2000 Chevy Tracker Glove Box PC
  • 2000 Chevy Tracker Glove Box PC
    Take a look:
    I can't show all 11 images here, so...
    You can see rest of it THERE.
    What you think?
    <>My previous Car PC<>
    nice, tho i would be a little worried about the mess in the glovebox.
      looking good! very clean install. you gotta give the details now
      1) hardware specs?
      2) how'd you mount the XENARC?
      3) how'd you cool the glovebox and OPUS? (i saw the fan, but where does air circulate from?)
      3) is the DVD IDE or USB? if IDE how'd you extend the data & power cable?
      again...looks like a great install!
        1) hardware specs?
        .........looks good. Very slick, and ideal place for the screen and other hardware.
        92 Taurus SHO - Daily driver - Epia M10000 80GB 512mb 7" touchscreen, Opus PSU etc
        93 Black SHO - 30mpg cruiser
        90 Silver SHO - 419whp fun/project car, CarPC to come (for tuning)
          1) hardware specs?
          1) VIA EPIA M10000 (1 GHz C3 CPU - Nehemiah)
          Corsair 512MB PC2700 DDR RAM
          Seagate 40GB HDD
          Panasonic CW-8122-B CDRW/DVD-ROM slimline slot loading drive
          SB Audigy 2 using 5.1ch
          D-Link USB 2.0 hub
          DIY flexible PCI extension
          VIA 2 slot PCI riser
          XENARC 700 TSV 7" TFT LCD Monitor w/ VGA & USB Touch Screen
          ATI Remote Wonder
          Keyboard
          2) I took it apart and mounted its faceplate to the cars stock DIN
          faceplate. Filled it with some liquid plastic, sanded it, painted it. Putted back the touch screen panel and the LCD and done. I didn't use the back plate of the monitor.
          3)The fan just moves the air inside that space. I don't have any problems so far but its winter though. We'll see next summer.
          4)(3) The DVD is IDE using 36" IDE round shielded cable from CompUSA. No problems. There is nothing special about the power cable. The power comes from OPUS.
            It seems like looking at the LCD would be a pain since the viewing angle aren't great. How well can you see it?
            Also about the computer in the glove comparment, did you check the temperature of the PC running inside the compartment? That would be my biggest worries, put a few case fan in there and cut the back of the glove compartment.
              The viewing angle is not a problem at all. XENARC has a wide viewing angle. I don't see any problems here. I'm worry about the glare produced from the touchscreen panel. I have to figure something out. Maybe windows tinted? I don't know yet.
              Yes I'm checking the CPU temperature many times in the BIOS and never gets above 50C with the heater running at full power now. But I always can ad some more fans. No problems so far. And there is no back of the glove compartment at all. Its an open space. Well... small but open.
