Scion xB 1stGen
  • Scion xB 1stGen
    xB Car PC
    Here is the progress of the CarPC for the xB.
    Parts List:
    M.B.- MSI Fuzzy 690T
    Processor - AMD Athlon 64 X2 5050e Brisbane 2.6GHz
    - 4GB OCZ DDR2 SO-DIMM DDR2 800 (PC2 6400)
    H.D. - 160GB 2.5" Hitachi SATA
    Sound Card - Creative USB Sound Blaster Audigy 2 NX
    Power Supply - M2-ATX 160W Intelligent DC-DC PSU
    GPS - GlobalSat BU-353 USB GPS Reciever
    Monitor - Lillput 2008 7'' Transflective LED Backlit Sunlight Readable Touchscreen Monitor
    NIC Card - Trendnet 802.11g Wireless USB 2.0 Adapter
    Case - Black Winsis Mini-ITX
    DVD Drive - SAMSUNG Slot-Load Slim External DVD Writer
    OS - Windows XP
    Front End - Streetdeck2
    HDRadio - HDZoom Visteon
    Bluetooth Adapter - Cirago BTA-3210 USB 2.0 Micro Bluetooth
    Car Audio
    Amp - Elemental Design Nine.4
    Fuse - 200A Tsunami
    Distribution Blocks - Tsunami
    Wiring - Elemental Design 4gauge
    Some pictures of the progress.
    Tsunami Components
    Some of the Elemental Designs Wiring
    Nine.4 Amp
    Test "vehicle"
    Testing the original setup I had used in the vehicle
    Sound Card, hooked up to the AMP
    GPS receiver chilling on the vice
    USB Wireless card....WORKS AWESOME!!
    Grand scheme of things
    Time to clean up the wiring
    Wiring cleaned up!
    Time to put it into the Case
    Testing everything with the case buttoned up!!
    Have since change this setup out in favor of the Winsys Case, MSI Motherboard, AMD X2 45W processor, and 4GB memory
    Testing the system out on one of my favorite sites!!
    Rewired All Speakers
    Test Fitting CarPc Under Seat
    Amp Wiring Cleaned up and routed
    Power Distribution Block Mounted
    and wired
    Fuse Mounted
    and wired
    Test Fitting Amp
    Jack and Jack Mount Removed
    Pc Wiring Cleaned up
    Some more updates....
    Switches Mounted
    Space between bottom 2 switches will have a led between them, for the pc
    Amp and Crossovers Wired, tomorrow will get it organized, and tidy
    Negative distribution block mounted and wired
      Carpet matches PERFECT!!!
      I cut the bottom of the touchscreen housing off to remote mount the buttons
      Early stages of molding in the screen, and so far coming out REALLY GOOD
      As you can see in the pictures cut the bottom off the screen that houses the buttons, then cut a notch in piece on the bezel to mount the buttons roughly perpendicular to the screen!
        Finished Product
          Very nice.
          '05 Magnum RT
          CarPC coming soon. Hopefully end of 2010.
          Parts left to buy-
          Monitor, Bybyte frame, Axxess hook up, Sheet metal for double din case.
            How long have you been working on this?
              nice job!!
              next project? subaru brz
              carpc undecided
                Have had a carPC in the xB now for the better part of 2 years, the current setup I have now I am really happy with,...right now though I am playing with new front ends particularly Road Runner/Ride Runner. Streetdeck has served its purpose but it seems development of any kind for it has pretty much vanished
                The total build/installation time was roughly month and a half
                  Couple more
                  USB ports I added...the one on the left currently has the Bluetooth adapter in it
                  With RR and the DFX4.0 skin
                  and with StreetDeck 2
