2007 fx35 carputer by xy99
  • 2007 fx35 carputer by xy99
    Hey guys been lurking for over a year now learning and gathering information and took the jump in my 2000 nissan maxima...i installed the car pc in december of 2009 but i traded my baby in at the end of january 2010 and got my new love 2007 fx35 fully loaded..and i luv it except it didnt have a carputer ...saw the turbocad thread and talk about inspiraton...I took the carpc from the maxima and put it in the fx for notes....
    The Guts
    Jetway JC-114 Black Mini-ITX Enclosure
    Intel Desktop DG45FC w/Intel Pentium Dual-Core Desktop Processor E5200 2.5 ghz
    2 gig Ram
    Panasonic UJ-875A Slim Slot load DVD±R/±RW/+RDL/RAM Multi Drive w/ SATA & Power
    BU-353 Weather-proof GPS Receiver
    ElmScan 5 USB OBD-II by ScanTool
    Lilliput 629GL-70NP 7" VGA Touchscreen w/ Auto Back-up Camera Switch
    M4-ATX 250W Intelligent DC-DC PSU
    Nissan aux input adapter
    The Glory
    Ride Runner Front end
    w/ Teknik Skin modded for my liking....thank you valheru for all your help..
    SHout Out to both my cousins for all their help none of this would not of got done without their ideas and massive help..
    Pre War
    Me and my cousins have some experience with computers and carpentry and a vast knowledge of google searching...anyone interested in doing a project ...its time consuming and sometimes nerve wracking but with patience and persistence trust me its the best feeling of accomplishment.. with that being said let me start on the installation
    we modded the jet way box by removing the powersupply provided and replaced it with the bad@$$ M4 atx. we cut a hole out of the side of the jetway case and mounted the atx board there..
    next we had to remove the casing for the lilliput and re sotter the ir sensor for it..
    The BATTLE
    First thing we did was supplied the power by running it through the firewall of the fx35 alongside all the other wires and brought the cable down through the glove box and then under the center console to the driver side seat. then we went to work at the dash..we took the oem naviscreen out and replaced it with the lilliput we used a nissan plastic casing that we bought online somewhere and it fit nicely into the two brackets that held the oem screen. i didnt put anything to mount it to the brackets because the dash goes over it and it doesnt budge...while were dong all this we wired the aux input to the back of the headunit...we rerouted the wire for the stock wiring for the navigation down to where the ashtray and clock assembly is..i used the wiring for the cig lighter as the acc for the computer and monitor above...we then took out the ashtray assembly and used a dremel tool to cut the hole by the ashtray to the size of the oem navigation screen..once this was done we then used bondo to secure the screen to the assembly...then we sanded and panted it...after a month or so i was not satisfied with the look so i purchased the 3m di noc carbon fiber vynl graphite and covered the clock assbly with stock screen and the gear shift center console..
    here we layed a piece of plywood to mount the motherboard
    we cut out a hole for the power connectors of the m4 to stick out
    heres the motherboard screwed in to the plywood
    we cut a hole for a top mount fan and installed it for extra cooling
    heres everything put in with the top off
    bench testing with the liliput
    the stock screen replaced the ashtray ..bondo has not been applied yet
    bondo has been applied around screen and primered
    here is the screen with the bondo painted black...was not happy with it so decided to add vynl
    screen with 3m di noc vynl
    no vynl
    with vynl
    heres the finished product
    front finished with vynl and installed
    And now the RipplingHurst method of covering it up...thanks for the idea
    Heres me cutting the Drivers side ac vent
    and another one..
    now you see it now you dont...
    idea here was use a wood block and the diffuser plate on top of it...i wanted to be able to take the computer out easily if i needed to tinker with it so i attached the wood block on with hinges...
    heres the piece attached with ac vent and hinged down to take out computer....
    heres the completed project...
    and my ripplinghurst impression
    and finally with the mat in place
    still to come... the tecknik modded skin
    2007 Fx35 Carputer Installed
    Riderunner with Teknik skin
    Great news, another FX install! I used my overhead console for the Xenarc 700TSV, and left my stock screen where it was. I may try to swap them, but after I get a transflective. I fear the stock screen position is going to give me too much glare. What is your experience there?
    If you're lurking for a while you probably already know about my install (see signature).
    So the jetway is under the driver's seat? Pictures? BTW, I'm also using the DG45FC, but with an E6550 and a DSATX in an external case made out of a HD cage (To protect it from passengers kicks, I also fit an metal screen).
    And more bigger pictures please! Good luck with your install.
    Worklogs: 08 Sequoia Platinum Carputer (In Progress!)
    Skin: MetroSex on the Beach preview
    07 Infiniti Fx35 (done!) & 06 Infiniti M35 (gone...)
      of course ive seen your install...how you place it under the seat is my goal..im still having trouble trying to fit everything underthere...ill put pictures up when i get it as good looking as yours...as for the sunlight it is kinda hard to see during the day i adjussted the day theme to be a bit better so its doable but ur right its not that great of visibility and at certain points cant see it at all.but i work 70 hours a week so i am moving early morning and late night..but this project is a work as i go so ill be thinking of ways to figure it out..if i figure anything out ill let you know for sure...
        You're right, it's a tight fit. I cut the carpet, folded part of it under the passenger space and removed some foam. I also had to shorten part of the A/C vents going for the passenger feet (it's still functional though). It's tight, but I still can go all the way back and low.
        Good luck!
          ohhhhh you cut the ac vent niceee idea..i will try that hopefully this weeknd if i get time thanks for the input..
            Cool, glad to help.
              added new pictures and organized them a little better
                updated pics 7/9/2010
                  LOL at the references! Thanks!
                  Good job so far, can't wait for the modded skin.
                  Cheers,
                  RH
