98 LS-Vtec 230HP Integra With Carputer
  • 98 LS-Vtec 230HP Integra With Carputer
    The Old Setup
    The Long Shot!
      The Making of the Carputer BOX. mmmmm lots of time lots of beer!
        The Carputer box before Laminate
          My Baby! + The New Carputer Setup and Type-R Engine
            Performance:
            Type R-Setup (New)
            Type-R Engine
            Type-R JDM Trany with upgraded LSD (Limited Slip)
            JG Edlebrock Intake manifold
            DC Sports Header, 2.5 Inch Exhaust Header Back
            ACT Extreme Clutch and Pressure Plate
            Fuel Pressure Regulator
            Type R Strut Bar
            Brembo Rotors, Slotted
            Interior/Exterior
            Alpine 7inch LCD In-Dash Monitor
            700Mhz Carputer
            Carbon Fiber Hood
            KYB Adjustable Shocks
            Reactive Springs and Coil Overs
            Type-R Body Kit
            Old Setup (LS Vtec)
            B18B block with:
            B18B rods shot Peened and polished
            Balanced / Blueprinted bottom end
            SIR pistons (11.3 to 1 compression)
            JDM B16 V-Tec head
            Integra Type R, valves, valve springs, retainers, port and polished with Crower Stage 1 Cams
            Type R Strut Bar
            More Pictures at More Pictures
              very nice
              nice setup!
              EDIT: I jsut saw your post about the stuff...
              Where is your HD? did you wire the IDE all the way up front for CD/DVD? i assume that box to the right of the comp is the PSU....what supply is it?
              Thanks alot!
              Cheap Laptop, great for Carputer!
                Hard drive is the box on the right. all padded so wont kill the HDD. no CD/DVD I have wireless on the computer download the movies and the music in my driveway and the power supp is just a normal power sup out of a small computer.
                Originally posted by jusatry
                nice setup!
                Thanks alot!
                  *cough*VTEC*cough*
                  Nice and clean otherwise
                    Very Nice!
                    Sweet install. What did you use to cover your sub box and such? Looks awesome.
                    98' Olds Bravada
                    Athlon 2000+/512/60g/WiFi/DVD
                    14" in-dash/7"headrests
                    Kenwood Excelon HU/Fosgate Amps
                    3x10" JL Audio subs/Soundstream components
                    Delphi XM/GPS/integrated cell phone
                    OBDII ECM Interface
                    A bunch more stuff no sane person needs
                      just curouis? 230hp? must be hp at the crank, cause my built b18c motor put out 200at the wheels and that was with alot more internals than what you have listed
                        Out of curiosity what do you all run your 1/4 mile times in?
                        1999 Camaro z28
                        -- Computer installed :) Phase 1
                        -- z28 302hp dynoed :( WAHH!!!!
                          230 at the crank, I am going to run the quarter this year after I get my type-R trany,
                          Infink what do you have done to your B18C?
                            Sub box is covered with Laminate. My car is gutted right now I am re-doing the install basically switching places of the sub/computer so it is easyer to work on. I am also showing the amp and going to cover the boxes with black laminate this go around.
                              how much did it cost you to make and install the carputer to your teg?
