2003 Ford Falcon BA (Australia)
  • 2003 Ford Falcon BA (Australia)
    Ok
    I know this looks a bit dodgey but it was the best i could come up with.
    The BA Falcon has a integrated radio & HVAC screen in the centre of the dash. The unit cannot be removed making it difficult to find a spot for the Touch screen.
    I have decided to mount it straight over the top of the old screen. I cannot see the radio display or the HVAC controls which is a bit dodgey but will have to do for the moment.
    The PC is an E-Vectra that I have sitting in the boot. Runs of a laptop 12V car adapter (The E-vectra is a 19V PC).
    Works well. except that the power supply does not survive crank which means I have to hibernate everytime I want to crank the engine. eek!
    Anyway here are some pics... any ideas on how to improve would be greatly appriciated.
    To Come: Griffin powermate.
    hey, not bad mate. i have seen some guys modify their screen in their BA to take a RCA conection for an XBOX, maybe you could do that, then add a touchscreen over top. i dont know if they have a switch or what to be able to still use the HVAC controls though.
    THE NEW
    : www.lowagz.co.nr ::
    THE OLD
    :: www.hakhawk.co.nr ::
      Nice install!
      Couple of Qs:
      How is the carptuer hooked into the audio system?
      And in the boot, looks like the floor is lower in the centre?
      Maybe using a rotating actuator arm, you can get the screen to flip up over the air vents when you want to use the controls undernearth. I dunno just me rambling on lol
      Fox Mulder
      2004 Toyota MR2
      Modified Intel Xeon E5450 3Ghz Quad Core 2GB RAM 160GB SSD M4ATX Xenarc 700TSV TS Toslink Audio BU353 DiNovo Mini Car2PC ODBII Bluetooth HF 16x2 Character LCD
        Unfortunatley I dont have the colour TFT, I only have the base model display as shown:
          Originally posted by Fox_Mulder
          Nice install!
          Couple of Qs:
          The audio is linked into the factory sound system, which luckily has an audio in jack.
          The boot has a sunken centre. which is really wierd. I could probably mount the carputer in the sunken bit, so its out of sight, but I figured it would get better ventilation where it is sitting now.
          Yeah I was thinking of making some kind of folding arm.... thats the next project!
            Looks good. It would look much nicer, if you could relocate that OEM display, and fab the screen in there...
            Renault Megane...the OEM look
              Or maybe you can fabircate the screen into a little pod above the air vents. So you'll have to make the pod and cut into the dash above that then bondo or something it all together...
              Fox Mulder
              2004 Toyota MR2
                Orrr take the screen out of its housing, and make up one of these.
                That holds my 7" lilliput after I take it out of its housing.
                2004 Ford Falcon XR6
                  Bob, thats great, where did you get the shroud from? did you make it yourself?
                  I would need to get a lilput if that was the case.
                    How is the viewing angle down there? Seems a little too low...
                      It's fine. Havn't tried it out in sunlight though yet as its still a work in progress.
                      jaytyn, I made the shroud myself from a piece of 9mm mdf, which had a cutout that fits the screen, and then a piece of 3mm mdf over the top which has the cutout for the viewable part of the screen
                        There is this company: http://www.asllogistics.com that can upgrade the standard "green" lcd to a TFT colour jobbie as shown below for $1100. The only problem is that it will not be touch screen. I guess I can probably try and get a touch film. but the problem is the TFT will be composite in...
                        ANy ideas... I really want an integrated solution and this sounds like the best way based on the BA Falcons design.
                        From this:
                        To This:
                          Why not just get them to mod the system and have your vga lcd installed instead then all you have to do is switch the signal from VGA to RCA 1 so u can change the temps etc
                          This way the VGA lcd is installed
                          Problem is do they use a 5" or 7" LCD? i think they use 5" i would ask them to see if they could create a bezal for a 7" screen and do the mod for composite output.
                          CarPC Status:
                          GPS: 99%
                          Hardware: 99%
                          Software: 92%
                          Case Install: 99.9%
                          Dash Install: 100%
                          Car Install: 72%
                            how do u find the screen you currently have? what resolution do you run on it? i'm just personally wondering if i should pay basically twice as much for a lilliput over one of the ones you're using...
                              I was going to use my factory screen but gave up on it in the end. The screen is approx 6" from memory
