Beemer (BMW) E87 Carputer
  • Beemer (BMW) E87 Carputer
    Finished it a while ago but now it's time to share it too
    CarPC parts:
    Intel 510MO
    1Gb RAM
    160Gb 3.5« HDD (SSD - On hold)
    M2-ATX PSU
    7« Touchscreen with FlipUP (CID BMW)
    Andrea SuperBeam Microphone (Awaiting shipment)
    Ground Loop Isolator
    Rearview (backup cam) with EasyCAP
    PDC "CISBO SB323-4" with RobbyBMW PDC modul ( http://bit.ly/co7JA5 )
    Mini PCI-E WLAN+Bluetooth + Antenna
    NaviLock USB GPS SirfStar III
    ELM327 USB OBD-2 Scanner (Awaiting shipment)
    Software:
    Windows 7
    Centrafuse 3.1
    GarminMobile PC
    Preparation:
    Remove the original LCD & replace with it 7" touchscreen
    Since i didn't have a top storage dash i had to cut it with my dremel and make space for it
    Conected the CID FLIPUP with the radio so it flips on key contact
    flip -> radio
    pin 1 : terminal 30 (plus) -> Radio = pin 15 (red/green - thick cable)
    pin 3 : terminal 31 (minus) -> Radio = pin 12 (brown - thick cable)
    pin 5 : K_CAN High -> Radio = pin 11 (orange/green)
    pin 6 : K_CAN Low -> Radio = pin 9 (green)
    Motorized FLIPUP (CID)
    Old video using CF2.1
    GPS Hidden
    Center console with AUX,USB port (removed cigarette lighter)& SpaceNavigator
    Hub under the seat for GPS, OBD II, SpaceNavigator & Usb flashdrive
    PDC with CAM
    And here is the carputer
    Thats all folks! =)
    very nice... good job! špica :-))
      Very Nice Setup, from where did you get that USB plug ?
        Originally posted by Enforcer View Post
        Cool.
        Although a bare motherboard that close to the battery?
        No problems till now.. well i'll get a chasis for the psu&pc soon.
        I had a usb charger and ripped it apart (removed the unnecessary parts) and solder the usb cable to it
          Lugi, this is the absolute best install I've seen yet. I love the fact that all factory equipment remains in place and the PC tucks nicely under the floor. The SSD HD will definitely hasten the boot time. Could you supply more details about where you got the CID? This is exactly what I was looking for, amazing job.
            very very nice job.
            Do you have a bit of crop with the 7" going into the CID?
            Current:
            [BMW E46 ///M3 Convertible]
            Previous:
            [BMW E31 850CSi]|[BMW E39 535i]|[BMW HVAC Research]|[IBUS Scrolling Text]|[BMPuter]|[Velocity]|[TomTom]|[Vision]|[Space Navigator Driver]|[Super Fast Boot]
              Awesome!!! What monitor did you sue to replace the original CID monitor? Is this a direct fit?
                man one of the best cars I have seen. Please tell me where did you get the motorized LCD
                  CID (Flap Monitor) is from eBay(de) was around 150EUR including shipping
                  Well i did crop inside the CID but not the viewing side because i don't have any experiance with fiberglass so i have a 7" in a 6.5" frame, using a custom resolution for CF. Maybe it's time to found some fiberglass master =)
                    This job is very clean , and i like
                      What monitor did you use to replace the original one?
                        "NoName" 7" touchscreen
                          where did you get it? ebay? can you give the name of the seller?
                          I've already ordered BMW OEM monitor from Ebay so I need a replacement that is proven to fit
                          Many, many thanks in advance!!
                            Just ebay it...it's just a normal 7" touchscreen lcd..
                            And btw it doesn't fit by default & i use it only as a 6.5" with custom Centrafuse resolution as mentioned before:
                            'Well i did crop inside the CID but not the viewing side because i don't have any experiance with fiberglass so i have a 7" in a 6.5" frame, using a custom resolution for CF. Maybe it's time to found some fiberglass master =)'
                            Didn't find a cheap 6.5" tft lcd..
