E39 carpc
  • E39 carpc
    Here's a few pics of my ongoing project.
    Started with wood...
    Got it cut and shaped to fit the screen
    Made one out of fiberglass. After bondo and primer...
    Screen mounted, bezel ready for texture...
    Tech specs for the build:
    7" lilliput 5 wire touch screen
    EEE PC
    Looking good. Nice idea of using wood. Don't think I've seen it done b4.
    Project X10 Belazer
    Progress: NEVER ENDING!!!
    http://www.mp3car.com/show-off-your-...ime-puter.html
      - -I have an E39 also and I like what you have done so far, keep up the work.- -
      - -Take a good look at yourself while at the computer, if your in a t-shirt and talking sh@t on the internet. Chances are you fall in the "Internet Tough Guy" catagory.- -
        Thanks. I used the wood to make a silicone master mold, so if mine broke, or someone else wanted one, I could whip one up pretty easy.
          Thanks. I wanted something that looks OEM and couldn't find anything, in the US, and under $200. Lol
          I think it turned out pretty good for my first project.
            Got it textured and tested the screen.
              Got it installed... But it's back out again while I'm installing this
              2.66 ghz core 2 duo, 2 gb ram, 320 gb HDD and maybe an audio card later.
              It's mounted on the factory amp rack.
                I really like your mod job. Looks better than OEM IMHO...
                :0)
                  What did you use to give it that texture/color? Thanks.
                    SEM texture and trim black paint. Apply it in very light coats to get your desired texture.
                      Awesome work!
                      "Live Free!!!...It's all about Open Source"
                      Recent Proj
                      Old Proj II
                      Old Proj I
                      YouTube:Project Videos
                      Homepage: HexxWorld.net
                      Twitter:http://twitter.com/hexxamillion
                        nice work
                          Finally getting back to this after a year and a half. Was busy swapping an LS3 into my car.
                          Updated info:
                          New carputer, core i3, 4gb ram, halo soundcard, 500gb SSD running Win8
                          Will be upgrading to a capacitive screen before final instal (and might work on a 10.1 setup in my spare time)
                          Pics of carputer installed in factory amp location (old MB) need to build a new case for the new setup
                          I'll be running optical to a zapco DSP and RCA to all the amps.
                          I'm debating between a single 18" sub sealed or 2 15" IB style.
                          Will do a active 3-way setup with custom door panels similar to these
                            Wish I had an LS3 for my car, was brainwashed by gas mileage into being satisfied with the V6 so I'm waiting for CARB legal turbos to come out. Would like to see updates of the rest of your project too, a 10.1 sound system has got to be awesome. If you want more sound pressure go with the twin 15's, but if you are trying to fill the complete low end, the 18 will give a little more energy at the lower end and finish your frequency response curve slightly better. More pics please!
