Carputer in Ibiza '02 Sport/Ibiza FR
  • Carputer in Ibiza '02 Sport/Ibiza FR
    The installation on both my cars is the same so i will present it together
    Some photos are from the installation of the '02 1.4 Ibiza, some of it's uninstall and some from the installation on the new car ('04 1.8T ibiza).
    Since the dashboard of the ibiza isn't helpfull to install the VGA indash (it is too vertical) the best way i found is on the cup holder.
    In both installations i removed the sources my car had (a JVC MP3/stock RCD) and everything is done only via PC.
    In front i have constructed a panel with:
    Start and reset PC button
    ON/OFF of the PC power
    ON/OFF of the amp
    USB 2.0 Hub (powered)
    UTP plug
    Mic / Speaker output (only in new panel)
    Hardware:
    MII-12000
    PW120M psu
    512MB DDR
    200GB WD Hard disk
    SlimLine DVDROM
    USB GPS
    Xenarc 7" TFT (700TSV)
    EOBD cable
    Pinacle Studio PCTV Pro (radio+tv)
    4 channel amp
    TV and Radio antenna (with 12V input)
    CarPC UPS
    The main problem we had is what to do in order to bypass the reboot problem when i start my engine.
    We made a simple circuit that works (with the PW80 it didn't worked maybe because it has larger voltage dropout).
    The 12V from the car battery goes to a 12V small battery in the PC and then from the small battery the 12V goes to the psu. So the psu is constantly powered from the small battery.
      Other various photos
        Finished (1st installation)
          nice install
          ThE ScReW's CarPuter :-)
            cool!
            welcome to the board!!
            what kind of bike is that in the background??
            there wasn't enough room to flush in the LCD where you have all the switches and everything else???
            Jan Bennett
              I am not sure
              There was room (although it wouldn't be too easy) but as i wrote, the central console it too vertical and most of the time i wouldn't be able to see the monitor.
                I have done some serious updates...
                I changed the tv tuner with one that has better reception when i am not moving and slightly worse when in move. It's radio though is worse so i need a better antenna.
                I installed a SBLive24bit in order to have some decent 4-channel audio (even in MP3) and easily adjustable front/back right/left balance. MII was aufull in this :P
                I changed the PSU with a M1-ATX and i am a lot more satisfied !!!
                I made a new hand-made (2 layer ) box that fits in the spare tyre so i don't have anything that takes space in the trunk.
                Inside the box , the disk (200GB) now has 2 springs that let it move along the vertical axis and so i reduce the chance of disk crash.
                The only thing i need to do is to find a good (preferably cheap also) RF remote control for the quick jobs.
                Ps. Thank's frodo for the perfect GUI...still using it from it's day 1
                Ps. I have done all that months ago but i took some (poor quality) photos with the M1 arrival (now). I hope i have some HQ photos later.
                  Nice install!
                  Nice looking spring there too btw...
                  Renault Megane...the OEM look
                    hi JouS! poli kalo install! pou meneis athina ? isos mporeso na to do otan katebo ellada ton ioulio!
                    keep posting more pics... great job!
                    how good is the tv quality ?
                    -VIA EPIA M10000/512MB/40GB HD
                    -DWW motorized 7'
                    -BU 303 GPS w/iGuidance/ CF
                    -Opus90w
                    -Belkin Bluetooth
                    -Pioneer HU
                    [||||||||||] 95% done
                      Me no understand no typo you did o.
                        Are you sure you want to know...?
                          "car" good quality if you know what i mean
                          I wish i had the money to spend for a test of a good diversity tv tuner. But i am not sure of the result and i will be very sorry if the quality is the same.
                          And in order to solve our non-native friends mystery...
                          I will be happy to meet you and give you a tour of my ibiza whenever you come to Greece
                          Thank you all for the positive feedback
                          EDIT: Athina menw, N.Smirni
                            Thanks for the translation...
                            Why not mold the screen in dash?
                              Too vertical dashboard as i wrote before
