2004 Jaguar X-Type - Windows 7 and Acer Aspire1 8.9" Netbook as a Donor
  • 2004 Jaguar X-Type - Windows 7 and Acer Aspire1 8.9" Netbook as a Donor
    It took a little than expected, but here it is.
    My list of components:
    1. Metra Double DIN Dash Kit
    2. Acer Aspire One netbook
    3. Touchscreen kit
    4 .USB powered hub
    5. USB 6-Channel audio card
    6. USB VGA converter
    7. USB Bluetooth
    8. 3 x phono-to-AV adapters
    9. 5 channel amplifier
    10. Slot load USB DVD
    11. Headrest monitors
    12. PCMCIA Wireless Hub
    13. 12v-to-5v DC converters
    14. USB GPS Module
    15. USB squid hub (mini and full USB ports in ash tray)
    16. Zune HD (in case I want radio besides HD Internet streaming)
    17. Free Microsoft Origami Experience 2.0 front end for media, calendar, Outlook integration and free Krento application launcher
    I used the netbook's 8.9 screen (which fits almost perfectly behind a modified Metra double DIN X-Type kit) and I had to put a momentary soldered from the motherboard next to the screen to suspend and resume Windows.
    The only thing that make this usable is the Origami frontend. I tried a bunch of others, but I like this one from the UI perspective and it has the functionality I need.
    Here are some pics of the install, Origami front end, headrests, slot DVD and router:
    And the car itself:
    Amazing car
    one of the best cars I have seen
      Oh damn! I always wanted a PC tablet on my car
        Did you adapt any of Jaguar's own touch screen head unit for this, or is it all scratch built?
          That looks excellent! I would believe it to be factory, were it not for the frontend's appearance. Out of curiousity, what was it that you liked so much better about this particular frontend over the others you tried; and in the same vein, what others did you try before deciding on this one?
          Again, it really looks excellent.
          Electronics work on magic smoke - don't let it out.
            No. I didn't use anything from Jaguar.
            The main thing for me is the Outlook email and calendar integration. The media player integration is also good. I have tried Streetdeck, RideRunner and Centrafuse. The fit and finish of the UI tends to look pretty amateurish - especially on the first two listed.
              So it's your own custom style isn't it?? cool..
                i noticed you had the zune media player, hows that working. I have a zune pass so i think itd be awesome to integrate that into my car.
                  It's nice, but the buttons/controls are too small for practical car use. Origami is a far better means of navigation and volume control. And it consumes WMP playlists, streaming radio settings, etc.
                    Origami
                    Where/how did you get MS Origami? I'd love to do something like this...
                    -Smith
                    Car: 2009 Dodge Challenger R/T - No extras
                    PC: None yet. Still planning. On a budget. Open to suggestions...
                      http://www.microsoft.com/windows/pro...c/default.mspx
                      FIRST LINK.
                        Right, tried that earlier, but how do you get it to work with Win 7? I get errors stating that my OS is not Vista even after changing compatibility properties. I've been picking through the net trying to find a version that works with Win 7. The reason I want to use Win 7 is because I can strip out the stuff I don't need. (http://lifehacker.com/5164286/window...explorer-kinda) Just wanted to know how you got it to work.
                        -Smith
                          It installs fine on Win7. I just tested it on a second machine. No compatibility modes, shims, transforms, etc. needed.
                            Humm... I'm running Win 7 Professional x64. Got it to work on my wife's 32 bit vista. Is your ver of Win 7 32 or 64 bit?
                            -Smith
                              Hmm. Mine is x86, but WOW64 should still allow it to be installed as with any other 32-bit app. If there are hard-coded paths with the Office integration and driver ties with the touchscreen(and most UMPCs are going to be x86 for a while), I could see the rationale blocking the installer at a architecture check. You could probably apply a transform to the MSI to work around the architecture check.
                              Why are you running 64bit for a car PC anyway? The cheaper USB devices you'll tend to need typically don't have signed drivers for 64 bit.
