Finally a working PC in my car!
  • Finally a working PC in my car!
    After years of reading, posting, planning etc I finally have a PC running in my car!! PC is an EPIA M10000 running of an 90W OPUS. It is located in my front trunk for now, not the final install but the final position. Haven't hooked up audio yet, for reasons I'll not go into an FM modualtor is my only choice, that'll go in this week some time. GPS is working, MP3 next, then various web services I want to set up to download weather, traffic etc.
    Here's a quick pic, screen is a DWW-700M, I found I could read it even in sunshine with the roof down (limited testing so far though).
    how stable is the screen?
      Very solid, assuming you mean does it bounce around...? Don't usually watch it during hard cornering though.
        how did you power it?? from computer power supply or computer? and what about brightness?
          My car has, as well as four DIN slots, a spare harness under the dash designed to power a phone kit. With a $10 harness I got live, ignition and ground right behind it.
          I added a 9 pin Molex connector as this harness is now powering my radar detector, screen and soon my FM modulator too. The screen needs ignition, live and ground, the harness in question runs through a 7.5A fuse in the regular fuse box. I blew a fuse when first installing but it has run fine since.
            Oh, brigtness.... seems fine, I could even read it pretty well with the roof down in bright sunshine. This picture was taken driving with the roof down.
              The screen looks really at its place there! Any pic of the screen closed?
              Renault Megane...the OEM look
                Here you go, although the head unit was out at the time. As you can see the screen covers the AC/Heater controls but it's no big deal, I rarely if ever use them.
                The cable in the cig lighter is for a light I was using, it isn't for the screen or PC.
                  That's what's going to happen in my truck. The pop-out screen will cover HVAC controls.
                  Words of wisdom.
                  How about the Wiki?
                    Did you do the clock/light mod? If so, hows the difficulty?
                    Progress:99% not 100% because theres always something to do...
                    Centrafuse on XP (lited)
                    EN15000
                    120GB 2.5" SATA HD
                    1GB DDR2 Ram
                    M2-ATX PS
                    Slot-Load DVD
                    BU-353 GPS w/Mappoint 2k6
                    DWW-700M
                      Yes. It's pretty easy, although be clear what your expectations are, it makes testing much easier. I thought at first that after the mod the clock backlight and eject button light would come on with the ignition, this is not the case. It's all dark until you open the screen.
                      It's fine, it's just that I took it apart half a dozen times checking and re-checking expecting lights to come on with the ignition.
                        Can you post pics of computer / car.Thanks , Looks great!
                          I don't have pictures of the PC yet, need to tidy up some cables, but here is my car.
                            i had this tft, but is not running correctly in my car.. have this TV??
                            finally i changed this monitor for TZL indash and now it's running perfect.
                            ( sorry, but my english is really bad )
                            Renault Megane Coupé Cabriolet
                            P3 550 mhz 256 mb RAM 15 gb hd, dvd.
                            gps handsfree parrot ck3300
                            windows xp sp2
                            road runner
                            map monkey and viamichelin mapsonic
                            Touchscreen 7" fully motorized in-dash
                              Yes, the monitor has TV too although I'm not using it. What is the TZL screen? I haven't heard of that one.
