CarPC and Head unit intigration on my 2011 Toyota Prius
  • CarPC and Head unit intigration on my 2011 Toyota Prius
    Hi folks.
    thanks to all the amazing projects i saw here i atempted to install a carPC in my 2011 Prius.
    Click image for larger version
    I put the monitor in the top glove box and the computer in the lower glove box.
    I considered buying a carputer but the price range was coming to about 400-to 500 (for a good one). So then I looked into making my own which is a better option but would take up extra time and still cost like 300 or so.
    So I decided to go with a nettop ( for about $150). Not the best choice for a carputer because it does not have a regular ATX motherboard and not very rugged but I only need it for internet access.
    Since the nettop does not have a motherboard power switch header that would normally connect to the push-button on the front of a personal computer case. I solder couple of wires to the on/off button which I used to place a small push button under the center consol.
ID:	2308896Click image for larger version
    My car does not have a conventional starter, there is no high amp spikes, so i dont need a DC to DC regulator.
    I taped +12 from the lighter socket and ground near the bottom of the glove box. and installed a small push button to turn on the computer.
ID:	2308899Click image for larger version
ID:	2308900Click image for larger version
ID:	2308901Click image for larger version
    I Installed the nettop holder in the lower glove box and made some vent holes.
ID:	2308902Click image for larger version
    Found some space behind the lower glove box where i stuffed the computer power brick and the wires for the LCD touchscreen
ID:	2308903Click image for larger version
    I removed the stock CD player because it did not have and aux input and bought a cheap genaric chinese Headunit off of ebay. I output the audio and video from the CarPC to the new head unit.
ID:	2308907Click image for larger version
ID:	2308908Click image for larger version
    Routed the wires and hooked up the CarPC.
    Problem!! the 7" touchscreen was too big to fit in the upper glove box so I ended up cutting the bottom off, squished the electronics together and repositioned the buttons.
ID:	2308911Click image for larger version
ID:	2308912Click image for larger version
ID:	2308913Click image for larger version
ID:	2308914Click image for larger version
    After hacking up the monitor it still did not fit the glove box so i had to cut up the glove box to make it fit.
ID:	2308916Click image for larger version
ID:	2308917Click image for larger version
ID:	2308918Click image for larger version
ID:	2308919Click image for larger version
    put everything to gether .
ID:	2308921Click image for larger version
    Finally testing if it works and yes everything is up and running. and when the glove box is closed no one knows there is a computer there .
    You just ruined your Prius.
      monitor in the glove box?
