350z carpc, autopc project
  • 350z carpc, autopc project
    Project took 5 days total and about 400 dollars worth of parts and tools.
    Finished project:
    How it began:
    I found a laptop on craigslist that had a cracked touch screen and broken outer shell for a hundred bucks. This gave me the idea to install it in my car to replace my 7 inch touch screen stereo. Here's what the laptop looked like.
    The first thing I had to do was to replace the touch screen. I found a vendor in china online and managed to pick it up for 150$. Part arrived in about a week. Install took about 20 min.
    My next task was to fabricate a bezel that I could mount the screen to in the center of the dash where the original radio had been. This is the original setup.
    As you can see the screen was very small and it was hard to navigate while driving.
    This is the factory bezel cut out with card paper cut and formed to the general shape I needed. I coated it with fiberglass resin to make it stiff.
    I then fiberglassed and applied bondo, then sanded the bezel.
    A couple more applications of bondo and some primer...
    J B welded 2 studs to the back of the bezel to hold the screen in.
    Gutted the passenger side of the dash to make room for the laptop...
    Test fit the bezel.
    I bought an Audigy 2 ZS for the laptop to run sound to the Bose amp which was very easy as I had an aftermarket adapter with 2 pair of RCA jacks and the zs 2 had 5.1 out, all I had to do was wire the Bose amp to acc. power and buy 2 adapters for headphone jack to RCA out so I would have front and back speakers. I ran the power to the laptop from the acc power for the radio and grounded it to the radio ground. I was blowing fuses so I had to buy an inverter to run the power supply through. I finish bondoed and sanded the bezel and covered it with carbon fiber print pleather I bought from a marine upholstery shop for 5 bucks. This is the finished product so far.
    This was my first time dealing with fiberglass, bondo, and upholstery, so I learned alot and had fun doing it. I used this forum for reference and am thankful you guys are here. My next project is to remove the pod gauges from the center console bezel and mold it smooth into the top of the screen for a more curvy look. I will then replace those gauges with a dash commander lcd screen hooked to the laptop, which will also replace my speedo cluster.
    Completed
      reserved 2
        Is that a Dell Latitude D6410? Where can I get the touch screen for it? Plz PM me, thx
          Very nice work. A screen that big in an 350 must light up the entire cabin at night
          Live mp3Car Facebook Chat
            I run the screen at 100% brightness during the day and 5-10% at night. This car isn't quite as big as a Altima but that doesn't make to much of a difference because the screen is dimmed at night. I'm hoping to make a program or batch file to automatically dim the screen at a certain time of day.
              Are you running a front end? My Auto Dimmer Control plugin for CF will do that. You can do it with RR without a plugin at all.
                Not running a front end atm just running windows 7 and I am using winamp for playback of music. Still debating on running a front end or not. I think I can get windows to do all the things I need it to, but I have seen some really nice front ends.
                  looks really good!
                    Finally finished!
                    Bezel was 300 dollars from a custom fabricator. He did a great job well past my expectations.
                    His info is:
                    Alvin Lawrence
                    5293 tower way
                    Sanford Fl 32773
                    340-513-1290
                    autofanatik@hotmail.com
                    Tell him I sent ya!
                      Great fabrication!! I really like how you intergrated the gauges.
                        looks greats what size is that screen? is it multi touch? and please if possible let me know the distributor you got it from thanks.
                          Dell ATG 6410 single touch screen 14.1 purchased broken from craigs list
