Nissan Qashqai+2 embedded carputer tablet version ;-)
  • Nissan Qashqai+2 embedded carputer tablet version ;-)
    after 3 years i upgrade carpc system with a Huawei Mediapad 7"
    of the previous configuration has remained only the carnetix p2140 appropriately reconfigured;
    i only changed the center console to add tablet
    this is the preliminary test
    tablet specs:
    Operating System
    Android ICS
    CPU
    1.2GHz Dual Core
    Display
    7'' LCD WXGA (1280x800 IPS)
    Camera resolution
    5 Mega-pixels AF camera & 1.3 Mega-pixels camera
    Capacity
    8GB
    Extended
    up to 32GB micro SD
    Connectivity
    Wi-Fi 802.11b / 802.11g / 802.11n
    Bluetooth 2.1
    Headphone
    3.5mm stereo audio jack, Stereo speaker
    GPS/A-GPS
    Accelerometer sensor
    Ambient light sensor
    Compass
    Battery Type
    Li-Polymer Capacity 4100mAh
    positive side
    global cost
    velocity
    simplified installation
    monitor resolution and quality
    boot velocity
    integration without particular frontend
    no crash or operative system error
    no drivers to install
    minimal configuration
    negative side
    rear cam; temporarily lost functionality (I have an idea :-))
    The tablet is powered by a Carnetix P2140 dual channel
    5v for Tablet and usb hub
    12v for silent 92cm fan behind tablet inside enclosure
    and programmed for send and cut dc with no delay
    for OBDII i use a modified Bluetooth adapter
    Software:
    widget auto pro as launcher
    WeFi Pro - automatic and seamless Wi-Fi connectivity whenever you are!
    Torque for OBDII data
    Tasker for automations
    - on (Enable the system, wireless connections etc)
    - off (Go in Stand by mode, Aereomode, pause music etc)
    - Say if wifi connection is on or lost
    - Say every 15 minutes what time is it
    Click image for larger version
Name:	cavo-curvo-cable-dati-usb-data-otg-tastiere-memorie-samsung-galaxy-s2-ii-i9100.jpg
    Central consolle command interface fabbrication
Name:	IMG_1646 [800x600].JPG
Name:	IMG_1647 [800x600].JPG
Name:	IMG_1648 [800x600].JPG
Name:	IMG_1648_2 [800x600].JPG
Name:	IMG_1649 [800x600].JPG
Name:	IMG_1650 [800x600].JPG
Name:	IMG_1660 [800x600].JPG
Name:	IMG_1661 [800x600].JPG
Name:	IMG_1662 [800x600].JPG
    Powered +5v HUB USB with velcro fix
Name:	IMG_1663 [800x600].JPG
    OBDII bluetooth adapter with 12v under key permanently connected
    no danger of battery drain ;-)
Name:	IMG_1475 [800x600].JPG
Name:	IMG_1474 [800x600].JPG
Name:	IMG_1665 [800x600].JPG
Name:	IMG_1664 [800x600].JPG
    microphone location
Name:	mic [800x600].JPG
    Huawei Mediapad 7" (1280x800 IPS) | Carnetix P2140
    My last update http://www.mp3car.com/show-off-your-...t-version.html
    Looks really good. Could you describe the front end/app you're using? I recognize Google Music as the music player, but nothing else.
      i use widget auto pro as launcher that is the only solution similar to centrafuse;
      is a widget inserted in th home of ICS very simply to use
        need moar pics!! looks good dude
          soon, work in progress, stay tuned :-)
            Central consolle command interface fabbrication photo added ;-)
              nice, I'm curious but how will you integrate the buttons you added with the tablet?
                natively mapped keys perform the same functions as a multimedia keyboard with Microsoft Windows;
                unfortunately in Android is not possible to map keys as in Centrafuse (or at least I do not know), so I chose the media keys that had direct effect;
                The LED is powered from the 5v USB port and serves as a warning to learn the status of the power supply;
                the adapter is connected via USB HUB
                  Where did you buy that tablet from, looking at doing a similar install for my brother.
                  Audio
                  Front / Rear RE Audio RE6.5C + RE Audio DTS-500.4
                  Sub RE Audio SEX10D4 + RE Audio DTS-1500.1
                  Carputer
                  MOCOSO Case + MiniTouch DD + Asrock E350M1
                    it's not difficult to find
                    http://www.huaweidevice.com/worldwid...yId=5011&tab=0
                      I saw that, since I do know how to use google and computers. I didn't see where you could actually purchase it. Do you have to be signed in?
                      Audio
                      Carputer
                        i'm in Italy,
                        you can try Amazon.com
                          What was the deal with the reverse camera? Are you planning to integrate it into the tablet?
                            for rear camera i found two problem,
                            first input analog signal into tab;
                            secon enable view with rear gear.
                            for the first, the idea is to enter analog signal in a mini video server an connect it with a rj45 usb adapter (wired)
                            but....
                            it's a study, i have to do some experiments
                              you can hook up a usb webcam and use it as a reverse cam
                              http://www.youtube.com/watch?v=taZ3z...eature=related
                              but the app will not initiate automatically
                              i wanted to ask you if the keys you removed from keyboard are mapped?
                              if no how did you did that
                              please upload some more pics and complete tutorial to make the audio control work
