Saab 93 OEM installation (Now running Android)
  • Saab 93 OEM installation (Now running Android)
    Hello,
    Since I saw the first factory colour screen in a car I always liked to expand the functionality of this display, mantaining the factory looking of the dash. That is my main goal. I think factory screens have the perfect resolution/quality for the purpose they are designed for.
    My car is a MY05 Saab 93 SS. It comes with the ICM3 colour display. The first problem was it does not have any external video input. So I had to disassemble the whole unit and spend some weeks of reverse engineering the LCD. Internally, it was like some other screens I have seen, analog RGB with NTSC timings. Time to design a video switch circuit.
    But I wanted to convert into touch screen too, and, why not, connect to the CAN network and catch events like reverse gear insertion (intended for automatic reverse camera switching) or button pushing (manual video switching using factory buttons). The CAN network (GM SWCAN) takes me another couple of weeks of decoding commands. How to sniff the SWCAN here
    The circuit. It has the USB touch panel controller integrated:
    The adapter integrated inside the screen ecu:
    The touch panel installation
    And the external connection:
    Testing the results. PC connected through the VGA connection of the converter and an special driver:
    Running emulated Windows Mobile in XP:
    Note: the display is 400x234 pixel res.
    The next step was the reverse camera connection. But most of the cameras are CVBS video signal (composite). So I had to design a CVBS (RCA) to RGB video converter. I know there are some converters of this kind in the market, but I want to make it myself, according with my personal requirements. After a few "fights" with old analog TV ICs, I decided to go into fully digital conversion. The results were worth it.
    The converter has two CVBS (RCA) inputs and one RGB (VGA). One RCA is reserved for reverse camera, the other one is generic. The VGA input is intended for connecting the Carpc.
    The installation diagram I have planned:
    Here is the converter internals:
    And externally:
    Drilling the trunk:
    Rear camera installed:
    Routing the camera wires through the trunk lid:
    Video converter instaled in the trunk:
    And the final result:
    looks really nice.
    What frontend are you planning to use?
    I think with a low resolution like that you wont have a good picture, if you do , -> pics
    View my worklog here
      Nice project. Your skillset is very impressive to be able to interface with stock equipment like that.
        Originally posted by eugenweij View Post
        looks really nice.
        I do like OS used as frontend, obviously Windows XP is not suitable for this resolution, Windows CE 'as is' has the same problem, even using an skin, it is an obsolete OS with a very limited software set.
        I think Android is the best option at this point, it is perfectly usable at 320x240 pixel res. (there are some smartphones running android at this res.)
        So I'm developing an Android box with VGA (analog RGB) output to be plug and play with the video converter I have installed in the trunk.
          Thank you. Electronic engineering is my passion and cars are too.
            This is excellent work. I love the fact that yo keep the OEM look of things and just expand the functionality.
              android sounds good , what are you looking at for functionality of your system ? e.g gps odbII etc.
                I'm planning to add GPS, 3G, audio out, some USB ports, CAN, and maybe composite video input, for security purposes or travel recording. The development is well advanced, I hope I can upload a video soon.
                  that would be nice
                    That looks absolutely amazing!
                    I have been wondering about the possibilities of such a thing for a while! I would love to be able to use the OEM system but with a more...up to date back-end (eg: Windows + Centrafuse / Android / RaspberryPi).
                    You have got some very impressive skills to be able to pull off such a neat solution!
                    How long did it take you to complete? If you dont mind me asking, what were the costs of building the modification minus the reversing camera?
                    Also, i dont suppose that you know how easy it would be to build a module that can effectively replace the stock car amplifiers? I love my music and the stock stereo is simply dreadful...i even have the Premium 150 sound system and its awful. =(
                    I look forward to see what you end up doing with this set up!
                    Regards
                    Giz
                      Regards
                      Giz
                      Thank you! It took me about 1 year. The total costs of the project are really hard to estimate, hours of research/development, design, PCB fabrication and electronic components ... it was not a profitable work at all but I'm very proud of the result. I sold a couple of kits last year in the Saabcentral forum.
                      About the sound system, I know about the poor quality of the Saab 93 audio, even when including the factory amps. I have solved this connecting an aftermarket amp to the speaker level signal of the stock little rear speakers. This amp drives two 6x9 speakers installed in the trunk gaps and the front doors ones. The amp should have bass gain control to amplify these frequencies.
                      As I said weeks ago, I was working in an Android carputer based on ARM. The following pictures shows the stock navigation display of my car (ICM3), RGB quality:
                      Running Android 4.2 (JB)
                      Sygic navigator:
                      Google maps:
                        Your work is something to be proud of for sure, That is a truely awesome project and the results speak for themself! Excellent work!
                          Nice! What hardware do you use for the Android ??
                          System in progress:
                          New install in progress...
                            Id be very interested in buying something that will allow my icm3 to play a dvd player if possible
                            VIA EPIA TC 10000 1Ghz Motherboard,
                            256Ram,40Gig,
                            Lilliput 7" Touchscreen
                            ALL ABOVE NEEDS SELLING !
                            OFFERS WELCOME
                            2008 Astra H Sportive SE 1.9 CDTI
                            2006 Quadzilla Stinger 250e Quad Bike
                            2000 Saab 9-3 Viggen Convertible
                              Very nice job
