Mitsubishi lancer 9 Car PC
  • Mitsubishi lancer 9 Car PC
    Hello..
    want to show several pictures of my Lancer 9 carpc.
    I have carpc in my car arround half of year.
    My old motoryzed lilliput GL701 - is not so good idea for carpc and I've decide to rebuild HVAC panel.
    Before:
    first step:
    I have use lilliput 619GL for project.
    Result:
    Awesome setup, I really need to learn how to fabricate things.
    My Nearly Complete Car:
    http://www.mp3car.com/vbulletin/show...ed-car-pc.html
    Micro Control Center... Control Your Car Across the Internet
    http://www.mp3car.com/fusion-brain/1...-internet.html
    Website: (It's a work in progress, really. All my projects have taken me from ever really developing it.)
    http://paulfurtado.com/
      Wow, great fabrication by the way. Nice work, looks great.
      // 2008.5 CWP MAZDASPEED 3
      // mp3car showoff thread
      // appearance & performance mods
      // computer setup
        same here
        looks way better than the before pics
          I can't see your pictures
          I have a question, I have an 8 and I fitted my PC in the boot, where did you take your ground from, mine is of the rear seat mount at the moment, but I have a very noisy ground in the car that seems to keep rebooting the PC, sounds as if your solved the problem if only I could see how you did it
          cheers
          Andy
            cheers
            Andy
            maybe something wrong then you try to see pics. pls try again.
            I've power my pc and monitor directly from battery with separately wires (+ and -). -It is main rule in instalation.
            I've use only ACC from car in my project for switch on of pc and monitor.
            Sorry for my english.
            I've fight all noises.
            Pls see picture:
              Sorry for my comments. it's on russian. I will translate it ASAP.
              системник собрал из корпуса десктопа.... инструменты - ножницы по металу и заклепник...
              уж очень хотелось полноценный ПК микро-АТХ, а не mini-ITX...
              Конфигурация: CoreDuo 2.2Ghz, 1Gb RAM, 160Gb HDD, мать - micto ATX, БП M2-ATX, bluetooth, GPS-BU-353, Wi-Fi, GPRS/EDGE internet modem, WinXP SP3, Centrafuse, iGO8.
              Звук подключил через AUX- магнитолы Пионеер. Играет отлично...
              На панельке снизу разместились кнопки RESET, дополнительная кнопка отключения подачи ACC на БП (если я не хочу чтоб комп включился), индикаторы-светодиоды Power и HDD.
              Сразу после установки появились наводки-трески от работы винта и вой генератора в динамиках....
              Пришлось перечитать кучу тем на этом и соседнем форуме... вобщем помогли все решить рекомендации от Chip c compcar.ru (кста все рекомендации от него только по делу...удивляюсь его познаниям в этой и смежной областях и как ему на все время хватает..)))))
              Проблема решилась применеием в цепи питания кондера в 100000мкф и ферритового кольца, выдернутого с згоревшего атх-го БП.
              Кабеля проложил правильно с соблюдением тех же рекомендаций.
                размещаем ЖПС приемник и ЖПРС - модем для инета.... ксатити скорость загрузки порадовала...
                и сама навигация - классная вещь.... не сколько доверяюсь ей, сколько помогает узнать по какой улице сейчас едешь (не нужно искать таблички)
                как не крути, а тачскрин не заменит клавиатуру в определенных ситуациях... посему была приобретена такая вот с трекболом...
                скажу честно- держал в руках и меньшие по размеру, но по эргономичности и удобству пользования - эта лучшая. ну и место в салоне я для нее определил слева сидения...там она отлично помещается....
                Под камеру заднего вида вырезал отверстие в крышке багажника...(как выяснилось потом - зря. есть камеры получше и с креплением попроще).
                Камера уже вторая. первая разбита была. у второй недоволен цветопередачей и вообще качеством... буду менять...
                Хочу вот такую:
                Для установки нужно просверлить лишь одно оверстие диаметром 6мм .... ну и надежность крепления у камеры нормальная (от пионеров) - прилегает плотно и смотрится как штатная...
                также установил маршрутную камеру
                но тоже буду менять..как оказалась она чернобелая, что не очень поможет в случае чего....
                Поставлю такую:
                она цветная, и с опцией отключения зеркального отображения.
                только стала делема чем видеозахват делать...
                сначала поставил отдельную DVR PCI карту. причем не дешевую - 240у.е. такие применяются в видеонаблюдении и можно подключить 4 камеры. она не загружает проц и обрабатывает видео сама...особенно хорош в ней софт - с большим количеством опций тонкой настройки.... но вылезло одно НО - софт запускается лишь с минимальным разрешением выше 900 (точно не помню), что не применимо с моими 800*600....
                буду что то думать..
                  hi thanks for the quick reply, so just to clarify you have run a new ground wire from the battery? and the put a capacitor across the + and - to smooth it out?
                  I can only see the image in your last post and not the ones in the original one though still. are they hosted somewhere else?
                  Andy
                    Great job on the monitor housing.....what is the blue stuff you formed the shape of the housing with?
                    "A rose by any other name is still a flower"
                      Andy
                      my english is not so good, but I try to explain you.
                      right. I have run new wires from battery. both +(pos) and Ground. It is hightly recommended.
                      All components in your system (carpc case, monitor, amplifier, radio-reciever) should be grounded in one point on body of car.
                      Capacitor and throttle is a power filter and must be located in carpc case before you power your PSU (you can find how it's made in any stand alone lilliput monitor package).
                      You can made the throttle by yourself.
                      Ferrite ring you will found in unworking ATX PSU for desktop.
                      Pls see my previous pictures.
                      Capacitor must be 25V 10000 mkF min.
                      You can find same pictures here
                        see this pic
                          it's two component epoxy resin. looks like plasticine.
                          I dont know who made it. My friend give me some quantity.
                            I really like the backup camera setup you have. Nicely done!
                              hi argafy
                              for some reason I can't see either the pictures on this site or the ones on your other one i just get broken links
                              Andy
