Digital Integra
  • Digital Integra
    Car
    1997 Acura Integra GSR 4-door
    Stock stereo system
    Hardware
    7" in-dash touchscreen
    Via CL-10000
    512 MB
    10GB IDE drive
    DVD player
    12V->18V adapter
    MPEGBOX shutdown controller
    Software
    Windows XP
    FrodoPlayer
    iGuidance (same as Routis)
    Project site: http://www.digitalintegra.com
    My Project: digitalintegra.com
    Lovin the USB port.
      Yeah the USB port is sweet.
      How is that CL-10000 working out for ya ?
      [H]4 Life
      I'm a lesbian too.
      I am for hire!
        The CL-10000 is nice. A little more expensive than the M10000, but it is a nicer board for non-car uses in case I ever decide to swap it out... Dual ethernet, four serial, 6 USB 2.0.
        As far as I can tell the only disadvange is that it doesn't have 6-channel audio. Since I'm running on the stock system, that is fine with me.
        - Noam
        BTW... OT, but I can't wait to try out iGuidance embedded in FrodoPlayer
          How did you get that usb to turn out so clean? I want to do the same thing in my trucks' driver door for a keyboard or usb stick. Could you tell me what you did. Thanks
          "I'm going back to Cali(Iraq), Cali(Iraq), Cali(Iraq), I'm going back to Cali(Iraq), Cali(Iraq), Cali(Iraq), I know so!!!!" Now I'm here!!
          By "ToneRiddle"
            I drilled a couple of holes and then used a utility knife to shave it away. The USB port itself is one of the ones that would attach to the back of a PC. I cut away the plastic holders so that the USB port itself sticks out more. I had to make it wider than the USB plug itself so that I could actually get the USB plug through.
              what did you use to attach it to the plastic?
              By "ToneRiddle"
                Just friction. It is a really tight fit. I'll probably epoxy it in at some point.
                  Wow, you sure did a great job on that USB opening! Why haven't I even thought of drilling holes and than cutting the opening? Doh! Next time I will do exactly that
                  00 Saturn SL2, boosted @ 8 psi - CarDomain
                  Newest install - my quickest ever
                  My 2nd carputer - b4 I broke the touchscreen
                  My very first carputer - voted the most ghetto
                    Yeah... The USB port itself was the easiest (mentally and in actually) piece to do.
                    Hacking apart the dash to add another DIN slot where the cigarette lighter used to be was much more "fun"... I also never thought I would become so comfortable with removing all of my seats and ripping up the carpet for all of the cable runs.
                      hey bud, i have a 96 integra and i also want to put in a 7" as you did. I was wondering why you didnt put the LCD in your single DIN spot, perhaps moving the car stereo down one notch and the LCD on top of that? Any advice/info about this would be great, i have so many questions about my carpc project that im currently planning! (im sure i could use your wisdom on integras)
                      '05 Acura TL w/ Navi & Bluetooth, JL Audio Cleansweep, JL Audio XR650 CSI, JL Audio XR650 CXI, JL Audio 300/4 Speaker Amp, Eclipse SW6123.4 12" Sub, JL Audio 250/1 Sub Amp, Optima D35 YellowTop Battery http://www.cardomain.com/ride/2184473/1
                        I was going for the stock look, so I didn't want to move the head unit. Also, I think you'll run into trouble with the LCD blocking and/or hitting the A/C controls.
                        - Noam
                          I used to own that domain! lol. I had a PC in my '96 'teg.
                          My Install Thread
                          digitaljetta.com
                          MKIV VW Jetta
                          How do I get sound to my car?
                            i dont know if you got my private message or not noam, but can you contact me on aim with the screenname i gave u on the msg? i really wanted to ask you some questions about the LCD and carpc in general! thanks again
                              noam... would u happen to know for a fact that if i put the LCD on the top DIN that it will hit the A/C controls? cause thats the only thing stopping me from starting my entire carpc project right now, otherwise i dont know what to do because i dont know how much longer im gonna keep this car and i dont wanna do major custom work on it. i dont mind if it covers the controls, as long as it doesnt actually hit them. Also, how much of a pain was it to place your pc case on the back of the seats? and was the wiring to the front also a pain? and finally... how are you powering your monitor? if its thru the power supply, how exactly did u do that? thansk again for all the help
