Renault Scenic II - SPDIF PC
  • Renault Scenic II - SPDIF PC
    Afters years of thought, I finally achieved my carPC v1.0.
    Quick highlights :
    - SPDIF connection to the head unit, hacking the CD changer connection
    - Completely removable solution. Not a single modification to the car.
    - Tank battery circuit to allow for clean shutdown.
    I'll probably set-up a website to give more details, but you'll find a few pictures attached. The PC was build in a metal U shape that can be unfolded for easier maintenance. It is tailor-made to get in the center console of the Renault Scenic, under the armrests.
    When I discovered that the integrated headunit had no AUX input and that the CD changer had no analog connection to it, I was seriously disappointed. I tried an FM modulator but the quality was really poor... I then found that this CD changer actually sends an SPDIF signal to the headunit, and checked with my home PC that standard PC levels were correctly recognized. I thus placed a little relay to switch the headunit SPDIF input from the CD changer to the Epia SPDIF output when the PC is on. The control wires are always connected to the CD changer, so the head unit is fooled into thinking the SPDIF comes from the CDs. Who said sound quality of EPIA motherboards is not perfect ??? :-)
    One specific requirement was that I was allowed no modification to the car as it belongs to my company. No screws, no holes, no glue, nothing. The console place seemed to be the best bet as it already contains a cigare-lighter socket. I had to run 2 wires from there to the headunit (one for SPDIF, one for activating the relay) and temporarily replace the cigar-lighter socket with a more reliable one. Not easy but well, I succeeded thanks to the help of a few guys at http://forum.planeterenault.com . One advantage is that the installation is completely hidden as the console still can be fully closed once the screen is disconnected.
    Finally, as the cigar lighter socket is only powered when the accessory line is on, I had to find a solution to power the PC during its shut down (or hibernation) and settled on a 10 Farad capacitor...
    Just kidding. I'm using an SLA tank battery of course :-)
    The circuit - attached - uses 2 diodes (MBR3045 is a dual diode) and a current-limiting resistor, and was designed following the advices and opinions posted here, there and finally there :-). The 3.4 Ah SLA is probably overkill, but if the shutdown takes longer for a reason or another... better safe than sorry.
    Thanks to all mp3car forum users that helped me in one way or another :-).
    Note : The screen is currently not fixed and sits in the glove box.
    Vicne
    SPDIF CarPC V2 - Tuner List CD Changer Emulator - Chris Conty
    Argh, you beat me there by one day! I've just finished doing the same SPDIF hack to my HU tonight . I guess your Scenic has a VDO "Tuner List" HU too, right?
    A few questions about your setup:
    - You are keeping the changer connected to enable the HU's SPDIF input. Does this mean you always have one or more CDs inserted? AFAIK, an empty changer is automatically ignored and skipped by the HU when switching audio sources. This is why I bought an aux interface from connects2.com (type VRNX001). It acts as a fake cdchanger and also contains an analog-to-SPDIF encoder.
    - Furthermore, how can I get the audio line-in (and the mic input) of the epia to be mixed into the SPDIF output? I haven't tried much yet (nor did I search..) -- all i noticed is that I couldn't hear anything from both inputs. Neither of them is muted in the mixer panel and they are being output properly to the ANALOG line out.
    Anyway, congrats on a hack well done. I am pondering a smart PIC-processor based interface so I can use the HU's stalk control to send commands to the PC. The stalk control in my Clio is actually a simple 3x3 matrix of switches. I am quite sure the Scenic is identical.
    EDIT: I did a search on the analog input issue. There doesn't seem to be a solution yet. A software pass-thru might do the trick, but it will increase cpu load. Anyone?
    CarPC status: HW all done, SW needs tweaked.
    Hardware: VIA MII-12K, 512MB, 60GB 2.5", CW-8123 DVD-CDRW, 7" Lilli ts, Opus 90W, BU-353 GPS, 802.11b PCI, USB bluetooth dongle, AverMedia AverTV Cardbus Plus, Morex Cubid 3677
    Software: RR, MM/FD
      I am very interested in hearing more on this. Can the trick be done on HU without an actual CD changer beeing connected or not?
      Vicne, could you post more detailed pics and changer hack pinout diagram for us?
      BTW I have a "Tuner List" ...
        Thats fnatastic, Gives me great ideas of how to do it in the megane! Have you seen this post with someone else having a screen in the dash. Might be an idea?
        http://www.mp3car.com/vbulletin/show...ghlight=megane
          The cd changer uses SPDIF for audio and D2B (a different set of pins on the blue mini-ISO connector) as control port. The HU will only enable its SPDIF input after getting specific data via D2B. This is one of the purposes of the Connects2 adapter (VRNX001). It mimics a cd changer (1 cd, containing 1 track ) so the HU will enable its SPDIF input. Secondly, the adapter contains a separate analog-to-SPDIF converter (stereo RCA analog in).
          The French URLs below (which handle the issue of linking a VDO Dayton CHM604 MP3 cd changer to a Tuner List HU) show you the pinout of the blue 8-pin mini-ISO. Ignore the round DIN-plug at the side of the changer. I will post the pinout of the stock cd changer (10-pin ISO) when I get home.
          http://www.forum-auto.com/sqlforum/s...ujet217329.htm
          http://perso.wanadoo.fr/sebire.phili...hargeur_cd.htm
          Software: RR, MM/FD
            Here are pictures of the stock cd changer in my Clio and its connector (pin numbers in green). The pinout of this 10-pin ISO connector appears to be as follows:
            1, 2, 4 and 10 = GND
            3 = SPDIF output (to HU)
            5 = CD UART +
            6 = not connected
            7 = 12V switched (from HU)
            8 = 12V permanent
            9 = CD UART -
            D2B traffic is handled by the UART pins.
            Software: RR, MM/FD
              Sorry all for the late replies, I was on holiday
              Yes, the damn "no-aux" Tuner List
              Yes, I've seen it, but I really think it's not worth the 100 EUR or so, that are mostly due to the Analog>SPDIF converter I don't need. So you're right, I always have a few CDRs in the changer : It's definitely cheaper and the only drawback is that every 80 minutes, the SPDIF is muted during a few seconds while the changer loads a new CD. This would probably disappear if I'd only put 1 CD in the changer but I don't really care for now.
              A big advantage of my setup is that I have a simple DPDT relay that switches the SPDIF input from the changer to the PC once the PC is started, so if I don't start the PC or if I remove it from the car for maintenance, the setup is transparent and the changer is fully functional . Of course, it only works if you have a cd-changer...
              Well, I have no use for that right now, but indeed, I think "line-in to line-out" is a kind of "shortcut" that doesn't go through the SPDIF encoder. As you say, it would suffice to go through a higher level application that would just sample these inputs and pass them through to the "wave out" to have them go "the long way" and via the spdif encoder. In that case, the "Playing" mixer settings would of course have no effect, but the "Recording" ones would. Probably using any realtime processing effect with all settings at zero would do the trick, using "some" CPU (depending on how well the effect is written)...
              It shouldn't be too hard to write one, but I don't have time or need for that right now.
              Maybe another way would be through a virtual sound driver such as the one included in TotalRecorder...
              Mmmh, don't know, but if I were you - and that's in my low-priority plans - I'd purely and simply try to emulate the control protocol of the CD changer...
              Regarding that, the status of my research is that among the protocols listed on http://www.mictronics.de/?page=cdc_proto , the only one that uses asynchronous two wires transfer (RX + TX + no clock) is the Blaupunkt one. Moreover it uses the same wires as our Tuner List, so that's encouraging : compare the last page of http://www.blaupunktusa.com/NR/rdonl...5E/0/MDP01.pdf to the attached pinout of the Tuner List (taken from this post). I also had confirmation by bistie on planeterenault.com forums that once the levels are adapted (5V TTL to 12V RS232) the protocol is compatible with a PC serial port. Still have to investigate exactly the protocol grammar, but that would allow not only next/previous/pause but also cd change *plus* feedback of CD#/track# to the dashboard. If you're ready to use a PIC, I think this path is simpler and worth the try, isn't it ?
              Vicne.
              Vicne
                True, that's nice, but that wouldn't fit on the Scenic because it only has one ISO frame (no spare space under the HU)... Moreover, in my case, as this car belongs to my company, I can not modify it permanently.
                My best bet for now would to fix the screen to a big clip that would "bite" the top of the Scenic's dashboard to have the screen almost at the same place as the factory GPS option - see http://www.autotrack.nl/img/news/jul03/Scenic.gif
                Vicne
                  Thanks for the details, mox. By the way, do you have more information on that D2B format and that "specific data" needed ?
                  I didn't know about the CD1/TR1. And what "running time" information does it send back to the player ? I mean, when does the head unit know that it has to change track or disk ?
                  If the changer operates stand-alone in that regard, and the head unit only displays the cd#/track#/time info without interpreting them, that would be cool because we could send other informations to the display (time 12:34 could mean 12st album by artist number 34..., etc).
                  Might be worth thinking of it...
                  Vicne
                    Um, no Actually I am sort of hoping for you to come up with a cool $5 PIC-based interface in the near future My experience with PICs is still next to zero, but I intend to learn more about them, e.g. by building a little development kit and starting off with a simple project.
                    The OEM display in my Clio's dash is somewhat limited, as it only displays track# and cd#, so no remaining time or anything. I guess the ppl of connects2.com have found a way to mimic a single cd with a single endless track. Once I select the cd changer as a source, the HU permanently displays "CD1 - TRACK 1".
                    Somehow I am glad my display is limited
                    Software: RR, MM/FD
                      Only if you emulate the CD changer. So far, only the connects2 device is known to work, but I think it could be done with a PC
                      Here's the pinout. Nothing special as you can see. What pictures exactly are you interested in ?
                      Vicne
                        Well, although I learned PIC programming at school, it's now nearly ten years ago and I have no experience and no material to program PICs, so definitely, I'll do it with a PC serial port or I won't do it at all... By the way, you mentioned "D2B" but are you sure it's the protocol used here ? 5 minutes google search for D2B makes me think it's a very generic protocol, much more than what I'd expect for a simple CD-changer/headunit dialog...
                        The more I think about the problem, the more I think it would make sense that once the head unit source is switched to a CD changer, it delegates all CD handling to the changer and only "passes through" commands from its front panel to the changer and replies back to its display. In that case, the only thing that *has* to be implemented is the "handshake" protocol so that the head unit always thinks that there is a changer present. Then maybe send a static "CD 1 - Trank 1 - Time 0:00" and off we go...
                        Vicne
                          I vaguely remember reading something on planeterenault.com about the highly popular CHM 604 mp3 cd changer using the D2B protocol. It might as well have been a German site, I can't remember
                          Since I've already settled for using my 89 euro Connects2 adapter, I was pondering some kind of smart processor driven interface between stalk control, PC and HU. Purpose of the interface would be to relay stalk commands to the HU by default, unless a certain stalk switch combination or sequence is given (e.g. pressing "source up" and "source down" simultaneously). The interface should then disconnect from the HU and pass controls to the PC instead. By using the interface to translate stalk keypresses into serial data (like an IR remote control), you could then use a serial port and Girder to control whatever application you like
                          BTW, FYI, here are the main components used in the Connects2 interface (I did some reverse engineering on the hardware).
                          Analog-to-SPDIF:
                          TL064 (stereo AF amp), linked to a 5331AKS (stereo A/D converter with serial output), linked to a CS8405A (SPDIF encoder), linked to the HU's SPDIF input.
                          UART control port:
                          ST72C314J4 (some flash microcontroller), linked to a BA8270F ("Bus Interface for Car Audio") which connects to the HU's UART lines.
                          Datasheets of these chips can be found online. Let me know if you have trouble finding them. Given your theory about the protocol, the BA8270F might be particularly interesting, as the datasheet states that it's an interface *master*
                          Software: RR, MM/FD
                            I am also avoiding any mods to my Clio here. Furthermore, I wanted the monitor to be removable at all costs. I am quite fond of this (anodized!) aluminum bracket that I've made for my 7" lilliput. The ugly black round cable will soon be removed, as all necessary connections will eventually be made thru the 15 pin D-sub connector which plugs into a connector that I've mounted into a little coins tray in my dash (I bought the original Renault spare part ).
                            The flatcable will go through a slot in the back of the monitor and be soldered internally. Will post more pics soon.
                            Software: RR, MM/FD
                              I see... Interesting idea indeed. The source up+down might not be possible on all units (mechanically, on both my headunit and my stalk controls, the up and down are mutually exclusive) but I see the idea.
                              Analog-to-SPDIF:
                              That's interesting for anyone wanting just to connect a mp3 player to the head unit letting the control cables run to the changer as I did...
                              UART control port:
                              Well, yes...
                              Unfortunately, this doesn't give explanations about the actual protocol, but better than nothing. Thanks for all this information, I just cross-posted it to planeterenault.com - hope you won't mind, I should have asked before ...
                              Vicne.
                              Vicne
