1997 camaro totally indash LCD and PC
  • 1997 camaro totally indash LCD and PC
    UPDATED PICS!
    Its about~99.9% finished so i figured it ok to post.
    Heres what i got:
    Asrock mircoATX mobo
    256 mb ddr400 ram
    60gig 7200rm maxtor harddrive
    notebook DVDrom
    7'' LCD scree with 400nits brightness(bright!)
    Touchscreen kit
    Creative sound blaster 5.1 digital soundcard runnin RCAs to a Alpnie mrv-f450
    Opus 150w car dc-dc powersuply
    Windows XP, mediaengine 2.32, lt1edit and Free scan digital dashboard/obd1 scanner
    near future: D-link USB radio and iGuidance Ver 2.0 GPS navigation
    It can play DVDs, one of my current 65 DIVX Movies, or one of my 1500mp3s. it also can show my cars data including engine paramiters and mph, boost, rpm on a digital dash board.
    It will soon have the radio installed and GPs navigation
    The only think i have left is buying the radio and gps
    And now what you have all been waiting for......
    PICS!
    .....pics!
    Cleaned up wires relocated opus
    Old pics
    My 97 SS Website
    Looks good! I love the place where you keep your system
    Now all you need to do is to do some minor touching up with fiberglass and you're all set
    00 Saturn SL2, boosted @ 8 psi - CarDomain
    Newest install - my quickest ever
    My 2nd carputer - b4 I broke the touchscreen
    My very first carputer - voted the most ghetto
      Woow.. Dimension Question..
      Nice install man I've been researching stuff to install in my Camaro and I've been trying to figure out where to place the mobo. Which ASRock board did u use I've checked on the dimensions of the microATX boards and they are around 9.6"x9.6" if thats the same size as your board how did u get it to fit behind the stock stereo system behind the dash..
        Do tell me your going to leave the sides of the screen open like that, it would be so getto. j/k
        It looks really good so far, the screen fits in there nicely. Doesn't look like you had to do much cutting. A little bondo and it will look like the screen came stock.
        Installed
        Asus A7N8X-VM - AMD Mobile Athlon 2400
        512 Ram - 60GB HD - Opus 150w
        Lilliput 7" - Rikaline 6010
        [00000000000001100010-] 98% Completed
        Check Out My Install!!!
          WOW very cool that you were able to fit a normal ATX board in your dash, with the hard drive and still have room for your LCD. Propps to you man.
          2 questions though,
          1. What processor are you running?
          2. Are you sure that you will be able to leave your mobo like that behid the dash, especially on hot days? If your not gonna bondo around the screen, I'd suggest custoizing some really quiet fans around it. Use it to heat your car
          Peace,
          Rafster
          Post # 3000
            Im using the asrock K7S41GX
            9.5 x 7.5'' smallest microATX board i could find. What really cool is i only have to cut one thing, just a small wire loom for the stock radio. When i need to go back to stock, its all there for me. Minus the bezel of corse, but i had a coupld of those lieing around.
            Im using the AMD duron 2500. Seems to stay generally good temp. Im not using stock cooling, but a actually larged fan/heat sink combo. The mother board its actually mounted to the a/c tubing back there, so a large portion of the mobo is touch cool plastic piping.
            Another thnk i do to help in the aid of cooling is close the a/c vents in the center. my car has 100k miles on it and that foam trim is shot just on the bottom. works to my favor tho, blows a nice flow of air over the entire setup.
            The fit was tight, but suprisingly it could have gone several different ways. one way i debated would have had almost all the plugs accessable out the front, but would have required a lot of cutting, so i opted out. It was tricky, but very do about. just be extremly carful to make sure nothing touching something its not supose to.
            I have already cleaned up most of the wires and removed wires that dont do anything since i took pics. I plan on putting one more fun in there to help out in keeping good airflow back there.
            Only thinkj i wonder about before i bondo up the gap, i want a volume knob, but how one earth would i wire this in? if anyone knows please let me know.
            My 97 SS Website
              "The mother board its actually mounted to the a/c tubing back there, so a large portion of the mobo is touch cool plastic piping."
              You are going to have to go really careful with condensation. Moist florida air + a cool pipe = condensation. Can you bleed some a/c from the tube into the dash space? AC air is dehumidified.
                Wow! That's going to look great after the bondo work. Nice DVD drive install as well.
                Hey, I recognize the plastic shelf that the HD is sitting on. I chopped that out for more room. The whole bottom and left. Cooling isn't much of a problem in that space I guess because of the openings under it for keeping the factory HU cool.
                  I watched that for several days (left the radio out) and never really got any condensation. BUT that was my biggest concern and stil i am very worried. Maybe the fact my a/c dont get as cold as it use to helps as well
                  Im actully debating weather or not to cut in to a baffle a small portion of the vent air from the main a/c tube to the computer area. even when the a/c is not on, i can still leave the fan on to blow are over the area
                  My 97 SS Website
                    Suggestion:
                    Cut out the Camaro "button" and unused button to its left and mount the DVD drive to the underside of the AC vents so that it's flush with the dash. It would look slick and probably be easier to get to/connect to.
                    Great job fitting it in there...lots of room to work with = clean install.
                      nice! gotta love camaros!
                        Looks like you did a real good job getting everything packed in there neatly.
                        I was going to get that mobo. Do you mind if I ask you a question?
                        Does the BIOS have the option for startup after power-loss? I know you have an Opus, but I plan on using this for startup. My current CarPC doesn't have this.
                        Progress Meter:
                        [|||||!||||'] 95% complete
                        It's in... it's finally installed!!!! But never finished!
                        "It works! It works! I've finally invented something that works!" -- Doctor Emmit Brown
                          Wow, very nice install man. Good work. I'm going to be performing a Camaro install soon, and will use this info as a basis for doing the job right. What exactly are you doing with your stereo? Will it fit behind the screen, or are you mounting it in the glovebox?
                          www.mobile-effects.com
                          Free file hosting, picture gallery hosting for installs, PM me.
                          Internet's first Front End Skin browser, featured installs, downloads, links, informative articles - all free to registered users.
                            Nice job! I thought the panel was hinged in the third-to-last pic. You should do that!
                            Fabricator
                              Originally posted by Geese
                              Suggestion:
                              You know, it'd be pretty slick to make the "Camaro" button the power switch.
                              Just a thought.
                              - Jeff
                              95 Mustang GT Convertible
                              87 Mustang GT Convertible
                              My Project | Let's Go Mets! | SCT Tuners
                              Project Status [===#===] [Bezel and dash creation]
