2004 Volvo Completed Install Link
  • 2004 Volvo Completed Install Link
    Completed project. Thanks to many here for ideas, and the benefit of their experience found here while lurking.
    S60R
    Great seeing another R with a PC. I'm not done yet but I'm getting closer =)
    /joZ
    I wanna die in the sleep like my grandfather, not screaming and yelling like the passenger in his car.
      great job...whats the purple box at the bottom of the dash with the dvd logo on it?
      New System in progress:
      M10k
      Phaze TD1500 ~> Seas g18rnx/p
      Zapco Ref 500.1 ~ 12" tc-9
      Transflective Xenarc
      My Car Pc Install
      My Boat Pc worklog
        Looking good.
        joZ - is your R a manual? (wish mine was :P )
          That is the controller pod for the ProLogic II surround sound DSP. It is a Clarion DVC-920 which connects to the brain box DVH-920. I went with Clarion because it can be configured as a stand-alone unit, has a separate small surface mount controller and the fact that you can modify the optical input cables (CeNET) to accept a Toslink connector.
            Yeah, this one rocks!
            The next step is molding in the screen now!
            (http://www.mp3car.com/vbulletin/showthread.php?t=32033)
            Beautiful car btw
            List of front-ends/usefull apps
            XTroniC | XTroniC Direct
              No, mine is aut. But the 850R man. has some problems with clutch and gearbox (wait, mine's got that too, not clutch thoug) but I thougt it would be easier to go with aut cause I would fry my clutch pretty often if I had gone man. I drive like I stole the car =)
              How do you like the advanced chassie mode? they say it's to hard for normal roads. is it?
              /joZ
                BTW, where did you find that cd/dvd? Is it powerd from the firewire or is my english reading skills just to bad???
                /joZ
                  Combo USB 2.0/Firewire Slimline Enclosure
                  /joZ
                  Either your English is just fine or mine is so bad I can't tell the difference.
                  It is running bus powered on a good shielded 4 meter FireWire cable.
                  The DVD slot line DVD came from here:
                  LogicSupply (Vermont, USA)
                  The enclosure from here:
                  Combo USB 2.0/Firewire Enclosure (CA, USA)
                    thanks.
                    /joZ
                      what OBDII tool are you using hardware/software??
                      /joZ
                        /joZ
                        I am using Alex Peper's OBD-2 cable/software it runs the RS232 signal out on CAT5 cable that can be extended and there is a RJ45->DB9 dongle on the PC end. Cost is about $120 US.
                        Vehicle Explorer/Scan Tool
