Mazda 626 Bezel DONE!!
  • Mazda 626 Bezel DONE!!
    Let me know what you think!!!
    Pics are below!!!!
    link doesn't work
    '98 Explorer Sport
    80% done
      website crashed!!!! I'll upload pics on here in a few minutes...
        here you go....
          the rest...
            nice...looks real good!
            http://memimage.cardomain.net/member_images/2/web/170000-170999/170063_221.jpg
              looks good,
              i dont know if you need to put putty over the entire thing though. just the pinholes.
              2003 Nissan Pathfinder LE - My cardomain page.
                thank you!
                  I didn't want the smooth finish, so I put more coats of primer on it and am going to paint it with plastikote trim paint without sanding the primer and see how that looks...
                  More pics to come...
                    How many hours did it take I've been doing the same thing (created a bexel) and I've been pecking away at it for about a month (an hour or two here and there)
                    I've just had to repaint it, I tried fixing a few low spots with more spot putty. Resanded and re-applied primer... of course now there's a crack in the primer.. I tried sanding that down too early (the primer wasnt dry) and made it worse... I sanded as much as I could and I've been adding layers of pain over the cracks in hopes to fix it.. quickly..
                    ahh the problems !!!!!
                    cant wait to move onto the next mini project
                    Progress [I will seriously never be done!]
                    Via EPIA MII
                    512MB RAM
                    OEM GPS (embedded)
                    nLite WinXP pro on
                    1GB Extreme III CF card
                    Carnetix 1260 startup/ DC-DC regulator
                    Software: Still, re-Writing my existing front end in .Net
                      Update:
                      The layers of paint seems to be working... It's actually smoothing out a lot of some minor inperfections...
                      I might have to go out and buy more paint tho... *DOH
                      Via EPIA MII
                      512MB RAM
                      OEM GPS (embedded)
                      nLite WinXP pro on
                        this has been about a week ...an hour here and there...not too bad...
                          I put about 4 coats of plastikote trim/bumper paint on last night. I'll check to see if I need more when i get home.
                          More pics to come tonight...
                            I now need to sand out the holes for the buttons..i put them in and they are really tight....so more sanding and some more paint...
                            pics to come....
                              626 Bezel finally finished!!!
                              Finished around buttons and wet sanded then a few final coats of plastikote trim/bumper paint. semi gloss.
