it the spray-filler you're asking to? I have used "Motip primer"...Though it is called primer it is spray-filler.
      I have tried a lot of different types. This is the best I found.
        Fast Response
        Thanks for the response. It's always good to know what products are out there and what results they can achieve. Enjoy your new setup, I know I would.
        -SwiftDeath
          very nice fabrication, certainly an oem look.
          dsatx in voompc 2 case <HERE>
            Congrats ! Neat Install ! Happy carputing.
              Very nicely done! Definitely looks OEM.
              AMD XP 2600+/512MB RAM/120GB hard drive
              Opus 150W/DVD/GPS/7" Lilliput TS/802.11g/Bluetooth
              Installed.
              -GPSSecure- - GPS Tracking
              -AltTabber2.2.2- - Handy touchscreen utility.
                Thank you for your comments.
                Actually this is only a temporary solution, as my goal is to have 3x this screen integrated in the center dash, controlling each a car-pc.
                It just takes some time to realize, so in the meantime I'm using this setup.
                  Nicely Done
                  What did you do to glue the bezel and console together?
                  I'm thinking of doing something similar sometime soon with my Toyota Highlander, so any info would be a great help
                    jpntaka: It has been melted together, using a soldering iron (as you can see on the pictures).
                    I you want to glue it together you can use PVC glue, which will also melt ABS/PVD plastic types...
                      Perfect!
