2004 - 2005 Audi 80 (1992) Carputer Install and other modifications
  • 2004 - 2005 Audi 80 (1992) Carputer Install and other modifications
    Project Vitals:
    Audi 80 1992 RED (model B4)
    2.0L Petrol Engine (non 16 valve)
    Lowering Springs Applied
    New Exhaust System Applied
    New Fogs Applied
    Location: Shoreham in the United Kingdom (Near Brighton)
    Project Status and Progress:
    Current Status: In Progress (18%)
    Current Task: Setting the wood together ready for holes.
    I plan to have this finnished in the next few days during my time off work for the xmas period. The image gallery will be kept as up to date and detailed as possible. I have included descriptions for most the images within the gallery on my site.
    Project Overview
    Aside from the other completed and planned modifications on my Audi 80, my main current project is a CarPc which I have been planning for over a year. I have even had the touch screen for about 9 months.
    Originally I intended to take the top half of the plastic dash off and then mount an aluminium frame on top which contained the screen. This would then be blended into the current frame ready to seat back into the car.
    Having thought about the project a lot and looking at other audi 80 installs such as this one I decided that I would take another route.
    I am constructing a entirely new central dash area which will be customised for my needs. The layout will remain essentially the same, mainly due to the huge headache it would be to try and relocate the heater controls.
    The new dash is initially made from 2 20mm thick pieces of MDF that have been bonded and screwed together. Then sanded and machined to get the right angle and rounded edges to fit perfectly in the existing hole in the center of the dash.
    After this the areas are marked out and holes machined out ready for the positoning of the touchscreen, radio, and heater controls along with the possible additional of some wonderful laser engraved buttons to replace the existing ones that are far smaller and more stylish.
    The final step will be to either paint the new dash, cover it in a laminate, or to produce an aluminium "face plate" that will go over the entire dash and wrap around along with the same holes cut out. This will produce the look of one continuous dash and allow for a nice anodised black finnish that would otherwise not be achieveable through current methods.
    The system itself is a 7" Lilliput touch screen combined with an old Sony Vaio PCG-Z600NE laptop which sits comfortably under the dash by the steering wheel which is handy. The power output has not been purchased as yet and I will be doing this in the next day or so (any suggestions welcome, although I may just got for a 30 unit from halfords). I will need to power the laptop, the screen, the amp in the boot, the headunit, the car (of course), the green neon in the boot (bit of fun) and the fridge that is located with the neon and subs. Its always nice to have a cold drink handy, although at the moment I think there is a bottle of Rum from Barbados which I should probably remove.
    I will keep you all updated as things progress this week, however the image gallery will more than likely be the most up to date area.
    Project Images
    View Original Dash Before MODS
    You can see a VERY ROUGH diagram of where this is all going
    View The Entire Gallery Of Modifications
    Project Sample Image:
    View the rest in the gallery
    Looking forward to your comments, and comments can be placed on the images within the site too.
    TTFN
    Dave
    Dashboard Monkey - CarPC News, reviews, installs and more
    Update 1:30pm on 29th September
    Went off to homebase today, board cutter was closed.
    Went to second homebase, board cutter was open, however it was going to cost 20 for 20mm MDF as I had to buy an entire sheet. So I settled for 2 pieces of 15mm thick MDF instead which cost a massive... 50p
    Piece one: 8.5 inch x 5.5 inch
    Piece two: 11.5 inch x 8.5 inch
    Also got some Rapid Setting Araldite 4.99
    to bond the two items together
    should be about an hour now until I can start getting down and dirty with the 2 bits together and do some markings ready to machine the holes out.
    The fit is perfect as you can see here with the smaller cutting, which should help to keep things secure along with the fixings. I guess the pic also helps give an idea of where this is all going.
    The gallery is updated with the latest, although not very exciting, pictures of the progress today. Should be another update later once the wood is stuck together nicely.
    TTFN
    Dave
      Update 5:10pm December 29
      Seems that after a design change I am now going to use a different size second bit of MDF.
      Headed back to homebase and got 2 new bits
      1. 8.5 inch x 8 inch
      1. 8.5 inch x 11 inch
      This time the cost was, nothing.
      Not sure why, the guy didnt say, he just cut it and wrote "replacement" on the paper followed by "Just walk out with it".
      So anyway, the new bits are now sticking and I will work with them once they are set.
      For anyone who cares, this post was made from the carpc system that is now up and running ready for install once I complete the frame.
      TTFN
      Dave
        Hiya
        I can't access the gallery links?
        Ford Focus MP3 : www.stevieg.org/carpc Blog Updated 29 January 2009!
        Car PC Status: Complete - Undergoing Software Redevelopment
          Yeah the site was redesigned, I am working on putting the images back. For now you can easily find all the pictures here:
          http://sunnymonkey.com/pictures.php
          TTFN
          Dave
          P.s
          Your interview was just posted on dashboardmonkey.
            TTFN
            Dave
            P.s
            Thanks found the pictures...
            Yeah I sw the interview, just adding links etc to my site now
              Thanks man!
                you pictures are not working... NONE of them!
                  I am having trouble too, i registered on your site and it still says about needing 20 second registration.. Can you embed some images into the first post?
                    how can you make me want to register somewhere? naughty boy.
                      Will sort out this post later on tonight.
                      For now, be sure you visit sunnmonkey.com without the www at the start and then log in.
                      Dave
                        Ok I have taken the protection off of the gallery for now as it does seem there was a problem.
                        You can now view all the images on sunnymonkey.com with no problems. Please still register an account so I can keep track of how popular it is.
                        I will sort the images on this post when I get a chance.
                          so do I still have to register?
                          cause it's coming up as
                          Not Available
                          This page is not available or there has been an error carrying out a request.
                          Please re-try your action. If you still experience problems please contact us or simply carry on navigating around this website using the links in the menu.
                          Kind Regards,
                          The Sunny Monkey Team
                          This page last updated on 13/01/05 @ 8:01pm.
                          I didn't know there was a 13th month!
                          Jan Bennett
                            13th of January 2005
                            English format date.
                            Think you visit just at the point the server was restarting?
                            Its all working fine at the moment and many people currently on the site.
                            Dave
                              Oh, and no, you dont 'have' to register. But it would be nice.
