1998 Tiburon FX Carputer
  • 1998 Tiburon FX Carputer
    Edit:: new Pics rehosted, and my car is dirty i know.
    EDIT MORe! Better pics at the end.
    Edit:: Fabricated dash
    http://www.mp3car.com/vbulletin/showthread.php?t=53981
    new updated pics of the car, and of FP running.
    as of 4/21/05, NEW PICS! at the end of thread.
    My Carputer! (More Car Pics at the end)
    2 Kicker Comp 10"
    Epia M-9000, 256 MB DDR, 120 Gig HD
    Lilliput 7" VGA Touchscreen
    Check it out?!
    Well the specs are in my signature... oops need to change that to INSTALLED, but oh well. The first 2 pics are the trunk. I used velcro to keep stuff on the ground, as well as to hinge my case top. Third pic is the 7" Lilliput Touchscreen, it's on a stand. 4th shows how I can remove it and throw it in my glove box, don't want to attract attention to my car. Next shows the sanded piece of plexi it's on. I was originally going to sand down that piece and use body filler and paint it black, but I'm going to eventually add LED's behind it, so the frosted look will be cool. I used hot glue to attach the stand. The last pic is just my car. Let me know if you have any questions or comments. Thanks.
    2 Kicker Comp 10"
    Check it out?!
      v. nice, bitta fibreglassing in the boot and ull be sweet
      Mods: 18" Boss rims,Twin custom stainless exhaust,cold air induction.
      Sound: Pioneer 7400 HU & 6x9's,12" Vibe Sub,600W Kenwood amp.
      CarPC: MicroATX, Inverter, WinTV, Lilliput 7", USB GPS
      http://www.no1knows.com/galleries/
        how does the touchscreen disconnect?
        does it have a plug? i was thining of doing something like that if i didnt fabricate my own dash.
          Nice looking install. Neat screen mount/dismount idea.
          2000 Monte Carlo SS - CarPC FINALLY INSTALLED!!!
          CarPC: VIA EPIA-M10000, Xenarc 700TSV, 20G 2.5" HD, Opus 90W, Targus USB DVD/CD-ROM
          Audio: Audigy 2 USB, Alpine 4 Channel Amp, 2 x Alpine 300W 6x9, 2 x Alpine 200W 6.5 (sub coming soon)
            Thanks for the comments.
            About the monitor, well the lilliput comes with a short cable attached permamently to the monitor that's ~5" long. It also comes with a cable that attaches to the 5" cable on the monitor and outputs VGA as well as USB (touchscreen). So I drilled a hole to run the long VGA/USB cable through, and put a rubber band on both sides, so it stayed put (didn't want to glue it). Then I just plug/unplug it and stow it. The main reason I didn't fab was security, and I think it looks sweet how it is.
            2 Kicker Comp 10"
            Check it out?!
              Have you thought about spraying the screen casing black for that last cosmetic touch?
                No, I don't want to take it out of it's case until my warranty expires. I say keep it intact as long as possible with those pricier components.
                2 Kicker Comp 10"
                Check it out?!
                  Well, the hot glue gave out today. I finally snapped and screwed it on there, what I should've done from the beginning. It's true, there's never engough time to do it right, but there's always time to do it over. Got a USB hub that I will soon be hardwiring to the onboard 5v line. Also , In the near future I will be hardwiring my egg onto the ITPS. The egg runs ~13 Volts plugged into the cig adaptor.. It's funny, because the screen stops scrolling when the bass hits, as the voltage is evening out. Well, thanks for the comments. I'll keep further devolpment posted.
                  2 Kicker Comp 10"
                  Check it out?!
                    You're right. I just started fiberglassing a sub enclosure a few days ago, it's got about 4 layers on it right now, ready to rip out of the trunk tonight.
                    2 Kicker Comp 10"
                    Check it out?!
                      I was going to mention about the hot glue, but i see it already happened.
                      It happen to me too, i was thinking that hot glue was permanent, but i guess after hot temps and movement it just gives way.
                      Dual Lilliput's 70NP/C/T
                      Syntax SV266AD KT266A
                      AMD Athlon XP 2000
                      Viking 256MB DDR
                      D-Link Wireless 802.11B
                      Seagate 120GB
                      OrbitMicro 250W DC/DC converter
                      SII Wireless Audio Link
                      Digimoto OBD-II
                      Earthmate GPS
                      BU-303 USB GPS
                      D-Link Bluetooth
                        Pictures
                        Yea, It didn't hold, but that's fixed now. Now I'm currently working on my custom fiberglass sub box. From my initial mesurements, my box will be about 1 cubic foot. Kicker recomends anywhere from 1 ft^3 to 2.4 ft^3 so volume isn't a concern. I had a little excess fabric i couldn't tuck away, so I made that little ledge from the top of the mount ring, this works perfectly in my trunk, and I'm very satisfied with it. Well here's the pics. BTW, that's just felt.
                        edit:: no more pics
                        2 Kicker Comp 10"
                        Check it out?!
                          That looks nice! It's a good idea to hide the monitor away
                          00 Saturn SL2, boosted @ 8 psi - CarDomain
                          Newest install - my quickest ever
                          My 2nd carputer - b4 I broke the touchscreen
                          My very first carputer - voted the most ghetto
                            hows the sub enclosure looking?
                              It's looking pretty good, likes tacky currently because i'm trying to isolate leaks. I'll post pics soon, gotta find my camera!
                              2 Kicker Comp 10"
                              Check it out?!
