Range Rover - reworked install
  • Range Rover - reworked install
    First few tries here:
    http://www.mp3car.com/vbulletin/showthread.php?t=15010
    Epia tucked away in the body panel. On the left side of the MDF panel is the Cheesebox that switches the signal to the rear view camera.
    Cover put into place - no sign of the computer. The silver thing in the middle is the key switch to turn off the power to the computer.
    Volume is controlled by the Griffin Powermate with a more car-like knob.
    The switches are for tactile control of software so that I can switch songs without having to look at the screen. Connected to the computer through a keyboard encoder.
    HU and USB sound card in the glovebox.
    Looks awesome man, I like the tucked away epia. Good job with the burltech around the monitor.
    My Carputer! (More Car Pics at the end)
    2 Kicker Comp 10"
    Epia M-9000, 256 MB DDR, 120 Gig HD
    Lilliput 7" VGA Touchscreen
    Check it out?!
      Nice and stealthy...That radio in the glovebox has got to be redone.
      Good job. Keep us updated.
      Aura MR62 (F and R)
      My Current MP3s
      IamDefiler.com
        That is one sweet install. I have the griffin powermate with the HUGE knob too. Could you post some details on how you went about replacing the knob and where I could score a replacement.
        Also I would love to know how you set up the controls for next/prev song. More detailed information there would also be great.
        Don't Fear The Gurkey
        Click here to check out My Setup
          very good. I especially like the trunk, Yeh, let us know about the knob and how you can skip songs. I have touchscreen, but I wouldn't mind having that as well.
          mykolJay
          99 Accord coupe
          http://www.geocities.com/accordpc
          My Project Thread on mp3car.com
            Awesome !
            Very nice !
            Please let us know how you got buttons to go to next song etc, is girder used or a hacked up keyboard ?
            Nano ITX / 512 MB / 60 GB / Panasonic slot load / M1-ATX / Bu303 / Sound blaster 24 / PPi amps / rockford sub
              Where are these switches you speak of ? I see none ?
              [H]4 Life
              I'm a lesbian too.
              I am for hire!
                That is a smooth install!! Good work!
                '02 GTI
                [Routis '04] [Opus 90W] [160GB Maxtor HD]
                [Lilliput 7" TS] [VIA M10000] [XMPCR]
                [512MB RAM] [Custom housing]
                [Deluo GPS Mouse] [E-MU 0404 Soundcard]
                Progress Meter: [==============|] 99.9%
                  Please elaborate
                  The switches are attached to a KeyWiz keyboard encoder.
                  http://www.groovygamegear.com/Page2.html
                  The Griffin Powermate has a standard 1/4" knob. Radio Shack, Jameco, and almost any electronics part store will have replacement knobs. The hard part was disassembling the enclosure.
                  Had to pry it open with a screwdriver since it is glued together. Also had to resolder the connecting cables since they were very flimsy and broke during my heavy-handed disassembly.
                    Originally posted by vladilen
                    Please elaborate
                    Do you have a link to a manual for that keyboard encoder? It looks pretty useful. A schematic of how you wired your switches would be terrific too if you could.
                    where did you pry from? The rubber part or where the knob attaches to the base? Or both? Oh and can you still use the push and twist functions with the new knob?
                      Wow, that's very clean and good looking!
                      00 Saturn SL2, boosted @ 8 psi - CarDomain
                      Newest install - my quickest ever
                      My 2nd carputer - b4 I broke the touchscreen
                      My very first carputer - voted the most ghetto
                        did you have any problems with the griffin powermate ?
                        my powermate is driving me mad ! at this stage only useful for the funky blue light !
                          They don't have a digital manual, it's just a double sided xerox that comes with the controller.There is not much to wiring the controller. From the switch, one wire goes to the ground on the PCB of the keyboard encoder, and the other goes to any of the other attachment points. I have a single wire from the ground going to one common line on all switches. The NO line then is connected to one of the other connections to generate a keystroke.
                          I don't recall exactly how I opened it. It has been some time ago. It is a total pain to do. Just take a screwdriver to anything that looks like a seam. Yes, it does keep both push and rotate functionality when removed from the case.
                            Initially, yes. I had to go into System Properties/Hardware/Device Manager, find the generic HID device and manually point it at the griffin driver. After that it worked fine.
