2004 VW R32 Install - NOT DIAL-UP FRIENDLY
  • 2004 VW R32 Install - NOT DIAL-UP FRIENDLY
    Hah! This forum is supposed to be for "finished" installations, but are they EVER finished? Here's my install as it sits - it's up and running, but there are plenty of upgrades to perform before it's "finished."
    Most of all, I have to thank those on the board who have helped make this happen! JCDillin, Frodo, Frigor, Rando, and Zorro - mad props to you!!! And thanks to everyone whose posts I learned VOLUMES from courtesy of the search tool.
    Interior "before" with XM Roady 2
    Trunk without CPU
    Fuse box before
    Console with finished monitor
    Trunk with CPU
    Fuse box after
    Running Frodoplayer with Frigor's skin slightly modified
    Custom CPU Housing
    The wires behind the housing are ghetto/temporary until the CPU to Monsoon incompatibility issue is resolved.
    EDIT: The issue is resolved!!! Read post #81 for details.
    And the CPU is ghetto-installed until I get the chance to hone my fiberglassing skills and build a proper enclosure for it. Specs:
    Hardware:
    P4 1.8GHz
    160 Seagate SATA HDD
    1024 GB DDR RAM
    7" Lilliput Touchscreen Monitor
    Panasonic DVD
    Mapower DVD enclosure
    Custom-made monitor fascia and CPU housing
    XMD1000 w/custom-made cable and Serial to USB converter
    OPUS 150 fanless PSU
    Griffin Powermate
    802.11B Linksys WMP11
    E-bay WinTV/FM
    Delorme GPS
    7-port USB hub
    Creative USB camera (for parking cam.)
    Sony Ericsson T-616 (for remote volume control)
    Bluetooth dongle
    Software
    Win2k
    Frodoplayer
    Frodo Statellite Radio X
    Phone Control
    VWESIS - Volkswagen Service Information System
    OH! I guess it's only appropriate to post pics of the car.
    My first attempt at a carputer.
    PM me if you're interested in a monitor faceplate for your '99-'04 Golf or Jetta. My Vortex ID is NorthAtlR32 - you can IM me there, too. Go here for more information.
    Absolutly incredible...superb! And you said it wasn't finished...
    I like everything, especially the start button, and, well, the car itself.
    What did you use to fabricate the screen enclosure?
    Do you have a pic of the USB reverse cam?
    Renault Megane...the OEM look
      Excellent install. Looks really good. One question, what screen are you using?
      Also can you post a zoomed-out pic of the screen, like the first pic.
      Thanks.
      Installed
      Asus A7N8X-VM - AMD Mobile Athlon 2400
      512 Ram - 60GB HD - Opus 150w
      Lilliput 7" - Rikaline 6010
      [00000000000001100010-] 98% Completed
      Check Out My Install!!!
        Most of all, I have to thank those on the board who have helped make this happen! JCDillin, Frodo, Frigor, Rando, RedGTIVR6, and Zorro - mad props to you!!! And thanks to everyone whose posts I learned VOLUMES from courtesy of the search tool.
        What's with the circular blue light from the bottom of the pic?
          Awesome install.
          This is too funny ...
          The HPA R32 requires a highly specialized diet of: Mustangs for breakfast, Camaros for lunch, Corvettes for dinner & STIs/EVOs as easy-to-digest snacks in-between meals. A carputer just makes it easier to upload the appropriate software before dining.
          Osiris Networx
          --Tuning is all about price vs performance. You've got to find your own medium.--
            It looks like it might be the powermate.
            Installed
              Oh yeah, thanks Quattro!
              R32, you simply HAVE to post more pics!
                Wow is pretty much all I can say.
                肚子笑痛了
                S60 Install
                  Iím still drooling
                  Ikea Case. Epia M10000.M1-ATX. 512 Mb. 2,5" 80 GB HDD. 7" Lilliput. BU-303 GPS. Sony Joystick.
                  Status -->
                  Lilliput Installed (not indash yet..)
                  BraveCar 2.5
                    Thanks!
                    Thanks Cris. I still want it to be more finished. A custom bezel that closes the gap behind the CPU and the seat the gap between the CPU and side of the trunk would be a step in the right direction. We're planning on showing this car as we get some of the performance and more of the appearance mods completed. So we gotta get that "finished" look.
                    The screen enclosure came about somewhat by accident (and I realize I need to provide better pics). I used 1/4 inch acrylic! I cut (routered) an opening big enough for the Lilliput LCD to fit into and cut (dremel and home-made jig) the slot for the DVD Drive. I used a router on the back of the acrylic to slot it so the DVD drive would sit closer to the "front" of the fascia. Anyhow, I cut the "frame" out of the Lilliput housing and used that Epoxy putty stuff I had left over from my Reef Aquarium days. The nice thing about it is that you can shape it into the basic form you want and it holds REAL well. Once it dried, I sanded it to the perfect shape and used the Plasti-dip paint to cover it. It blistered about three times before I finally get it to lay down right!
                    That start button REQUIRES A RESISTOR! I fried one before I realized that. D'oh! I can't remember the value - I think it was 1.2k Ohm - just enough to drop 5V from the PSU to roughly 2.2 Volts. The buttons are available here in different colors. And I DID get that idea from someone else on the forum.
                    The parking camera is a work in progress. I'm really not concerned about seeing behind the car - call me crazy! My biggest concern is rolling those 18's up the side of a curb when parking away from everyone else. So I'm mounting the camera in the right outside rear-view mirror. That's going to require a fair amount of work since the camera isn't weather resistant, but we'll knock it out. Anyhow, this is basically what it looks like, but that's not the same model.
                    Thanks again! And with any luck, I'll post the links to the articles we get published on the car.
                      OOPS! I'm using a Lilliput 7". I'll go back and edit the post to include that important detail.
                      Thanks.
                      Sure! Like this one? I had posted it originally, but the website told me I had exceeded the number of pictures I can add in one post. Hope you like! By the way, the toggle switch you see at the bottom of the dash isn't related to the carputer install. It's a 7 hp cheat that controls a bypass in the muffler. Details with dyno specs available here.
                        Originally posted by Osiris
                        Awesome install.
                        Thanks man! We're working on the engine over the next couple of months, as well as the engine management software. We're hoping to pull the same numbers HPA was getting out of their cars. But this whole carputer idea started as a result of wanting to be able to upload a 'fat' program at a traffic light as needed with the intention of keeping a more driveable program loaded for ... um... "normal" driving.
                          DUDE!!! Couldn't have done it without your help!!!
                            It is the Powermate. Woke up in a cold sweat at 4:45 this morning when I finally figured out how I could integrate it into the console to make it look factory. Those pics will take a couple of weeks, but work commences tomorrow.
                            Thanks man. We're gonna have her at the shop tomorrow where the light is more conducive for shooting better pics. I'll get some that better show off the software and hardware that's integrated too.
                              Originally posted by Bravellir
                              Iím still drooling
                              Thanks a bunch!
