1981-1993 Dodge custom crew-cab truck
  • 1981-1993 Dodge custom crew-cab truck
    I finally have this system installed and operational. I'm still chasing a few minor hardware issues and the software has a long way to go, but I decided it's time to show it off to whoever might be interested...
    Truck:
    -1981 Dodge crew-cab pickup. Featured in the Nov.2006 issue of Custom Classic Trucks magazine. Click here for the web version of the article.
    Computer:
    -Intel D945GCLF mobo w/ 1G memory
    -M2-ATX PSU
    -OCZ Solid Series 30G SSD
    -Xenarc 700TSV monitor (2008 model)
    -Panasonic CW-8124 slot-load DVD-CDRW w/ USB enclosure
    -Garmin GPS-18x 5hz receiver
    -4 port USB hub behind glove box
    -4 port USB hub in dash (only 3 open)
    Sound system:
    -Visteon HD radio tuner
    -Vibe XE3 crossover/equalizer
    -Alpine MRP F250 4 channel amp
    -4) Polk Audio component speakers
    -Jensen 120W 2 channel amp
    -2) 6 1/2" Bazooka sub-woofer tubes
    Software:
    -Windows 7 Professional w/ no tweaks
    -RideRunner w/ my own skin
    -Garmin MobilePC
    Project completed! (almost)
    My Truck as featured in Custom Classic Trucks magazine.
    The truck...
      The computer is mounted behind the right rear seat. This pic was taken before the seats were back in.
        Here it is with the seat installed (flipped down) and the cover installed on the computer..
          The monitor is mounted where the HVAC controls were, so I moved those the where the ashtray used to be.
            The DVD-CDRW drive, crossover/equalizer, and USB hub replaced the factory radio..
              Here's a rear view of that combo...
                Here's a shot of the instrument cluster. The trim around the gauges is a piece of aluminum I had cut at work with a lazer cutter..
                  Behind the left rear seat is the receiver for the shaved door handle solenoids and fuses and relays for all the electronics that I added to the interior.
                    It also has a cover...
                      The HD tuner is under the front passenger seat and the amps are under the rear seats, but I don't have any pics of those.
                      Future plans are to replace the HVAC controls with a Fusion Brain setup. I also want to hook up the headlight switch and dash light dimmer to the FB and then control the gamma/brightness of the monitor automatically with the lights.
                      Thanks for looking!
                        Your truck arouses me, sir.
                          Modern vintage - FANTASTIC! Better than from factory - NICE!
                          For the future you may think about molding-in the monitor sorta like this (mine) 1981 F-100.
                          OLD SYSTEM (DEAD)
                          Intel D945GCLF2 Dual Core ATOM
                          Lilliput 7" 629GL 2008 LED Backlight
                          BU-353 USB GPS Receiver / iGuidance / IGO8
                          M2-ATX Power Supply
                          RideRunner Front End / Various Skins
                          Windows XP SP3
                            That looks really good! I was kinda stuck with the hole that was left after I removed the HVAC controls and the cheesy Dodge "message center" that was there. Plus I was in a hurry to get it finished before Chryslers at Carlisle car show. I have another cluster bezel I can play with, though...
                              Don't know if I would have mounted a PC directly above a Bass Tube but I'm certain the Bass would shake it no matter where you mounted it. :P
                              That is a very clean and professional looking install too. I like the metal enclosures for the PC and corssovers / relays above the Bass tubes.
                              Very nicely done.
