2003 F150, First time installer
This topic is closed.
  • 2003 F150, First time installer
    Let me know what you think.
    Looks good man, what are the system's specs? (m/b, cpu, hd, ect...)
    2005 Silverado - Atom 330 D945GCLF2 - 160GB Hitachi 2.5" HD - 150W Opus PSU - Lilliput 629GL
      my specs
      Specifications:
      Case - Extruded Anodized Aluminum measuring 10" x 9.25" x 3.125"/254mm x 235mm x 80mm more info
      Processor - ATOM 330 1.6GHz Dual Core 8 Watt CPU with 1Mb L2 cache 533MHz FSB
      Graphics - Intel GMA 950
      Chipsets - Intel 945GC Northbridge
      ICH7 South bridge
      Audio - Realtek ALC662 High Definition audio codec + Composite/RCA Line Outputs
      USB 6x USB 2.0
      LAN 1x 10/100/1000 Mbps
      BIOS Intel BIOS 4mb flash memory
      Rear Panel I/O 2x Ps2 for mouse and keyboard
      1x VGA
      1x 7 pin S-Video
      1x 10/100/1000 LAN
      1x RS 232 COM
      1x Parallel Port
      6x USB 2.0 ports
      3x Audio: Line in, Line out, and Mic in
      Monitoring and Management Power Management (Supports S3 standby)
      Fan Speed Control
      Memory/RAM 2Gb PC5300/667MHz
      250 gig mobile hard drive
      M2-ATX Smart Power Supply: Connects directly to the battery,
      Voltage regulation,
      Automatic Start-up more info
      Built-in Bluetooth-Exclusive Feature Internal V1.1/1.2 Vista Compatible
      50m/150' Range
      Works with Centrafuse 2.0
      Also Included 6 pin locking power harness
      users guide and wiring diagram
      master driver disk
      detailed system build sheet
      LCD monitor power cable
        my monitor
        i also have
        EBY701 7" touch screen
        1 JL audio 12
        2 kicker amps ans a micro farad capacitor
          Well... this looks like absolute garbage.
          Clean that edge up and make it look professional before you start bad-mouthing other people's installs. Yours isn't all that great yet. I actually see zero fabrication work in your ride... all you did was cut holes and mount stuff. And a pre-built unit? With the amount of trash talking you've been doing on the forum, I was expecting an awesome custom install. This is nothing more than buying the parts ready to go and just installing them. Bravo for installing a turn-key solution.
          Tidder
          Try RevFE
            How did I miss this thread? Basing your install on the comments you made in our posts, I agree with Tidder. You didn't even mold the screen into your dash, you simply cut a hole in your dash like a kindergartner and smushed the screen behind it. When I found this thread, I was expecting some super well done setup that blew mine away. Its really nothing spectacular, if I had to rate it, I'd say its a 4, and not because of the PC system, but because of the audio thats simple enough to do.
            1X Ainol Novo Flame Tab
            4X MK808b
            3x Perixx Touchpads
            3x 7 inch Screens
            1X 7 inch motorized Screen
            1x Win 7 PC
              I will say this, it looks ... nice. If this is all you were looking for then you have done well. And that is fine. Not everyone does this as a hobby. No biggie. But you really should watch what you say about others' projects since they are working on things waaaay beyond what you seem to be capable/willing to attempt.
              All you need right now is some plastic putty, hard work, and patience and you can mold your screen into your dash bezel. It will also help rebuild your reputation with the senior enthusiasts here. There should be some great information in the Fabrication forum.
                wow, and to think you badmouthed the vanputer, i say his install was way better than yours. he at least took some time and creativity in his project.
                - Project: Unified Car Control
                - Original OpenMobile Interface Designer
                  I agree with you 100%.
                  4X MK808b
                  3x Perixx Touchpads
                  3x 7 inch Screens
                  1x Win 7 PC
                    Shouldn't this be in worklogs rather than finished projects? It looks like a decent start installing a prebuilt system, but you have a good amount of work to go. You really should do some fabrication rather than just cut and pasting (literally) the components. By the way... way to play a ripped movie. Go pay for your media
                    RevFE
                    My Shop
